Like Tree22Likes
Old 10-10-2010, 09:32 AM
  #2356
Konich's Avatar
Seems really close to the Azarshi body I have. The only think I don't like about it is you have to run the undertray with it. I'll be sporting it at MOHR on Wednesday.
The openings are in a better position than the stock body so I think it will cool slightly better. Also a lower profile should help out as well.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dsc05469.jpg
Konich is offline
Old 10-10-2010, 01:35 PM
  #2357
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I like the body.. just not the price...
Dlewis4 is offline
Old 10-10-2010, 04:43 PM
  #2358
anyone know where i can buy the tresory hopup parts?
LiL_JaSoN is offline
Old 10-10-2010, 05:21 PM
  #2359
mike881's Avatar
is anybody running the 410 with a tekin rs esc? I keep having problems with it getting soooo hot and starting to glitch at bout 5 minutes 30 seconds into my run!
mike881 is offline
Old 10-10-2010, 05:33 PM
  #2360
anyone have excessive slop in the front and rear hubs?
i had to add a few shims in there.
Old 10-10-2010, 05:38 PM
  #2361
Matt Howard's Avatar
I ran an RS pro until I needed it for another vehicle, I now run an LRP SXX TC spec. I wouldn't run the regular RS in a 4wd buggy unless you're only running stock. The RS just isn't up for the rigors of mod 4wd buggy.
Matt Howard is offline
Old 10-10-2010, 05:50 PM
  #2362
Briguy's Avatar
Trader Rating: 125 (100%+)
IMO it depends on the buggy . I`ve ran RS 7.5 in my XXX-4 and XX-4 for years . But those have bigger bodies and more air movement . I ordered a Pro for the 410 since such small body and doesn`t look like much air will get inside the body .
Briguy is offline
Old 10-10-2010, 05:51 PM
  #2363
Dlewis4's Avatar
I am running an RS.... sounds like you may need to look into your throttle profiles, or make sure everything is smooth. My esc never gets about 140 degrees.
Dlewis4 is offline
Old 10-10-2010, 06:39 PM
  #2364
mike881's Avatar
What throttle profile do u run? I was running linear and then the mild one below that, didn't change anything really
mike881 is offline
Old 10-10-2010, 07:25 PM
  #2365
Dlewis4's Avatar
i am running number 3, also have my mesh a little loose, and have the vents cut, and the back of the body cut
what pinion are you rnning
Dlewis4 is offline
Old 10-10-2010, 07:47 PM
  #2366
mike881's Avatar
yeah I have the vent and body cut out too. I'm running a 21t, running a 22t doesnt affect the ESC just the motor. I do think I found a problem and if not I got a few tips from the tekin thread. Thanks though
mike881 is offline
Old 10-11-2010, 05:43 AM
  #2367
rfleck's Avatar
Trader Rating: 58 (100%+)
Here's a pic of my ride.
Matt, Good looking ride!
What turnbuckles, ball cups and balls are you running?
rfleck is offline
Old 10-11-2010, 05:54 AM
  #2368
Corey Bernardo's Avatar
MY NEW DURANGO 2010 spec arrives tomorrow and gets me back in the mix of things after a 7 year hiatus.... Should I build it with the 2010 spec kit stock setup?
Corey Bernardo is offline
Old 10-11-2010, 06:12 AM
  #2369
hacker's Avatar
Trader Rating: 141 (100%+)
has anyone put just grease as substitute for the diff oils front & rear? like the good old tamiya 4wd days, molybdenum grease.
hacker is offline
Old 10-11-2010, 06:13 AM
  #2370
Lunsford turnbuckles, losi white ball cups and AE TC5 ball studs.
Springs kinda depend on your track, I went one rate softer front and rear, dark green up front, light green in the rear. Don't use the kit diff oil in the front, way too soft. Use 7k-10k in the front and anywhere from 2k-5k in the rear.
