Like Tree22Likes
Old 10-05-2010, 09:23 AM
  #2206
grapejuice's Avatar
Trader Rating: 152 (100%+)
Originally Posted by 1evo RRR Driver
Not a good idea, I saw a 1/8 buggy completely burn up Sunday when his lipo exploded, always take the battery out of your car.........
Yeah, I know I should, just in a hurry sometimes
grapejuice is offline
Old 10-05-2010, 09:38 AM
  #2207
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Matt Howard
put the rear shocks in the middle hole on the arm, having them in the outside takes away rear droop and makes the shock stiffer. I can almost guarantee you that is the issue.
i agree move the shocks in!! and make sure your rear is all the way foward..and soft springs and ride height plays a big role....your car will be glued to the ground in the rear.. no weights needed imo... and the correct tire and u should be good to go
bigBoyBigToy is offline
Old 10-05-2010, 10:05 AM
  #2208
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Thanks again guys for the info. What's everyone running for ride height? Please give me numbers as bones level can be 18-20 for my adj. Thanks......
Bman's 3XNT is offline
Old 10-05-2010, 10:26 AM
  #2209
grapejuice's Avatar
I run 19
Old 10-05-2010, 10:38 AM
  #2210
Trader Rating: 21 (100%+)
what did U means by rear arm all the way forward ??does it means shorter wheelbase?? so u put the spacer facing the back of the car on the hinge pin?? thx!!!
mccoy is offline
Old 10-05-2010, 10:42 AM
  #2211
Matt Howard's Avatar
arms and hubs all the way forward will put more weight over the rear tires, giving more rear traction.
Matt Howard is offline
Old 10-05-2010, 11:26 AM
  #2212
Originally Posted by grapejuice
I run 19
Old 10-05-2010, 02:35 PM
  #2213
littlejohn's Avatar
Sorry.. but I have to say this is just a bit of scare mongering.
Yes, I agree that it is best practice to remove any battery from the car for charging. But to say that a Lipo "just" exploded is misinformation. For one, lipos don't "explode".
I don't doubt that you saw a car lighting up whilst charging, but you're leaving out a lot of info, like how was it being charged. what was the condition of the battery etc etc.
I had a mates DEX410 light up in flames mid race. And I heard all sorts of stories after, just like what you've said and even some blaming the car. The truth was, one of the CVD pins came loose and pierced the lipo which in turn caused the pack to light up.
The truth is. If used correctly and charged correctly, it is perfectly safe to charge the packs in the car, but this doesn't mean you don't have to monitor the packs while charging. Lipos will swell way before they light up. swelling often means the cells have gone bad, it is indicative of the seals being compromised somewhere. So if enough oxygen is allowed in, the lithium will react and cause the pack to light up.
littlejohn is offline
Old 10-05-2010, 07:28 PM
  #2214
Konich's Avatar
I've never taken my lipo's out. If you charge, balance, and store properly I haven't had a problem in 2+years. Plus I'm just lazy and have deep enough pockets to repair anything
I hear there is a 4wd class tomorrow at MOHR
Konich is offline
Old 10-05-2010, 07:31 PM
  #2215
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Woot for Wednesday night racing!!!
Dlewis4 is offline
Old 10-05-2010, 07:40 PM
  #2216
dangerwr's Avatar
I am there son! I hope it stays running for the mains this time . . .
Hopefully it was just a lesson in plugging cables correctly into the Rx.
dangerwr is offline
Old 10-05-2010, 07:49 PM
  #2217
Konich's Avatar
I'm going to try a super secret tire setup......Ok you got me! BK bar fronts and Jconcepts rears. I smell A-main victory over grapejuice by 3.4 seconds
Then I will celebrate victory with some new lipos for the Rango!
Konich is offline
Old 10-05-2010, 10:07 PM
  #2218
R-E-A-P-E-R-'s Avatar
Ill be there. You may beat Grape but ill have you all laps down buy the time the buzzer goes off.
Yeah right.
R-E-A-P-E-R- is offline
Old 10-05-2010, 10:25 PM
  #2219
dangerwr's Avatar
Rango time.
dangerwr is offline
Old 10-05-2010, 10:26 PM
  #2220
grapejuice's Avatar
Ha!! Bring it
