Like Tree22Likes
Old 10-17-2010, 07:40 AM
  #2536
mike881's Avatar
Originally Posted by Slim18
I was wondering if anyone had any heat issues on their speed control. i have a novak 8.5 in my rango and the motor is cold as can be but when i ran a 22T pinion the speed control thermaled on me. i jumped down to an 18t and temps are in range now but from what i have been reading most people with an 8.5 are running over a 20T pinion. anyone have any incite on this
I retuned my Tekin rs because it kept thermalling on me no matter what I was geared at. Somebody told me the stock Tekin settings aren't good for a 4wd but regardless, I got an lrp and it lasted through 4 races last night do you have a fan on yours? My lrp still gets to about 140 with a fan so I think the fan is a big help
mike881 is offline
Old 10-17-2010, 07:46 AM
  #2537
Briguy's Avatar
Trader Rating: 125 (100%+)
When I first bought the car and seen the body I thought I would have heat issues . I'm running a Tekin RS Pro 7.5 and believe I have a 19 toot pinion . All night my Motor temp was 130 and ESC was 140 .
Briguy is offline
Old 10-17-2010, 07:52 AM
  #2538
mike881's Avatar
I finally got to run my Durango and get a real race night with it. I must say it has A TON of steering. I raced a b44 two weeks ago because my speedo fried up, it was fun but man that thing pushed in the corners compared to the rango. The only problem I had last night was when the track was perfect I kept rolling after the straight. I feel like I had way too much steering and way too much traction which isn't a bad thing, I can deal with that
I also noticed at the beginning of the night it felt more like a 2wd then a 4wd. Is there any rule of thumb to make it pull out of corners rather then spin out? I toned down my finger and that helped
These aren't bad things and I figured I'd ask because I have no idea what different setups do. I love this car and can't wait to race Wednesday night with it!
mike881 is offline
Old 10-17-2010, 09:37 AM
  #2539
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Hey guys. I am looking at purchasing a Durango buggy, but I believe the SMC Saddle Pack 4900 I currently have is too tall for the car. The lipo is 26mm tall. Can anyone help me out on whether this will fit?
Thanks,
Brad Shearer
Brad S. is offline
Old 10-17-2010, 09:45 AM
  #2540
mike881's Avatar
Thanks,
Brad Shearer
I think you have to stick to it being under 25mm... the rear drive shaft goes right over the batteries
mike881 is offline
Old 10-17-2010, 10:13 AM
  #2541
Konich's Avatar
I have some IP Lipo's for sale 35C and 4200 23.5 mm tall if anyone is looking for some cheap lipo packs
Konich is offline
Old 10-17-2010, 10:26 AM
  #2542
R-E-A-P-E-R-'s Avatar
how much?
R-E-A-P-E-R- is offline
Old 10-17-2010, 10:32 AM
  #2543
Konich's Avatar
Maybe a trade for a body?
Konich is offline
Old 10-17-2010, 02:54 PM
  #2544
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Ive got a 35C IP4200 for sale as well... not wanting too much for it...
So. I have settled on a setup for my car
Front
Dark green springs/3 hole pistons/40 weight shock oil
top outside camber link/ 0* camber and toe
10k front diff weight
Rear
Light Green springs/3 hole/30 weight oil
top inside camber/0 camber/1 toe
2/4 antisquat dive thingy's
5k rear diff weight.
The only thing i am thinkign about trying is 7k/3k weights in the diffs. BUT, as of irght now, my car is CLEARLY the fastest in the corners and around the track period... just need to figure out how to be more consistent.
Dlewis4 is offline
Old 10-17-2010, 04:47 PM
  #2545
dangerwr's Avatar
Originally Posted by Raul Garcia
I will have some finished parts tonight.
Were you able to take a test drive?
dangerwr is offline
Old 10-17-2010, 04:56 PM
  #2546
Konich's Avatar
Dlewis4: What are your shock hole mounting positions front/rear?
I have close to the same setup but would like to take a tad of steering out of the front. I think all I might need is a simple shock relocation.
Konich is offline
Old 10-17-2010, 05:02 PM
  #2547
Dlewis4's Avatar
FRONT
2nd to the inside on the tower
inside on the arm
REAR
inner on tower
outer on arms
Dlewis4 is offline
Old 10-17-2010, 05:18 PM
  #2548
Trader Rating: 21 (100%+)
Talking
just get back from my race club!this car is awesome!no lag on acceleration.lot of steering! the bad on my side is the small plastic skid plate at the back..damn gotta get the brass one and then i'll be okay!..
mccoy is offline
Old 10-17-2010, 06:20 PM
  #2549
Trader Rating: 79 (99%+)
Sorry no test drive, but how's this..
Raul Garcia is offline
Old 10-17-2010, 06:22 PM
  #2550
