Like Tree22Likes
Old 10-04-2010, 06:30 PM
  #2191
RETRO R/C's Avatar
Trader Rating: 57 (100%+)
I might be a bit biased, however I can highly recommend the VENOM batteries and speed controls. Like most people I thought of Venom as more budget brand, however in the last 12 to 18 months their race products are every bit as brilliant as brands costing twice as much.
As you may know - Venom uses the same manufacturer as Speed Passion and Hobbywing etc for their speed controls. I have NEVER used a smoother speed control - and I own a Tekin and have used LRP etc, the software upgrades are also free and the speed control does not require a laptop to program it. They are all good brands, however, even if money is not a concern, you can always spend the money that you save on tires, parts and other consumables, which will allow you to have more track time and practice.
The batteries are definately some the best value on the market. I was very impressed with the 5200 45C batts - gave me an absolute tonne of power and obviously heaps of duration. If I can make one suggestion - avoid using the deans plugs - such a pain in this car. Most charging systems and speed controls now come "wired" for the Corally type tube connectors.
Thought I might throw up a few pics of mine after final prep for a championship here in Australia...........might keep you going before yours arrives
As an aside, you will note that I am using the Tresrey "Gainbull" body. Heat was one of the intial concerns with the car, these shells give allot more room for heat-sinks and fans etc. I also have a new body ready to paint by "BUGLE BOY" bodies here in Australia. Has the same basic style as the original Durango shell - but re-engineered for more room. Will try and get some pics of it soon - absolutely awesome looking shell!
This DEX410 is allot like the Associated B4(or B4.1) in that once you have the one basic set up - you change it very little from there - only minor tweaks here and there are generally required.
Cheers
Darryn
RETRO R/C is offline
  #2192
Matt Howard's Avatar
Originally Posted by Bman's 3XNT
Just the side plates. I am going to run 2k this week to see if it helps.
Where are your rear hubs and arms mounted? Shortening the wheelbase will increase rear traction, especially onpower.
Matt Howard is offline
Old 10-04-2010, 06:36 PM
  #2193
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Everything is forward. Longest rear camber link in #2, bottom of rear shocks outside hole and run -2/4 for rear anti squat. Next I am going to try the 1 deg. hubs. Also rear light green springs and 30 wt drilled pistons to #55. Thanks for any more help....
Bman's 3XNT is offline
Old 10-04-2010, 06:38 PM
  #2194
Everything is forward. Longest rear camber link in #2, bottom of rear shocks outside hole and run -2/4 for rear anti squat. Next I am going to try the 1 deg. hubs. Also light green springs and 30 wt drilled pistons to #55Thanks for any more help....
put the rear shocks in the middle hole on the arm, having them in the outside takes away rear droop and makes the shock stiffer. I can almost guarantee you that is the issue.
Old 10-04-2010, 06:48 PM
  #2195
RETRO R/C's Avatar
I have the weight set and have tried all the configurations. For me personally thew car is allot more forgiving to drive running the skid plate weight at the rear. It also has the added benefit of not getting destroyed like the plastic one does when the car catches on the track. Weight is less of an issue these days, and to be honest I was allot happier with the car when the weight was in the back.
Cheers
Darryn
Old 10-04-2010, 06:52 PM
  #2196
dangerwr's Avatar
I'm going to have to respectfully disagree. Every car I've driven, this one included, gains rear traction by lightening the rear diff action. Obviously if you go too light you'll diff out but anything around 2k-3k in the rear should be fine if your looking for more rear traction.
This is what I thought at first as well. Lightening up the diff action will definitely get everything moving faster. I am not sure this is really what you want. What I am thinking is that a lighter fluid could start to spin the outside too fast. I am not sure what too thin is in this car yet but if the balance--or the rate at which the outside catches up with the inside--is off then you will ultimately compromise traction because your back end comes loose.
dangerwr is offline
Old 10-04-2010, 10:54 PM
  #2197
MaTt 93's Avatar
Cheers
Darryn
Is that the body Harlow was using at the states titles? Also have you tried jarreds setup? I'm thinking of going down in diff oils because on every other setup i've seen there useing lighter diff oil
MaTt 93 is offline
Old 10-04-2010, 11:40 PM
  #2198
RETRO R/C's Avatar
Yes - the body was a "Bugle Boy" shell - an early version of what they are now producing. Great looking shell.
I think our conditions in NSW can be quite a bit different to elswhere around the globe - with the exception of perhaps ST Ives when it is prepped like the titles. I have run the heavier oils because when I first tried the car with 7k in the front and 2k in the rear it was very "nervous". I still have relatively light oil in the rear. The other factor for my diffs is that I am using the Kyosho orings to seal the diffs instead of the standard kit "X-rings" - that slows the action down somewhat.
Each track is going to be different - and everyone drives differently. I think Hupo's set up is a really good start, one which I based my set up on.
Cheers
Darryn
Old 10-04-2010, 11:44 PM
  #2199
Trader Rating: 104 (100%+)
Anyone that wants to sell, let me know, none are out there now.
Ostach24 is offline
Old 10-05-2010, 12:21 AM
  #2200
WHAT WOULD BE A GOOD STARTING SET UP FOR A lOAMY LOOSE SURFACE WITH LOTS OF RUTS.
MY LOCAL TRACK HERE IN NEW ZEALAND (COUNTIES) HAS ASURFACE THAT BREAKS UP EASILY. THE TYRES WE NORMALLY RUN ARE LOSI STEP PINS OR J CONCEPTS GOOSEBUMPS.
ANY HELP APPRECIATED
kiwi79a is offline
Old 10-05-2010, 07:22 AM
  #2201
grapejuice's Avatar
Trader Rating: 152 (100%+)
Go on petitrc.com, they have a set-up sheet section, you should be able to find one there...I posted a link a few pages back.
grapejuice is offline
Old 10-05-2010, 07:28 AM
  #2202
R-E-A-P-E-R-'s Avatar
OK, I have never run a 7.4v saddle pack before. Can I charge them individually or do I have to charge them in series?
R-E-A-P-E-R- is offline
Old 10-05-2010, 07:43 AM
  #2203
grapejuice's Avatar
Series, don't even pull mine out of my car most of the time.
Old 10-05-2010, 07:55 AM
  #2204
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Yup. In Series...
Dlewis4 is offline
Old 10-05-2010, 08:02 AM
  #2205
1evo RRR Driver's Avatar
Not a good idea, I saw a 1/8 buggy completely burn up Sunday when his lipo exploded, always take the battery out of your car.........
1evo RRR Driver is offline
