Like Tree22Likes
Old 10-22-2010, 11:25 AM
  #2671
grapejuice's Avatar
Trader Rating: 153 (100%+)
Originally Posted by Corey Bernardo
just noticed on Hupo's setup he has 3K front and 1K in the rear..
different viscosities thicker produces more ???
different viscosities thinner produces more???
would it be the same as tightening or loosing a ball diff? first time ever used a car with a gear diff
I ignored that part of the set-up since diff setting vary track to track, and oil weights vary between manufactures just like shock oil.
But yes it is the same as tightening/loosening a ball diff.
grapejuice is offline
Old 10-23-2010, 01:29 AM
  #2672
urismo21's Avatar
Trader Rating: 14 (100%+)
Originally Posted by grapejuice
Does your car turn? I good starting point is 10k front and 5k rear.
Yeah, car does seem to turn in alright. Everyone runs way lighter oil, what is the advantages of this and or whats the advantages of the thicker oil
urismo21 is offline
Old 10-23-2010, 07:40 AM
  #2673
R/C Tech Elite Member
DavidR's Avatar
Trader Rating: 97 (100%+)
Hey guys...
Here's the pics of that fan mount...
Sorry it took so long...
What I did was used the plastic from a box that a Savox servo came in... It's just about perfect.
Wedged it in between the RX and speed control, I'll end up using just a dab of shoe goo to hold it in place.
When I go to wire up MY car I'll probably etch everything out so the cut lines are smoother and better looking.
DavidR is offline
Old 10-23-2010, 10:52 AM
  #2674
Just joined the Durango community, finished it up today! Can't wait to take it out for the first time Monday night.
Thought I would post a few pictures. When I got the car and saw the bright yellow wheels, I decided to go with a paint job that was equally bright and obnoxious. The design is inspired by Troy Lee's livery for the Flying Lizard Porsche from a few years ago.
I shoehorned an XErun 120A esc in there, and it does fit with a micro spektrum receiver, barely. Was a pain in the butt though. I still have to shorten the motor wires, but this works for now.
Let me know what you guys think!
Thothtp is offline
Old 10-23-2010, 01:24 PM
  #2675
Blackstring's Avatar
Hey guys I'm selling my 09 spec 410. $450 includes lots of spares and tires. PM me if interested. I'll post a few pics later.
Blackstring is offline
Old 10-23-2010, 05:53 PM
  #2676
More pics available upon request
Old 10-23-2010, 05:58 PM
  #2677
TheFcuddy's Avatar
I ran my 410R tonight. This is pretty much my start into 4wd. I have a Tekin RS Pro 6.5t with a 12.5mm high torque rotor. I have my timing at 80. The buggy is incredible. I ran it for about ten minutes and heat is an issue. My motor was 140 and my ESC was 170-180. I don't want to do that again. Is this generally the case with this car? I want to run a battery straight through but that might not be possible. The drive train seems free. I want to see what you guys are turning up with temps.
The rear skid plate is junk, that thing pack up with dirt and pretty much tore off. There seems to be some slop in the steering as well. I will have to pull it apart and maybe tighten the servo saver. The wheels don't seem to go back to exact center if I throw it to the ends and back. I have a Hitec 7940 in there.
The car is awesome I just need to get some issues ironed out for reliability. Is it general practice to not run 4wd's for extended periods of time? I am going to look into rigging up a fan for sure.
TheFcuddy is offline
Old 10-23-2010, 06:14 PM
  #2678
Trader Rating: 49 (100%+)
What size pinion?
I'm running a 20T pinion with normal spur and I'm using a Tekin 13.5.
I can run a whole pack with the ESC being 100ish and motor being 130ish. (assuming I can get a whole pack through it without the servo-saver grenading)
aradaiel is offline
Old 10-23-2010, 07:00 PM
  #2679
Briguy's Avatar
Trader Rating: 125 (100%+)
I`m running a Tekin 7.5 geared at 19 and don`t get above 130 after running a full pack . Timing cranked to 85 , 40 boost and current limiter at 80 . I even had to switch to a regular RS as my new RS Pro failed on me .
Briguy is offline
Old 10-23-2010, 07:09 PM
  #2680
MaTt 93's Avatar
hey,
Im thinking about getting some new bearings for my dex410r and was wodering what ones to get??? Im probably looking at spending about $30?
thanks,
Matt
MaTt 93 is offline
Old 10-23-2010, 07:11 PM
  #2681
Briguy's Avatar
Avid revolutions
Briguy is offline
  #2682
Matt Howard's Avatar
Originally Posted by MaTt 93
hey,
thanks,
Matt
Avid sells a set, they're a buck a piece and you can choose what seals you want in them, steel, rubber, or steel/rubber.
Matt Howard is offline
Old 10-23-2010, 07:17 PM
  #2683
MaTt 93's Avatar
awesome.... are they any good?? because the bearings that came with the kit started squeaking after about the 5th race day
MaTt 93 is offline
Old 10-23-2010, 07:21 PM
  #2684
Briguy's Avatar
Don`t let the price fool you . I ran their bearings in my 1/8 buggies and they last quite a while .
Briguy is offline
Old 10-23-2010, 07:27 PM
  #2685
MaTt 93's Avatar
them it is than .....which flange, the revolution or the rubber?
MaTt 93 is offline
