Like Tree22Likes
Old 09-27-2010, 11:10 AM
  #1936
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Loosening the slipper helps a lot too. Durango's setting must be set for astroturf or something, because the only time I noticed it slipping was on concrete.
edit:
I'm going to be taking apart my CVDs when I install the dust boots, what's the best way to remove old threadlock?
t0p_sh0tta is offline
Old 09-27-2010, 02:15 PM
  #1937
makaluch's Avatar
Trader Rating: 36 (100%+)
Just sit the tip of your soldering iron on the grub for 5 seconds to soften it up. Drop of nail polish remover or paint stripper removes it but don't get it on your other plastics. (methylene chloride)
makaluch is offline
Old 09-27-2010, 03:16 PM
  #1938
R-E-A-P-E-R-'s Avatar
Originally Posted by dangerwr
Well, you can try the drill and sand paper trick or ask Justin if they sell the new one and if he knows if it fits.
What is the smallest receiver Spektrum sells and the smallest ESC Tekin has ever made! You might want to get both of those. I dunno really because I run Futaba and Novak. I lucked out getting those things in there. They would not have fit if I did not find that Timmy Tweaks carbon radio tray.
These cars are tight but there are not that tight. Your RS ESC is the size of a Quarter. So you'll have room for just about rx you could find. The RS isnt some oversized Novak JANK thing like Danger likes.....
R-E-A-P-E-R- is offline
Old 09-27-2010, 03:50 PM
  #1939
Company Representative
JoeNolasco's Avatar
Originally Posted by rfleck
What is stock toe in? 3deg?
You know, that is a good question. I will check this out on my car and report back. I couldn't find this info in the manual or on the setup sheets, but comparing my 410R to a 410 2009 car here at the shop the 410R appears to have 0 or 1 deg toe WITH the 1 deg rear hubs.
The 2009 410 looks like 3 deg. It looks drastically different. I need to find out what the deal is.
FYI-the arm mounts do not change the toe on this car. The arm mounts only change anti-squat and roll center.
JoeNolasco is offline
Old 09-27-2010, 04:40 PM
  #1940
mike881's Avatar
reap I pm'd you on denver rc. How much do you charge to paint a body
mike881 is offline
Old 09-27-2010, 05:33 PM
  #1941
Matt Howard's Avatar
Just measured my 410R and I've got 3 deg each side with the stock hubs.
Matt Howard is offline
Old 09-27-2010, 05:49 PM
  #1942
mike881's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXYKT4&P=7
Just ordered these, anybody have any reviews on them?
mike881 is offline
Old 09-27-2010, 05:59 PM
  #1943
I have had good luck with Venom packs in the past. I just ordered a
TrakPower Dark 4650mAh 35C
Old 09-27-2010, 06:11 PM
  #1944
Those look like good packs for the money.
Old 09-27-2010, 06:19 PM
  #1945
rfleck's Avatar
Trader Rating: 58 (100%+)
Yep, I run these as well. They are pretty light. I really like them. Plenty of punch for LRP 7.5. I have had them since April and they have held up well.
rfleck is offline
Old 09-27-2010, 07:11 PM
  #1946
mike881's Avatar
yeah I am hoping they have enough punch, I will be runnin the 7.5 redline. I'm sure its going to be enough!
How much run time do you get, 10-15 min?
mike881 is offline
Old 09-27-2010, 07:13 PM
  #1947
Trader Rating: 49 (100%+)
I'm running a venom 4500mah 50c pack in the 'rango.
I use a 5000mah 50c in my t4 and a 5000mah 40c in my B4. I've had zero issues with any of the venom stuff.
Anyone have issues with the servo saver loosening itself? I had to locktite mine to keep them from loosening and breaking.
aradaiel is offline
Old 09-27-2010, 07:44 PM
  #1948
FWIW I was running 3 practice laps (22 seconds each) and a 6 minute race and putting around 1800 mah back into my packs. I was running a 7.5 as well.
Old 09-27-2010, 08:19 PM
  #1949
Dlewis4's Avatar
Trader Rating: 148 (100%+)
It says in the isntructions to locktite it
Dlewis4 is offline
Old 09-27-2010, 08:25 PM
  #1950
Trader Rating: 104 (100%+)
I have been reading quite a bit about this and is there a major difference between the r and the regular model? Is it worth buying it for those who have it? Anyone wish they got the r instead or vice versa?
Ostach24 is offline
