Like Tree22Likes
Old 10-23-2010, 07:33 PM
  #2686
Matt Howard's Avatar
Originally Posted by MaTt 93
them it is than .....which flange, the revolution or the rubber?
Get the revolutions if they're in stock. When I ordered my kit I had to get one of my sizes in rubber.
Matt Howard is offline
Old 10-23-2010, 09:03 PM
  #2687
TheFcuddy's Avatar
Originally Posted by Briguy
I`m running a Tekin 7.5 geared at 19 and don`t get above 130 after running a full pack . Timing cranked to 85 , 40 boost and current limiter at 80 . I even had to switch to a regular RS as my new RS Pro failed on me .
I have a 20t pinion in there right now. My timing is at 80, I am running dual mode so I don't have turbo or boost going. Anything else I should look for to cause excess heat? I will lose the timing for now. I take it the servo saver gets sloppy quick?
TheFcuddy is offline
Old 10-23-2010, 09:11 PM
  #2688
Briguy's Avatar
Trader Rating: 125 (100%+)
A couple guys have been having issues with the servo saver but I think it is from being bound up by too much lock tite . I`ve only raced mine 4 race days so far and everything is like new , no slop in the suspension or steering .
Briguy is offline
Old 10-23-2010, 11:54 PM
  #2689
I have a real stupid problem, and I don't know how I managed it.
My front wheels are pulling forward and my rear are reversing, which looks awesome and takes a couple seconds to figure out why the wheels are rotating at full speed, yet the car is not moving.
I spent the day trying to fix my previous build errors and get the wiring done to try and make a heat, to no avail. I'm burned out and can't see in the manual where my (probably, very silly and simple) mistake is.
Help? PM's appreciated.
brettness37 is offline
Old 10-24-2010, 12:00 AM
  #2690
urismo21's Avatar
Trader Rating: 14 (100%+)
I have also made this error, you would have one of the diff's in upside down.
Always remember screws to the bottom and you should be alright, lol.
urismo21 is offline
Old 10-24-2010, 12:01 AM
  #2691
urismo21's Avatar
Looking for gearing advice for running 17.5 with a normal LRP TC spec ESC. I have the tekin 17.5...
THanks in advance
Luke
urismo21 is offline
Old 10-24-2010, 04:43 AM
  #2692
Dlewis4's Avatar
Trader Rating: 148 (100%+)
THanks in advance
Luke
I would start in the 30-31 range. 17.5 in this thing?
Dlewis4 is offline
Old 10-24-2010, 07:52 AM
  #2693
TheFcuddy's Avatar
I will pull it apart and see if I can find a problem. Thanks.
Old 10-24-2010, 09:15 AM
  #2694
Corey Bernardo's Avatar
another weekend with the new durango and I have to say my skills are coming back a lot faster than I anticipated after a 7 year hiatus haha .. I have my car absolutely on rails.... let me know if anyone wants to try it out... was testing all day yesterday at my indoor blue groove course... took me 4 packs to get it...... Now I just have to worry bout all my sponsors remembering me ? ahah
Corey Bernardo is offline
Old 10-24-2010, 09:27 AM
  #2695
Briguy's Avatar
I`d be interested in your setup .
Briguy is offline
Old 10-24-2010, 09:32 AM
  #2696
Konich's Avatar
What are people using for replacement ball cups (RPM, assoiciated, etc)?
I'm going through my cars today and there is too much slop in the steering and rear hubs. All the ball studs are tight but it looks like the cups are getting "ovaled" and causing too much slop. These are the original that came with my kit but I have replacements. I just don't want to be replacing them every couple of months.
I would like to use the stock turn buckles so shoot my some idea's!
Konich is offline
Old 10-24-2010, 09:54 AM
  #2697
Konich's Avatar
Kyosho P5 seals are in stock apparently
https://store.vgracing.com/catalogse...t/?q=kyosho+p5
Konich is offline
Old 10-24-2010, 10:27 AM
  #2698
Dlewis4's Avatar
Ordered mine thru Amain last night
Dlewis4 is offline
Old 10-24-2010, 11:05 AM
  #2699
Is there some sort of pillow ball or something I need for the aluminum hinge pin holders? Anyone got a part number?
Old 10-24-2010, 11:16 AM
  #2700
http://www.amainhobbies.com/product_...vot-Ball-Set-8
