Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#3001
I need to make sure I have all the tools needed for this kit. I already have the following:
1.5mm driver
2.0mm driver
2.5mm driver
3.0mm driver
7mm nut driver
What other drivers and turnbuckle wrench sizes will I need to maintain this chassis?
Thanks again!
1.5mm driver
2.0mm driver
2.5mm driver
3.0mm driver
7mm nut driver
Thanks again!
#3003
#3005
#3007
#3008
if your gonna get a kit get the PRO, Dlewis I have to argue with u on this topic... Yes they are pretty much the same cars... but I believe the plastic in the R car is different then the plastic in the Pro... also with the pro it looks all pretty carbon fiber and alloy.... ahha
#3011
No worries! They have worked very well. I have put several packs through the ones I have on the rear and am pleasantly surprised. Make sure you have e-clips because they will get wrecked taking the diff apart if you have not taken them apart 2 - 3 times yet. MHOR has plenty of the e-clips . . .
#3012
#3013
I doubt the plastic is any different. People have to design molds according to which material they use. They would not have 2 different sets of molds for these cars. The difference is in the machined aluminum parts and the carbon fiber bits. And of course there is the bling'n gold anodized spacers.
But to each their own. I would rather get an R and get what it needs than spend an extra $300 and get "pretty" stuff.
#3014
Thanks fellas. Now for the tough part. My local track has no restrictions on motor limit in the sportsman class...so, I have had really good luck with the Mamba Max Pro combos and I am leaning toward the 4600kv setup. Would this really over power this rig on a tight 1/10th scale track? If not please point me in the right direction.
I am use to running 1/8th nitro buggies where more is better so excuse my newbeness. But I recently moved to an area that is really big on indoor electric an the 1/10th 4wd buggy class has bit me good. Seeing first hand that the 410 is almost bulletproof has me sold.
#3015
Edit: The Novak Ballistic 8.5 is a 5000kV motor so I might even step it up a bit to the next one Castle offers . . .
