Like Tree22Likes
Old 10-14-2010, 09:11 AM
  #2431
dangerwr's Avatar
Originally Posted by R-E-A-P-E-R-
He gets to keep talkin smack as long as he keeps beating us.....
He can go talk smack on Denver-R/C Man Drama with his boyfriends. I am trying to solve an issue here so I can go out and have some fun with my Durango. I am sure there is a Shoemaker Kitten thread elsewhere on R/C Talk Too Much.
dangerwr is offline
Old 10-14-2010, 10:17 AM
  #2432
mike881's Avatar
Did Grapejuice show you what was wrong with my car and what fixed the problem? I went through 3 of them, each only about 2-3 laps in. I fixed the problem by loosening the steering plate and making sure that lock nut is on backwards. Make sense?
Grapejuice, why didnt you race last night?
mike881 is offline
Old 10-14-2010, 10:23 AM
  #2433
dangerwr's Avatar
You mean making sure the steering plate is not too tight and has smooth action? Check. No binding and lock nuts are on upside down. Everything was smooth but I need to check the steering arm and make sure it was not backing off the servo horn to create stress once fully assembled.
dangerwr is offline
Old 10-14-2010, 11:13 AM
  #2434
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Hey guys, i bought a brand new rear Team Durango Swa bar set... and i know for a fact i wont be running it... i got my setup so i dont need it.
It is opened, but eerthing is there, and brand new. Never mounted...
$25 shipped/
Dlewis4 is offline
Old 10-14-2010, 01:39 PM
  #2435
grapejuice's Avatar
Trader Rating: 152 (100%+)
Originally Posted by msconcepts
HAHAHAHAHAHAHAHAAHH!!!! LEMME KNOW WHEN YOU WANT TO BUY A CAT
Why??? So he can break expensive stuff like shock shafts and axles?
grapejuice is offline
Old 10-14-2010, 01:43 PM
  #2436
dangerwr's Avatar
Yeah, and you adopt Cats anyway. No since in buying them . . .
dangerwr is offline
Old 10-14-2010, 01:55 PM
  #2437
Briguy's Avatar
Trader Rating: 125 (100%+)
Will these turnbuckles work ? http://teamassociated.com/factorytea.../details/1404/
Was thinking of using them and Losi white super duty ball cups .
Briguy is offline
Old 10-14-2010, 01:59 PM
  #2438
dangerwr's Avatar
These should work but will be a tad long. The stocks are 43mm and these are 45mm. Lunsford sells 1.75" (44.45mm) that are a little shorter. Either way you should be fine . . .
dangerwr is offline
Old 10-14-2010, 02:11 PM
  #2439
rfleck's Avatar
Trader Rating: 58 (100%+)
Guys,
So I am trying to race my Durango last night and every few laps I make I am breaking the bottom arm of the servo saver. Much like Mike881's issue last week or so. I have a stubby servo and nothing is binding. I went through 3 or 4 of them last night. I tried running them loose and then tight and then as recommended in the manual.
Anyone know what gives? I do not have too much stick time on the Durango and was bouncing off pipes a little bit but not taking hard hits. Something is definitely wrong and realize that this might be a weak point on the car but it seems really strange to break the same part in the same spot every few laps.
I am currently on the search for an aluminum one but would like to hear any suggestions as to why I might be experiencing this problem Thanks,
- Danger
Bottom piece of the servo saver (as in where it attaches to the servo linkage) or top piece where it attaches to ackerman?
Are you running stock ballcups? If so I would think they would pop off prior to breaking this piece.
rfleck is offline
  #2440
Dlewis4's Avatar
i bought the AE FT blue 1.75" turnbuckles and they work great. Wish i would have gone with the Lunsfords, but didn't want to wait.
Dlewis4 is offline
Old 10-14-2010, 02:12 PM
  #2441
rfleck's Avatar
Yeah, I have seen the outdrives being snapped on the CAT
rfleck is offline
Old 10-14-2010, 02:14 PM
  #2442
dangerwr's Avatar
Bottom piese that attaches to servo linkage. The first day out I popped off the ball cups (I am running the stockers) and liked the idea of those popping off rather than breaking something else. Now I just break the bottom servo saver piece every few laps . . .
dangerwr is offline
Old 10-14-2010, 02:17 PM
  #2443
Briguy's Avatar
I`d rather have Lunsfords also but the FT ones are sitting at the hobby shop , have to order the Lunsford . Plus the AE ones are almost half the price
Briguy is offline
Old 10-14-2010, 02:21 PM
  #2444
dangerwr's Avatar
I paid $30 for the Lunsford (all 6 of them) from A-Main. Asides, the blue clashes with the Durango! Always nice to support your LHS, however.
dangerwr is offline
Old 10-14-2010, 02:29 PM
  #2445
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
There's a good half dozen CAT SX2's that run at my local track and I've never seen a shock shaft or out drive break.
They are prone to breaking A-arms and chewed up their slippers from not checking them after they ran the car in a little. Otherwise it's been really durable.
heavyjeffd is offline
