Like Tree22Likes
Old 10-31-2010, 04:08 PM
  #2881
Company Representative
JoeNolasco's Avatar
Originally Posted by rx7ttlm
Which 4wd Mod cars have oil filled diffs? Ok, I will preface this with I haven't raced 4wd mod in about 6 years. What is the difference between the 410R and the 410? What in the world makes it a $300 difference between kits? (one is 650 one is 350 on stormer, and for that price I can buy ANY other Competition RC car from xray lol) And who is the us distributor? I am thinking about running 4 wheel mod this winter and this looks like a good car (I dig that it has gear diffs because i hate rebuilding ball diffs). Looks like graphite shock towers, and a couple aluminum parts(bulkheads and knuckles)
No other cars have gear diffs that I know of
The 410 2010 spec has many alum and ti upgrades on it and Also includes swaybars and boots on the shocks and cvds
The us distributor is HRP. Many shops stock and support the Durango line. Some more than others. :-)
The dex410 r just needs the front aluminum suspension holders to be good to go. We have a couple guys running without ti turnbuckles and they are fine.
JoeNolasco is offline
Old 10-31-2010, 04:19 PM
  #2882
Originally Posted by Dlewis4
Make sure you post up some pics... those things are gorgeous.
+1 is there a problem w/ the diff. housing?
cbrociuos is offline
Old 10-31-2010, 07:02 PM
  #2883
dangerwr's Avatar
They often leak. I have 10k in my front and does not leak but the rear has 5k and leaked all the time. I used Kyosho P5 o-rings as mentioned on this thread and life is better now!
dangerwr is offline
Old 10-31-2010, 07:04 PM
  #2884
i rebuilt my rear diff using 3k oil with the p5 o-ring and shimmed out abit.
havent leaked yet ..
LiL_JaSoN is offline
Old 10-31-2010, 07:12 PM
  #2885
dangerwr's Avatar
Sweet! I still cannot find those stock replacement washers that sit against the o-rings on the inside of the diffs. I have them back ordered on A-Main though . . .
dangerwr is offline
Old 10-31-2010, 07:18 PM
  #2886
add one of these
http://www.amainhobbies.com/product_...mm-Washer-Shim
OR
http://www.amainhobbies.com/product_...r-7x10x02mm-10
and one of these
http://www.amainhobbies.com/product_...02mm-Washer-10
to each side of the output drives before putting them on
Old 10-31-2010, 07:26 PM
  #2887
dangerwr's Avatar
Default Mysterious servo saver issue solved!
Finally!
So I was out doing some loops at MHOR today and started to go through servo savers again. It really looked like something was chewing into the bottom servo saver arm. We have seen this before but chalked it up to the knurled aluminum nut on the bottom of the servo saver doing work after the plastic piece let go.
Turns out the top, right screw that mounts the servo was sticking through enough to gouge the servo saver and wear it thinner than it already is! I felt like a tard for not noticing this earlier but I can be clueless at times.
Life is good with this issue solved and diffs that are not leaking!!!
dangerwr is offline
Old 10-31-2010, 11:11 PM
  #2888
Trader Rating: 27 (100%+)
can someone maybe post a pic of this? Seems like it needs to be done, I havent built the car yet and would like to know how before I do..
Also where do you use the P5 seals?
C_Money is offline
Old 11-01-2010, 04:55 AM
  #2889
Briguy's Avatar
Trader Rating: 125 (100%+)
Finally!
Good thing is you found the issue and no more servo savers going out !
Briguy is offline
Old 11-01-2010, 11:26 AM
  #2890
Also I was reading all you need is green springs, is it still good to get the spring kit?
And what about the lipo weights? would it be good to get those too?
C_Money is offline
Old 11-01-2010, 12:03 PM
  #2891
im running the kit springs up front. associated black springs worked in back pretty well. but i ordered grey for the rear. the greys are much softer. i bought the skid plate weight, but i have 4 pieces of lead zip tied to the bottom where the other brass weights go. 2 per side. kind of hokey but you really cant see 'em anyhow, and they work. one track i run is hard packed clay on slicks. the other is hard packed top soil on hot bodies pinks. both tracks are high bite. hope this helps.
Old 11-01-2010, 12:38 PM
  #2892
as long as people are using weight then thats what I needed, thanks
C_Money is offline
Old 11-01-2010, 01:16 PM
  #2893
dangerwr's Avatar
It was driving me nuts and wanted to throw the car in the trash a couple of times but knew it had to be something that I was doing wrong. The instructions say to use the M3 x 6mm SHCS but must have been using the 8mm screws or something. The car is packaged so tight there is not room for much error (if any at all)!
dangerwr is offline
Old 11-01-2010, 01:19 PM
  #2894
Corey Bernardo's Avatar
I got my durango "THEIR" its super dialed...... IF ANYONE interested I will post my setup development with you...
Corey Bernardo is offline
Old 11-01-2010, 01:33 PM
  #2895
Photocycler's Avatar
Trader Rating: 36 (100%+)
Building my 410r tonight, any last minute tips...I got the Kyosho O rings for the diffs so want to try and get it right the 1st time with no leaks and a dialed buggy
Photocycler is offline
