Like Tree22Likes
Old 10-03-2010, 02:55 PM
  #2116
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Originally Posted by Briguy
I wish there were . They all are sold .
Just bought one off ebay w/free shipping .
Awesome. You will LOVE it. Just get the metal front brace and you will be inbusiness!
Dlewis4 is offline
Old 10-03-2010, 02:58 PM
  #2117
Briguy's Avatar
Trader Rating: 125 (100%+)
Already have the brace on my list ! I race a xx-4 and can`t wait to run the Rango !
Briguy is offline
Old 10-03-2010, 03:08 PM
  #2118
Matt Howard's Avatar
you'll like the durango. Of all the 4wd buggies I've driven my Durango finally knocked the XX4 off the top of my all time favorite 4wd's.
Matt Howard is offline
Old 10-03-2010, 03:14 PM
  #2119
Briguy's Avatar
Anything else I should get for the 410r ? I Have f/f and f/r aluminum pivots , front and rear shock springs on my list so far . Running on high bite hard packed clay so really don`t think I need the shock and axle boots .
Briguy is offline
Old 10-03-2010, 03:21 PM
  #2120
Trader Rating: 49 (100%+)
I put shock shaft covers and rear CVD boots on the rear. My rear CVDs are looking new.
I also have a chassis weight setup ($40 new, wtf?) and I switched to titanium turnbuckles. The stock 'rango rodends kept popping off the balls.
Loctite your servo saver adjustment. Mine kept backing up allowing the saver to loosen and slam and break.
aradaiel is offline
Old 10-03-2010, 03:25 PM
  #2121
Dlewis4's Avatar
Switch to lime green springs in the front with 3 hole pistons, and dark green in rear with 3 hole, 35/30 weight... dialed.
The shock boots and axle boots just add to the durability/lack of need to rebuild all the time.
Dlewis4 is offline
Old 10-03-2010, 03:26 PM
  #2122
Briguy's Avatar
What brand turnbuckles did you get ? Looks like Lunsford doesn`t have them for the buggy . how much does the chassis balancing weight weigh ?
Briguy is offline
Old 10-03-2010, 03:28 PM
  #2123
makaluch's Avatar
Trader Rating: 36 (100%+)
Originally Posted by aradaiel
...The stock 'rango rodends kept popping off the balls...
Food for thought. On my old Losi stuff...
I use to use diff thrust bearing washers to trap the rod end onto the ball. Use the concave side facing the shock end. I don't know if it'll work on the Rango but it's an idea.
makaluch is offline
Old 10-03-2010, 03:32 PM
  #2124
Dlewis4's Avatar
Just buy some 1.75" lunsford or AE FT turunbuckles... i bought some AE ones and it was 27 bux for all 6.
I think Lunsford's are just a few bux more for the whole set.
Dlewis4 is offline
Old 10-03-2010, 03:36 PM
  #2125
Briguy's Avatar
All the turnbuckles are the same length on this buggy ? Dang , that makes things easier .
Any popular parts that break ?
Briguy is offline
Old 10-03-2010, 04:00 PM
  #2126
Dlewis4's Avatar
I would get a spare spur, a set of front arms, and plastic arm mounts if you are using those....
Dlewis4 is offline
Old 10-03-2010, 04:46 PM
  #2127
ABBOTT's Avatar
Anybody broke on of these arms yet?
ABBOTT is offline
Old 10-03-2010, 04:51 PM
  #2128
Dlewis4's Avatar
I havent... the only thing i broke was the rear gearbox supports because an 8th scale buggy creamed the rear end of my buggy...
Other than that... nothing has broke.
Dlewis4 is offline
Old 10-03-2010, 05:15 PM
  #2129
dangerwr's Avatar
Default Awesomeness!
I finally got to race this buggy over the weekend. I did not place anywhere mentionable because I was driving really hard to see where were the limits. The car is so much more capable than I am right now! This is one fun car to drive--maybe even more fun than my 8th scale!
I did have both front steering ball cups pop off at the same time! I will not be in a hurry to change them out just yet because it looked like they saved me from actually breaking something. The Orion 4600 packs were choice and the Novak Kinetic and Ballistic 8.5 is a great combo for this buggy. Ran cool through the 6-min quals and practice.
My speedo died by the end of the night and am not sure what that is all about. I wanted to ask how you guys are mounting yours to the chassis. Someone recommended I double up on the double-sided tape. I do not think this would hurt but is it enough and will it hold together cohesively?
dangerwr is offline
Old 10-03-2010, 05:24 PM
  #2130
Dlewis4's Avatar
I have mount mounted to a carbon plate that was made by a guy in England... i am thinking about going straight to the chassis though.
I know this car puts a little more strain on motor and ESC though due to no slip in the drive train...
but shouldnt have been enough to kill your speedo
Dlewis4 is offline
