Like Tree22Likes
Old 10-16-2010, 08:04 PM
  #2521
Matt Howard's Avatar
Originally Posted by Briguy
Count me in also .
This buggy is awesome !
I take it your maiden run went good
Matt Howard is offline
Old 10-16-2010, 08:13 PM
  #2522
Briguy's Avatar
Trader Rating: 125 (100%+)
Ya , my lap times are much better with this buggy . Amazing the difference just on the first night running it .
Briguy is offline
Old 10-16-2010, 08:15 PM
  #2523
Corey Bernardo's Avatar
Well after running the Durango today I must say I was impressed with how it turns and handles the bumpy stuff, freaking car turns I love it so aggressive yet easy to drive if that makes sense......May a few changes to setup but not many from kit 2010 spec... I did break one thing though and I wish they sold it in alloy, since the plastic is rather cheap... its' the rear O shaped plastic piece where the rear diff pushes through and hold the battery strap at the same time in between 2 gold shims.... Other that that, car seems pretty good. I guess the 4.5 motor was a lil too much torque for that piece thank god for zip ties for now!! ahah
Changes I will make next time are - BK bar all around instead of J-conceps Bar Codes, and perhaps a softer rear spring
PS. the Orion 4500 45c LRP combo speedo and motor where super fast! aha
Corey Bernardo is offline
Old 10-16-2010, 08:30 PM
  #2524
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I know my first time driving it i picked up 2 laps over my b44... so much easier to drive... it just... goes.
Dlewis4 is offline
Old 10-16-2010, 10:13 PM
  #2525
Kind of a silly question: do standard wheels fit this buggy? ei. can I put JConcepts Rulux wheels or something on this bad boy without some kind of adapter?
brettness37 is offline
Old 10-16-2010, 10:25 PM
  #2526
Dlewis4's Avatar
Just gotta drill out the centers just a tad...
Dlewis4 is offline
Old 10-16-2010, 10:43 PM
  #2527
R-E-A-P-E-R-'s Avatar
I LOVE MY DURANGO
R-E-A-P-E-R- is offline
Old 10-17-2010, 01:07 AM
  #2528
I had my first un of my 410 today. I run then the rain came. I found I had way to much steering. Im running dark green springs front,3 hole pistons and 30wt oil. light green rear with 3 holes and 25wt. 50K front and 20K rear.
Using Goose bumps all round. (as I used to with B44) longest length turnbuckles all round, high roll center with 3 deg kick up, 4 deg hubs.
I race on a loose loamy surface. (Ive never used gear diffs before).
What would be a good starting point to dial out some steering.
I found the steering super responsive. and under accelleration the rear wanted to step out.
Also the servo saver came loose after 6 laps. Ive done it up tight now!!!
And im running the full weight set
kiwi79a is offline
Old 10-17-2010, 03:43 AM
  #2529
hmm.. IP 5000 35c or IP 5200 45c
LiL_JaSoN is offline
Old 10-17-2010, 04:13 AM
  #2530
Dlewis4's Avatar
I got an IP4200 35c for sale...
Dlewis4 is offline
Old 10-17-2010, 04:38 AM
  #2531
run the low roll center in the rear and lighten up those diff oils. Most people are running 7-15K in the front and 3-5k in the rear.
Old 10-17-2010, 06:08 AM
  #2532
Briguy's Avatar
I put Grape`s setup on mine and so far I really like it , just had to turn the steering down some . Even when the track dried up last night I couldn`t run full steering , which I would of been pushing with my XX-4 .
Anyone want to buy a XX-4
Briguy is offline
Old 10-17-2010, 06:12 AM
  #2533
Trader Rating: 49 (100%+)
Move the rear hubs forward, if not already. Made a huge difference in mine.
aradaiel is offline
Old 10-17-2010, 06:13 AM
  #2534
Originally Posted by Raul Garcia
You'll see...
Everyone is having the same two problems. You guys won't be disappointed.
Servo savers, diff hoops and Hingepin braces are what are in order.
aradaiel is offline
Old 10-17-2010, 07:24 AM
  #2535
I was wondering if anyone had any heat issues on their speed control. i have a novak 8.5 in my rango and the motor is cold as can be but when i ran a 22T pinion the speed control thermaled on me. i jumped down to an 18t and temps are in range now but from what i have been reading most people with an 8.5 are running over a 20T pinion. anyone have any incite on this
Slim18 is offline
