Like Tree22Likes
Old 10-19-2010, 05:28 AM
  #2581
anyone run those big tube washers inside the hubs between the bearings?
i dont seen them neccessary?
LiL_JaSoN is offline
Old 10-19-2010, 05:33 AM
  #2582
RETRO R/C's Avatar
Trader Rating: 57 (100%+)
Run them without question.
It stops "bearing crush".....in other words your bearing wont "bind" when you tighten up the wheel nuts.
Cheers
Darryn
RETRO R/C is offline
Old 10-19-2010, 07:04 AM
  #2583
grapejuice's Avatar
Trader Rating: 152 (100%+)
Originally Posted by Matt Howard
Yes, run the hubs forward to get more rear bite. That's the only way I've run mine so far
I'll have to give that a try.
grapejuice is offline
Old 10-19-2010, 07:06 AM
  #2584
Briguy's Avatar
Trader Rating: 125 (100%+)
Are you guys running the rear arms forward or in stock kit location ?
Briguy is offline
Old 10-19-2010, 07:42 AM
  #2585
Trader Rating: 79 (99%+)
arms full foward, and hubs full foward.
Raul Garcia is offline
Old 10-19-2010, 07:48 AM
  #2586
Corey Bernardo's Avatar
just added the bronze alloy weight unit to the rear of the DEX410, did you guys notice any difference with this??
Corey Bernardo is offline
Old 10-19-2010, 08:04 AM
  #2587
grapejuice's Avatar
Definitely, helps keep the rear-end more planted, plus the car was originally designed with NIMH batteries.
Old 10-19-2010, 08:47 AM
  #2588
awesome good to hear . . . I got it pretty dialed in last night by softening the suspension 2 rates softer then stock setup, today will try the weight kit unit mounted in and rear hubs forward. . . just am afraid to lose steering I have it rotating so good like a 12thscale! ahah
Old 10-19-2010, 11:17 AM
  #2589
rfleck's Avatar
Trader Rating: 58 (100%+)
[QUOTE=Corey Bernardo;8093253]awesome good to hear . . . I got it pretty dialed in last night by softening the suspension 2 rates softer then stock setup, today will try the weight kit unit mounted in and rear hubs forward. . . just am afraid to lose steering I have it rotating so good like a 12thscale! ahah[/QUOTE
from the sound of the changes you are making, you should be close to what alot of us are running. I wouldn't worry about losing steering. I have tried alot of things and have yet to have the car push in the turns.
I ran this past weekend at my LHS, after putting on the rear weighted skid pad and almost pulled of a 18 lap qualifier, which has yet to happen on the new configuration.
rfleck is offline
Old 10-19-2010, 01:16 PM
  #2590
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Before you buy the weights... limit the rear travel with the droop screws... you wont need to spend the money!
Dlewis4 is offline
Old 10-19-2010, 05:55 PM
  #2591
Alright guys I have the care completely dialed now its on rails!!! I labsolutely love it. I can put it anywhere I want and the car just goes... Changes I made tongight compared to last night are.... the weight unit in rear, forwarded spaced rear hubs, and .5 - 1 degree of toe in with the front I also went from Jconcepts bar codes to PROLINE HOLE SHOTS M3 compound! I LOVE THE CAR WOW... Ill post my setup soon..... if u guys wanna try it.. I think I really hit gold
Old 10-19-2010, 06:25 PM
  #2592
Konich's Avatar
Nice to hear, I'm going to move my hubs forward and see how it does tomorrow night.
Where are people finding the Kyosho P-5 seals for the diffs?
Konich is offline
Old 10-19-2010, 06:33 PM
  #2593
rfleck's Avatar
P5 orings have been dialed for me so far. 3 races, no issues.
rfleck is offline
Old 10-19-2010, 06:38 PM
  #2594
Briguy's Avatar
Only place I could find them is Amain but they have been out of stock . I only have one race day on my buggy but the stocks are still holding .
Briguy is offline
Old 10-19-2010, 06:58 PM
  #2595
dangerwr's Avatar
So today at work they were wiggling in the door a new, small CNC machine for our model shop. AWESOME! So I will be drawing (reverse engineering) the servo saver in CAD this week. Hopefully I will have an aluminum one in no time. Not sure if I will be able to punch out a bunch of them but will make at least a few and get 'em anno'd in black. Danger Gear for the Durango. SWEET!
dangerwr is offline
