Like Tree22Likes
Old 09-29-2010, 10:01 PM
  #2026
Originally Posted by dangerwr
You got it! You will also need the pivot balls that go with these.
http://www.amainhobbies.com/product_...vot-Ball-Set-8
you need both the inner and outter brace?
what are the balls for?
LiL_JaSoN is offline
Old 09-30-2010, 07:17 AM
  #2027
grapejuice's Avatar
Trader Rating: 152 (100%+)
At minimum the outer brace...balls support the hinge pin in the brace, must have those to run the aluminum braces.
grapejuice is offline
Old 09-30-2010, 07:30 AM
  #2028
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Grapejuice is your setup posted anywhere? I've check a few pages back, but I can't find it.
t0p_sh0tta is offline
Old 09-30-2010, 07:59 AM
  #2029
grapejuice's Avatar
I don't, can't get the file small enough to post it on here. PM me your email and I can send it there.
Old 09-30-2010, 09:39 AM
  #2030
dangerwr's Avatar
Default CVD's binding?
Guys,
I have noticed that my front & rear CVDs bind a little bit. Not the center CVDs connected to the slipper but the ones that actually drive the wheels. I am under the impression that this is because the car is not broken in but does not seem right to me. I am not sure what else would cause this . . .
Is it possible that if I did not get the grub screw on the flat spot of the drive pin the CVD would bind? If I turn the spur by hand you can see the front & rear A-arms lift and then drop through and entire revolution of the spur. Talk about el weirdo!
Any ideas?!? Thanks,
- Danger
dangerwr is offline
Old 09-30-2010, 11:42 AM
  #2031
Guys,
- Danger
The reason for this is too much locktite floating around in the CVD - I had the same problem and had to rebuild the CVDs... Donīt try to break them in - you will kill your bearings ...
TopAs is offline
Old 09-30-2010, 11:47 AM
  #2032
t0p_sh0tta's Avatar
Thanks Grapejuice. Very close to the changes that I have in mind.
Old 09-30-2010, 12:06 PM
  #2033
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
Guys,
- Danger
and yes it can also be the grub screw! not on the flat spot..make sure you redo them and get it right so there really free u dont want any binding with this car keep it smooth and rolling free...
bigBoyBigToy is offline
Old 09-30-2010, 02:17 PM
  #2034
rfleck's Avatar
Trader Rating: 58 (100%+)
Guys,
- Danger
I have had this happen on previous builds because of too much lock tite as well on the cvd.
rfleck is offline
Old 09-30-2010, 02:45 PM
  #2035
littlejohn's Avatar
Guys,
- Danger
like the others have said.. too much threadlock. pull them apart, clean everything and rebuild them. I used grease during the assembly of mine and run them with a tiny bit of bicycle wax chain lube.
to make sure you've got it right, rotate the cvd at the most extreme angle to check for binding.
I also run my diff / pinion loose as well.
littlejohn is offline
Old 09-30-2010, 03:36 PM
  #2036
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I think it is a great looking car, but I don't like the how open the drivetrain is.
BuggyKing is offline
Old 09-30-2010, 04:12 PM
  #2037
Why ? It's nothing different to 1/8 nitro and again it's not belt driven so why you would need to do it differently
Poinas2 is offline
Old 09-30-2010, 04:22 PM
  #2038
BuggyKing's Avatar
I just remember a buddy of mine that had the Tamiya 501x with the open drivetrain and things getting stuck in the pullies.
Old 09-30-2010, 05:24 PM
  #2039
Konich's Avatar
Guys,
- Danger
Just buy Grapejuice's durango and trade him yours. Thats what I did
Konich is offline
Old 09-30-2010, 06:17 PM
  #2040
grapejuice's Avatar
But belt drive has a lot more going on, plus with how the car is set-up makes it sooooo easy to work on being a 4wd...fours screws each and out the diffs come
