Like Tree22Likes
Old 11-03-2010, 05:35 PM
  #3016
Thanks,
Is this what you are refering too?
http://www.amainhobbies.com/product_...less-Motor-85T
1day is offline
Old 11-03-2010, 05:45 PM
  #3017
dangerwr's Avatar
Originally Posted by 1day
Thanks,
Yes it is! Now that I look the next size Castle motor is a 5700Kv. This might be a little much but you can always dial it back. A couple things to be aware of with this car: It likes to run hot and overpowering is not to your advantage--maybe this will help with your decision.
Also, you have limited space to work with. A MM Pro is still a large ESC you might want to do more research on footprints. I have a Novak Kinetic and barely fits. Tekin has really small ESCs and are less of a problem. It all depends on what receiver you are using as well. The Spekrum stuff is really small and gives you more options. I have Novak's smallest speedo and Futaba's smallest Rx compatible with the 4PK and is funny how much room I do not have. There is about .04" between my speedo and my spur.
dangerwr is offline
Old 11-03-2010, 05:55 PM
  #3018
Wow..thanks! I have not even thought about the real estate on this chassis (you are wide open in the 1/8th world so it has never crossed my mind). I run an M11x with a tiny reciever so... I have a MM pro on my jammin so I have that for reference. With that, do you have the size specs on your setup for comparison? (this is getting complicated!)
1day is offline
Old 11-03-2010, 06:01 PM
  #3019
Photocycler's Avatar
Trader Rating: 36 (100%+)
this is so weird this is the pack exactly I bought
http://www.amainhobbies.com/product_...es-74V-4500mAh
When I put it in the rear part of the strap bends over it ..could i have done something wrong when I built it..I dont see anything
Photocycler is offline
Old 11-03-2010, 06:08 PM
  #3020
Corey Bernardo's Avatar
whats so weird... those are the same packs I run.. they will work.. chill out haha
Corey Bernardo is offline
Old 11-03-2010, 06:10 PM
  #3021
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Photocycler
So got my saddle pack and it was pretty disappointing to see the pack I bought is too tall? is it the 45c that is too tall? Do I need to go 35c?
SMC also has a new pack out that will fit (5200, 50C Extreme). As long as the hight of batteries doesn't exceed 25mm, you'll be good to go.
rangerjkb is offline
Old 11-03-2010, 06:12 PM
  #3022
dangerwr's Avatar
Yeah, a couple of us at our our track are running these and fit just fine. What version of the kit do you have?
dangerwr is offline
Old 11-03-2010, 06:14 PM
  #3023
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I believe there is two different height settings for the battery strap. One for 23mm and 25mm. You might be set on 23mm or the bottom hole.
Jmuck69 is offline
Old 11-03-2010, 06:16 PM
  #3024
dangerwr's Avatar
Yeah, this thing is a booger to wire up. Do you know anyone that has one? That is your best bet. You can get a better look here:
http://www.oople.com/rc/photos/review410r/page08.html
It will get complicated! There is much more room on other 10th scales, even. This one is special indeed!
dangerwr is offline
Old 11-03-2010, 06:18 PM
  #3025
check this got the 410 r
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-photo.jpg
Old 11-03-2010, 06:50 PM
  #3026
Jmuck69's Avatar
Check step 14 of the instruction manual. It gives you two positions of the battery strap mounting. For that battery, you should mount the strap in the top hole.
Jmuck69 is offline
Old 11-03-2010, 06:51 PM
  #3027
Dlewis4's Avatar
Trader Rating: 148 (100%+)
ooks like your pack isnt set all the way back like it should be...
Dlewis4 is offline
  #3028
dangerwr's Avatar
Huh. Weird! Did you put the foam strips underneath the battery? BTW, I stole your avatar for our local forum. I just bought the Ripper "Pool Light" deck. I saw the Ripper art book Powell put out but is like a $140. WTH?
dangerwr is offline
Old 11-03-2010, 07:16 PM
  #3029
I finally got around to write out my setup long hand style!!! What a pain in the ass this was, but I promised you guys I would post it, sorry for the delay. I was really trying to get it on the setup sheet but I couldnt figure out why it wasnt saving correctly when I emailed to you guys... Oh well here it is:
TEAM DURANGO DEX410 2010 SPEC SETUP SHEET
NAMECorey Bernardo
DATE 10-31-2010 @ R/C Excitement, Fichburg, MASSACHUSETTS.
AIR TEMP 70’
CONDITIONS INDOOR(hard packed clay that blue grooves) Traction is high bite.
TRACK SIZE: At least 100x40
FRONT SUSPENSION:
RIDE HEIGHT: 19MM
CAMBER: -3
CASTER: KIT STOCK
TOE: 0
DIFF OIL: 5000 AE
SWAY BAR: NO
SPRINGS: BLACK
REBOUND: 0
PRELOAD: 9MM
OIL: 25 LOSI
PISTON: 4HOLE
LENGTH: 22MM
ARM MOUNTING POSITION:1
SHOCK TOWER POSITION:3
CAMBER LINK POSITION(TOWER): 5
CAMBER LINK CASTER BLOCK: 1
SPINDLE/CASTER BLOCK SPACING:2MM ON BOTTON 1MM ON TOP
REAR SUSPENSION:
RIDE HEIGHT: 19MM
CAMBER: -3
DIFF OIL: 2000 AE
SWAY BAY: NO
SPRINGS: LIGHT GREEN
REBOUND: 0
PRELOAD: 11MM
OIL: 20 WEIGHT LOSI
PISTON: 4HOLE
LENGTH: 34MM
ARM MOUNTING POSITION: 1
TOWER MOUNTING POSITION: 1
CAMBERLINK POSITION TOWER: 4
CAMBER LINK HUB: 1
HUB: 1DEGREE HUBS USED
REAR BLOCKS: -2F / 4R
HUBS:SPACED ALL WAY FORWARD 3MM
ARMS SPACED: 1MM FRONT / 3MM R
TIRES:
LOSI BK BARS(PINK COMPOUND) F/R
REAR FOAMS CUT .5” OFF EDGE
NOTES: Car is absolutely amazing to drive super smooth and has steering and corner speed for days!!
1MM SPACER IN FRONT ARMS
ACKERMAN USING HOLE “C”
BALLAST POSITION: SKIDPLATE
WING: DURANGO
BODY: DURANGO
ELECTRONICS:
MOTOR: LRP X12 5.0T
LRP SXX Ver 2 TC Spec
SPUR: 87
PINION:18
BATTERY: ORION 4500 45C
Old 11-03-2010, 07:29 PM
  #3030
dangerwr's Avatar
Where do you find 4-hole pistons?
dangerwr is offline
