Like Tree22Likes
Old 10-21-2010, 07:32 AM
  #2641
R/C Tech Elite Member
DavidR's Avatar
Trader Rating: 97 (100%+)
Originally Posted by Dlewis4
I like the fan mount. Any better pics of it to see how it was done?
I didn't take any last night, but I'll pull it out and snap some today.
Pretty simple idea that seems to work good though!
DavidR is offline
Old 10-21-2010, 08:18 AM
  #2642
grapejuice's Avatar
Trader Rating: 154 (100%+)
Originally Posted by Briguy
Here it is -
Front End-
Camber link: #2 on tower(middle inside), "R" caster hubs
Shocks: Black springs, 2 hole x (55) drilled piston, Losi 35 wt.
Middle on tower(carbon tower), outside on arm
Diff: Losi 15K
Toe: 0 deg.
Camber: -1 deg.
Ride height: 18mm
Front ackerman
Rear End-
Camber link: #3 on tower(second from the bottom inside), #2 on hub(middle)
Shocks: Light Green springs, 3 hole x (55) drilled piston, Losi 30 wt.
Middle on tower(carbon tower), middle on arm
Diff: Losi 5K
Toe: 0 deg, hubs
Camber: -1 deg.
Ride hight: 19mm
Anti-squat: RF -2, RR 4
Side and Skidplate weights
LRP SXX TC Spec w/ X-12 7.5 (prototype rotor), 87/21 gearing
Made a couple more small changes, using the Kyosho orings in the diffs now so went back to 10k in the front since the rings fit a little tighter, no leaks yet after two race nights and some practice!!!! Moved rear hubs all the way forward, think what I might do is put a 1.0mm spacers on the front side of the hub to space it back just a bit. Broke the 29 lap barrier last night from 28!! Car is feeling good!
grapejuice is offline
Old 10-21-2010, 08:21 AM
  #2643
mike881's Avatar
wow good job!
mike881 is offline
Old 10-21-2010, 11:55 AM
  #2644
Trader Rating: 78 (98%+)
Well guys did some track testing on the new diff housing, they worked great LEAK FREE!! and smooth. I am working out making new harder outdrives, and the alloy steering arms will be ready for testing by monday or so. Please everyone be patient, you wont be dissapointed.
Raul Garcia is offline
Old 10-21-2010, 01:14 PM
  #2645
Briguy's Avatar
Trader Rating: 125 (100%+)
Sounds good !
Briguy is offline
Old 10-21-2010, 01:22 PM
  #2646
grapejuice's Avatar
But I want it now!!!
Old 10-21-2010, 01:51 PM
  #2647
Corey Bernardo's Avatar
SLIGHT CLICKING UNDER HARD ACCELERATION WHAT IS THIS ??? EWWW
Corey Bernardo is offline
Old 10-21-2010, 02:00 PM
  #2648
ABBOTT's Avatar
Most likely the rear ring gear. Shim rather close and let it work its way in.
ABBOTT is offline
Old 10-21-2010, 02:03 PM
  #2649
dangerwr's Avatar
The ball diffs on someone else's car?
dangerwr is offline
Old 10-21-2010, 02:38 PM
  #2650
ABBOTT- I think you are correct with you hypothesis ! On the issue being the rear ring gear that messes with the rear diff gear... should I try to loosen it put it together again and re-apply lock tight, cuz it seems to me that it as a lot of play in their meaning lock tight came unlocked hahah
Old 10-21-2010, 03:20 PM
  #2651
ABBOTT's Avatar
I left the pinion like it shows in the manual then added one extra shim to which ever side of the diff that would make the ring gear mesh tighter with the pinion. No problems so far, but Im also running alot less motor than you
ABBOTT is offline
Old 10-21-2010, 05:38 PM
  #2652
is it me or ALOT of plastic-plastic or screwing into plastic parts when screwing dont 100% tighten up.
even though the screw is all the way in, you can just keep spinning it.
its a snug fit, but just doesnt fully tighten/lock.
noticed this to about 80% of the the parts where you screw into plastic on my car.
LiL_JaSoN is offline
Old 10-21-2010, 05:40 PM
  #2653
Briguy's Avatar
I didn`t have that problem when assembling mine .
Briguy is offline
Old 10-21-2010, 06:05 PM
  #2654
I had no issues either the car is fawkin amazing!!!! I LOVE IT
I just dont like this slight click under hard acceleration! ahha
Old 10-21-2010, 06:25 PM
  #2655
R-E-A-P-E-R-'s Avatar
Bad tooth on your spur maybe????
R-E-A-P-E-R- is offline
