Like Tree22Likes
Old 10-14-2010, 09:00 PM
  #2461
Corey Bernardo's Avatar
Ok guys I finished the DEX410 2010 spec tonight.... just have to add electronics and paint the body... Was a great build, super quality everywhere.... I ended up breaking the rear circliar housing where the batter pin pushes through... uses quick CA for now... it was almost impossible to get the pin through the top holes....
Front end question
I have some minding in the steering and left arm is binding as well.. I think I will re -do the front end again... do u guys reccomend?
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-photo.jpg
Corey Bernardo is offline
Old 10-14-2010, 09:15 PM
  #2462
Trader Rating: 49 (100%+)
I used B4 turnbuckles, $21 for six.
I keep breaking the servo saver as well. If I have it too tight it destroys servos and if I have it too loose it breaks the servo saver. It seems like I can't win.
aradaiel is offline
Old 10-14-2010, 09:22 PM
  #2463
Dlewis4's Avatar
Trader Rating: 148 (100%+)
How are you breaking the servo saver... put it half way tight, thread lock it, then be done with it....
I just dontsee how...
As for Corey, make sure the steering is tight, then back off half a turn on the nuts that hit the bearings.
make sure your plastic bushings in the arm mounts and the general arm mounts themselves arent tweaked.
Dlewis4 is offline
Old 10-14-2010, 09:48 PM
  #2464
mike881's Avatar
What dont you understand? Several people, myself included, have had problems with the servo saver. Others not so much but thats good for them!
mike881 is offline
Old 10-14-2010, 09:50 PM
  #2465
Dlewis4's Avatar
Cuz I race my car 3x a week and have never had a problem. I dont know if they changed how they made them right after i got mine or something.
I wreck... a lot. Havent broken mine yet... knock on wood... lol
Dlewis4 is offline
Old 10-14-2010, 10:43 PM
  #2466
dangerwr's Avatar
Fine. I have access to a Fedal if any of you know what that means. Anodizer too. I just need to know if it is an issue 4 others , , ,
Let me be the 1st. Danger Gear.
dangerwr is offline
Old 10-15-2010, 02:23 AM
  #2467
Originally Posted by mike881
Did Grapejuice show you what was wrong with my car and what fixed the problem? I went through 3 of them, each only about 2-3 laps in. I fixed the problem by loosening the steering plate and making sure that lock nut is on backwards. Make sense?
Grapejuice, why didnt you race last night?
locknuts on backwards help?
im thinking of making a carbon fibre steering plate..
i find the 410R has too much flex, i wonder if the 410 one has less flex?
also check this out
http://item.taobao.com/item.htm?id=4445524461
even has brass weights, and if you look closely they weigh 30g aswell.
even the body looks identicle.
LiL_JaSoN is offline
Old 10-15-2010, 06:29 AM
  #2468
rfleck's Avatar
Trader Rating: 58 (100%+)
Danger,
You state you use low profile servos, the question I was asking was if it were possible under stressed conditions that the ackerman hit the bottom of the servo. This pic, although horribly fuzzy illustrates how most servos cannot cause a bind in the steering. I don't know how much different (or low profile) your servos are. Just want to make sure you are not overlooking this as a potential issue.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-servo-pic.jpg
rfleck is offline
Old 10-15-2010, 06:33 AM
  #2469
rfleck's Avatar
Then I do not know. Perhaps I try to drive it too much like my 8th scale . . .
Ditto, this little rocket is strapped! I actually drive it much harder than my 1/8th scale
rfleck is offline
Old 10-15-2010, 07:06 AM
  #2470
I had issues in the building process with the sitting of the front and rear diffs in the bottom cases... the long outdrive side seemed the bearing didnt go far in enough to seat flush with the plastic??? any one experience this???
Old 10-15-2010, 07:11 AM
  #2471
grapejuice's Avatar
Trader Rating: 152 (100%+)
You talking about the bearing on the case side of the diff? I very lightly filled the case on mine to get the bearing on and didn't run all the shims at the start. Now that it is broke in, I have all the shims on the rear diff and just the silver one on the case side on the front diff....just have to play with it at first.
grapejuice is offline
Old 10-15-2010, 07:20 AM
  #2472
I see so it takes some playing with... Yea I fixed the rear housing last night.. what i did was shave a lil plastic off the botton ever so gently and slid the bearing as far in as close as I could do the diff gear.... Hopefully doing the same to the front will work and fix the seating issue
Old 10-15-2010, 08:35 AM
  #2473
Trader Rating: 79 (99%+)
Corey Ill PM you my #
Raul Garcia is offline
Old 10-15-2010, 08:38 AM
  #2474
dangerwr's Avatar
Originally Posted by rfleck
Danger,
Thanks for taking the time to post this! I would have to post a pic of my setup but I have looked and do not believe this issue is possible with my setup. I will look very closely tonight . . .
dangerwr is offline
Old 10-15-2010, 09:07 AM
  #2475
rfleck's Avatar
What is the brand and type of servo? I can get the size and see how that compares the Hitec 7955TG.
rfleck is offline
