Like Tree22Likes
Old 10-04-2010, 11:28 AM
  #2161
Corey Bernardo's Avatar
Well guys I just ordered the Durango 410pro 2010edition today, I am getting back into the hobby and from research and what people are telling me this is the car of cars to have in the 4wd buggy class.. I have been in the hobby for years an was a factory driver for a handful of companies back 5-6 years ago.
I am here to ask questions for once as a non factory driver and to get help from you Durango guys on this car... I for once am on the other end of the questions, and asking questions lol... I used to run for novak, xray, trinity, parma, and hope to get my skillz dusted off after 8 years away...
how should I build the car any inside team tips I should know about?
How is the kits stock setup?
what color wheels does the 2010pro edition come with?
I have it outfitted with a Airtronics 150oz of torque .10transit time servo
5.5 Orion Vector Pro
Orion CarbonMolecular 4500 45c lipo
LRP SXX TCspec V. 2 ESC
Airtronics M11x radio
Corey Bernardo is offline
Old 10-04-2010, 11:38 AM
  #2162
grapejuice's Avatar
Trader Rating: 153 (100%+)
Get on the Durango web site, there are a few building tips on there: http://www.team-durango.com/blog/?cat=3
Also on the Durango web site you can find set-up sheets, as well as on petitrc, never ran the stock box set-up but the 2010 spec does come with diff oils that are a good starting place, what type of track will you be running on?
Kit wheels are yellow.
grapejuice is offline
Old 10-04-2010, 12:02 PM
  #2163
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
What gives more on power traction in back? -2/2 or -2/4. I run -2/4 because it adds some more kickup correct? Looking for a little more on power traction. Also will a shorter or longer rear link help? I run it longer now to help traction in the the corners. Is this correct or do I have it opposite? Thanks guys....
Bman's 3XNT is offline
Old 10-04-2010, 12:07 PM
  #2164
Dlewis4's Avatar
Trader Rating: 148 (100%+)
To the guy who just bought the 2010 spec....
soften the car up right away...
go 10-3 or 7-3 in the diffs, light green springs in front, dark green in the rear, 35/30 shock oil, 3 hole pistons all around. That will be a good starting point, especially if you are running on high bite tracks.
B-Man, a shorter rear link will let the rear end come around more, I would try sticking with the long link and getting the 1* rear hubs... best of both worlds
Dlewis4 is offline
Old 10-04-2010, 12:15 PM
  #2165
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
also check out the oople review!! its really helpful!! u will love this car!!! I prolly shouldnt have gotten rid of mine but deals were made that i couldnt pass up!... also !Ken shu posted a couple of pages back some indoor high traction set ups! his car is so Dialed and he is loving it!! he is the current Stock region 8 roar buggy champ and went from the b44 last year and is not looking back!!!
bigBoyBigToy is offline
Old 10-04-2010, 12:44 PM
  #2166
awesome thanks guys!!!
what should I put in the front and rear diffs for oil? 5000 all around or ?? less in front for more steering.. the track will be high bite indoor.. Clays is hard as a rock, and people use BK bars
Old 10-04-2010, 01:02 PM
  #2167
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Your front will almost always be heavier than the rear.
10/5 is a good starting point, but some of the team drivers go even higher, 12k and 15k.
t0p_sh0tta is offline
Old 10-04-2010, 01:05 PM
  #2168
grapejuice's Avatar
No, heavier in the front, car has a lot of steering as it is, start with 10k in the front and 3-5k in the rear.
Don't know what size track you will be running on but may want to re-think that 5.5, I run a 7.5 LRP and that thing MOVES!!! I can pass B44 on our short straight during races, ~75' long. 5.5 is probably a bit much
Old 10-04-2010, 04:05 PM
  #2169
RETRO R/C's Avatar
Trader Rating: 57 (100%+)
As mentioned previously by others, the car certainly is a performer. You have made a good decision.
Definately softening up the suspension makes this car more forgiving. I have posted my latest set up (not on the Durango site yet) here for you to go through. It is for for high traction - short or long track, it should not matter. It is similar to Hupo Hongil's set set up used in the US earlier this year. It is a bit more forgiving.
As for motor choice - I personally would not recommend a 5.5. As suggested, a 7.5 is more than enough, as this car accelerates like no other at this time. A 9.5 feels like a 7.5 in this car (from personal experience) as far as acceleration goes. I have seen the car run with these wild motors and whilst spectacular, it makes the car crazy fast and balloons the tires on the straights - all a bit to much.
For diff oils - I generally run 20K in the front and vary it in the rear depending on the steering characteristics I want. I use the 20K as it seems to keep the car nice and stable in the front end and takes away some of the "steery" feeling of the car.
Cheers - and again - GREAT choice of ride.
Cheers
Darryn
RETRO R/C is offline
Old 10-04-2010, 04:17 PM
  #2170
WoW thanks a lot budd, I totally appreciate the help! I was actually going to opt for the Orion 7.5 Vector motor, cuz I figured it would react like a 7x2 brushed motor in a 4wd that I remembered for way back when lol... but my LHS owner said I should get the 5.5 because the track is huge and blue grooves so the power can really be used...... He runs a 4.5 Vector! ahah
Old 10-04-2010, 04:20 PM
  #2171
whtpny4's Avatar
Trader Rating: 15 (100%+)
i am going to be giving the durango a try very soon, cars look very impressive!
whtpny4 is offline
Old 10-04-2010, 04:23 PM
  #2172
Konich's Avatar
Who is making 23.5mm lipos still? I need to pick up another set, but I need the positive in the back, negative in the front on the right side of the car.
Konich is offline
Old 10-04-2010, 04:26 PM
  #2173
Konich- venom i believe
Old 10-04-2010, 04:32 PM
  #2174
Konich's Avatar
Thanks, not much out there with that option. I did find them though
http://www3.towerhobbies.com/cgi-bin...&I=LXYYZ8&P=SM
Right terminal layout and 23.4 in height.
Konich is offline
Old 10-04-2010, 04:44 PM
  #2175
dangerwr's Avatar
Get you some! You gonna race Wednesday? I doubt if I will make it since my intermittent GF wants to hang out . . .
dangerwr is offline
