Like Tree22Likes
Old 10-14-2010, 03:31 PM
  #2446
mdowney's Avatar
Trader Rating: 21 (100%+)
Originally Posted by dangerwr
I paid $30 for the Lunsford (all 6 of them) from A-Main. Asides, the blue clashes with the Durango! Always nice to support your LHS, however.
Do you have a link or part number? I haven't been able to figure out exactly which Lunsfords I need for my Rango.
mdowney is offline
Old 10-14-2010, 03:37 PM
  #2447
Briguy's Avatar
Trader Rating: 125 (100%+)
Punisher - lun1067
Super Duty - lun11067
Briguy is offline
Old 10-14-2010, 03:56 PM
  #2448
dangerwr's Avatar
Originally Posted by Briguy
Punisher - lun1067
Yup! I used the 3mm since I planned to use stock ball cups . . .
http://www.lunsfordracing.com/mm5/me...egory_Code=3MM
dangerwr is offline
Old 10-14-2010, 04:06 PM
  #2449
mdowney's Avatar
So if I want to use the RPM heavy duty cups I should get six of the super duty ones?
mdowney is offline
Old 10-14-2010, 04:12 PM
  #2450
Briguy's Avatar
No , Lunsford Super duty turnbuckles only fit their Super duty ball cups . The Punisher turnbuckles will fit RPM ball cups .
Briguy is offline
Old 10-14-2010, 05:53 PM
  #2451
dangerwr's Avatar
I tried to run the Super Duty ball cups on my T4 last year. They are sized a bit different than the RPM. And I am not talking about the fact they are 3mm vs 3.5mm in diameter. The sockets are larger--you have to run their (Lunsford Super Duty) ball studs as well. Sticking with the 3mm "Punisher" makes life a little easier.
dangerwr is offline
Old 10-14-2010, 05:56 PM
  #2452
mdowney's Avatar
OK - makes sense. Thanks guys.
mdowney is offline
Old 10-14-2010, 06:15 PM
  #2453
rfleck's Avatar
Trader Rating: 58 (100%+)
Bottom piese that attaches to servo linkage. The first day out I popped off the ball cups (I am running the stockers) and liked the idea of those popping off rather than breaking something else. Now I just break the bottom servo saver piece every few laps . . .
Damn, that sucks. Ok, went and looked at my durango. Does the ackerman ride over the back of the servo? In other words, no possibility for it to hit the bottom case of the servo under extreme comditions? Thinking outside the box here.
rfleck is offline
Old 10-14-2010, 06:47 PM
  #2454
dangerwr's Avatar
No, I have a low profile servo--it is not touching. The only thing I did differently, now that I think about it, is that I dialed in my sub-trim on the radio. Instead of physically repositioning the servo horn on the servo with it centered, I used the radio to center the servo. Otherwise I was running 100% (standard) trim to the left. Maybe I will not longer do this?
dangerwr is offline
Old 10-14-2010, 07:27 PM
  #2455
R-E-A-P-E-R-'s Avatar
I doubt that is the reason for the constant breaking. I am still trying to figure out what part it is you guys are breaking?????
R-E-A-P-E-R- is offline
Old 10-14-2010, 07:31 PM
  #2456
grapejuice's Avatar
Trader Rating: 152 (100%+)
It's the lower piece of the servo saver, the piece that the servo linkage connects to.
grapejuice is offline
Old 10-14-2010, 07:41 PM
  #2457
Briguy's Avatar
I run Lunsford Super Duty turns and ball cups on all my Losi trucks/buggies and you do no need to run their Super duty ball studs . I use Losi ball studs with no problems .
Briguy is offline
Old 10-14-2010, 08:16 PM
  #2458
rfleck's Avatar
I use subtrim all the time to make sure it is centered rather than using the actual trim, then set endpoints. That would not cause the issue.
rfleck is offline
Old 10-14-2010, 08:30 PM
  #2459
dangerwr's Avatar
Then I do not know. Perhaps I try to drive it too much like my 8th scale . . .
dangerwr is offline
Old 10-14-2010, 09:42 PM
  #2460
msconcepts's Avatar
Trader Rating: 38 (100%+)
Originally Posted by grapejuice
Why??? So he can break expensive stuff like shock shafts and axles?
hahhahaahha!!!! negative..............im just trying to get him to finish at least ONE RACE!!!!!!!!!!!!!!!!!!!!! ONE
msconcepts is offline
