Like Tree22Likes
Old 10-27-2010, 06:04 PM
  #2776
Matt Howard's Avatar
Originally Posted by Corey Bernardo
just noticed theirs a new setup on the durango website from competition hobbies oct 24th, and noticed the driver name was "brian kinwald" he running for Durango now? that would be awesome
AFAIK he runs for Xfactory. They currently don't have a 4wd buggy in production so they're given their guys free reign to run whatever 4wd buggy they want until their new one comes out.
Matt Howard is offline
Old 10-27-2010, 07:05 PM
  #2777
Trader Rating: 49 (100%+)
Fix the diffs last. Leaky diffs will get around a track.
Broken servo savers lead to smeared mascara
aradaiel is offline
Old 10-27-2010, 07:34 PM
  #2778
Corey Bernardo's Avatar
thats pretty Matt!!
Going to run on a blue groove indoor track tomorrow all day then racing starts at 7pm.. I have a quick question, just want to get the car to its full potential of greatness.. I have it pretty freaking dialed right now, just curious if I can get it "even" better... On the rear tie rods, if I was to move the camber link down one row all the way in, and all the way out on the rear hubs.. that will produce more rear traction correct?? intially
Corey Bernardo is offline
Old 10-27-2010, 07:53 PM
  #2779
fifi's Avatar
Tresrey option for broken servo saver.
Coming end October
seen at http://m2d-shop.fr/
fifi is offline
Old 10-27-2010, 08:12 PM
  #2780
Briguy's Avatar
Trader Rating: 125 (100%+)
Wish the Tresrey parts were available in the states .
Briguy is offline
Old 10-27-2010, 08:17 PM
  #2781
fifi's Avatar
thats pretty Matt!!
Good tips under buggy setup guide
http://www.petitrc.com/index.php?page=setup_guide
fifi is offline
Old 10-27-2010, 08:37 PM
  #2782
fifi- good call that site rocks!! I remembered some stuff, but after being away for 7 years it was tough... good call thanks!!
Old 10-27-2010, 08:55 PM
  #2783
fifi's Avatar
Haven t touch my 410 for 4 month so 7 years...
Had to read more than 120 pages on this forum.
My 410r should arrive today to replace some used parts of my 410 and try the plastic side, the U and 25mm lipo
This part looks so nice
Not mine don t know what it worth.
fifi is offline
Old 10-27-2010, 11:07 PM
  #2784
dangerwr's Avatar
Coming end October
Tresrey website now says early November. I am still considering just making my own . . .
dangerwr is offline
Old 10-27-2010, 11:08 PM
  #2785
i like the red mid drive axles.. makes the car look bling!
also the aluminium servo saver link.
LiL_JaSoN is offline
Old 10-27-2010, 11:27 PM
  #2786
dangerwr's Avatar
Yeah, I guess red is the Tresrey trademark (sorta). I really like the gold that Team Durango uses. I will take freaking purple if someone would just make one!
dangerwr is offline
Old 10-27-2010, 11:37 PM
  #2787
look what's tresrey coming out with in nov.. new shocks, shock towers, brass weight
http://www.tresrey.com/tresrey/produ...parts_eng.html
i also converted the price of the steering link, it works out to be $15, which is fairly cheap.
im going to email them the price for postage.
Old 10-28-2010, 12:30 AM
  #2788
azz187's Avatar
Lil Jason,
You should have bought an associated!!!!
and whats with the so wobbley outdrives..
kinda pissing me off.
seriously, leaky diffs, wobbley outdrives, tight as hell outdrives.
how can they F up the diffs.
and why dont they make the diffs where the pin goes throw the outdrive rather than a e-clip.
azz187 is offline
Old 10-28-2010, 02:29 AM
  #2789
fifi's Avatar
If you go with all the tresrey parts you will have to go with nosram electronic... same as LRP but in red.
fifi is offline
Old 10-28-2010, 05:23 AM
  #2790
that would be nice, but would be too much $$ on unneccessary parts to make it look good.. red washers, red shock collar,
anyway i think i found a solution to wobbley outdrives by shimming the outdrives using 7x10mm shims and 5x7mm shims.
if you notice the outdrives wobble because there is alot of room under it so it can move side to side.
i noticed the outdrives have alot of play back/forwth causing the outdrives to wobble, so shimming the outdrives out so the have minimal back slop and less play, so the outdrives has less room to move side to side so it wobbles less,
also make sure the gear inside sit all the way in.
dont put the shims inside the diff as it will push the gear out more and have a gap under the gear giving room for oil to flow. put the shims outside the diff onto the outdrive to remove all the play.
combine these with the p5 orings and u should have a perfect wobbleness, leakness diff.
