Like Tree22Likes
Old 09-26-2010, 06:51 PM
  #1906
majorsmx521's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Matt Howard
I've got the hubs but haven't tried them yet, should give more rear traction.
do you think lateral traction?or forward traction?
seems to have great straight line traction just slides a little more than i would like
for the record i am splitting hairs this buggy is awesome!
nct race today and i am still glowing love the whole package
majorsmx521 is offline
Old 09-26-2010, 07:46 PM
  #1907
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
I've got the hubs in the mail. Are you guys running the rear weights? If so, which ones? I'm running box stock at the moment and the rear is pretty loose on a medium traction clay track.
I've got 10k/5k in the diffs, but haven't had a chance to play with shock oils as of yet. Can't wait until Friday to get this thing dialed in a bit, but it's amazing.
t0p_sh0tta is offline
Old 09-26-2010, 08:31 PM
  #1908
mike881's Avatar
Originally Posted by R-E-A-P-E-R-
I would use a dremel
Mount the shaft in a drill chuck carefully and get some 320 wet sand paper. That will get you the best finish without a lathe.
Which I have in my garage if you would like me to turn it down for you.
so what was the verdict on this? I am in the process of building my kit, let me know before I screw something up!
mike881 is offline
Old 09-26-2010, 08:54 PM
  #1909
Konich's Avatar
Is anyone noticing the 410 seems to always need new tires compared to the 410R?
I wonder if the chasis flex helps as the tires scub off and provide a more consistant feel?
It seems that either my setup or driving style necessitates new rubber
Konich is offline
Old 09-26-2010, 09:01 PM
  #1910
dangerwr's Avatar
Check to see if it fits through the bearings first. The word on the street is if they do not you can buy the replacement for $2 and somehow that fits. I just used a lathe and basically took the coating off the one that came in the box.
Are you building right now? I will hopefully have mine done by next weekend. I already have too many wires in mine. Grapejuice has a clean setup. What electronics are you gonna run?
dangerwr is offline
Old 09-26-2010, 09:16 PM
  #1911
mike881's Avatar
I'm hoping on having it ready to race next wednesday. I'm gonna be runnin a Tekin RS esc, 7.5 redline motor, JR 9100s servo.
And if it doesnt fit, u know if mhor sells it? Ill keep you updated
mike881 is offline
Old 09-26-2010, 09:17 PM
  #1912
air8's Avatar
Here's the info for the Hutch race. http://www.rctech.net/forum/kansas-m...lyer-info.html
I hope to have my Durango next weekend. I'm anxious to do some testing on the super bite clay.
air8 is offline
Old 09-26-2010, 09:22 PM
  #1913
dangerwr's Avatar
The RS is pretty small right? I know you will need a small receiver! I am wondering if I should have got a 7.5? I will not make it this Wednesday but definitely the next . . .
dangerwr is offline
Old 09-26-2010, 09:27 PM
  #1914
mike881's Avatar
nope the bearing isn't fitting...
I have a spektrum 3000 reciever.... how small of a receiver do I need
And we'll see, you're 8.5 still might kick my rear end around the track
mike881 is offline
Old 09-26-2010, 09:32 PM
  #1915
dangerwr's Avatar
Well, you can try the drill and sand paper trick or ask Justin if they sell the new one and if he knows if it fits.
What is the smallest receiver Spektrum sells and the smallest ESC Tekin has ever made! You might want to get both of those. I dunno really because I run Futaba and Novak. I lucked out getting those things in there. They would not have fit if I did not find that Timmy Tweaks carbon radio tray.
dangerwr is offline
Old 09-26-2010, 09:38 PM
  #1916
air8's Avatar
What Novak speedo did you use?
air8 is offline
Old 09-26-2010, 09:39 PM
  #1917
mike881's Avatar
ok well I'm glad I read up on that.
What else should I know now (like that bearing that wont fit) about building this?
mike881 is offline
Old 09-26-2010, 09:41 PM
  #1918
dangerwr's Avatar
Do you run the plastic chassis braces? I would. I am not surprised if one could burn through a set of tires in a week with this car. Are you spinning a lot? What motor do you run?
dangerwr is offline
Old 09-26-2010, 09:45 PM
  #1919
dangerwr's Avatar
That is it and that is all. Have you built the diffs yet? Be sure to follow the Oople article while you build. Also have the Team-Durango site up as well. Look at those things they have listed "In the Pits." Take your time with the diffs. Use plenty of Green Slime and be slow putting on the main gears to the out drives.
dangerwr is offline
Old 09-26-2010, 09:51 PM
  #1920
mike881's Avatar
sounds good, I always build my diffs with lots of grease! I already broke the plastic thing that goes over the CVD to protect the pin from coming out....It's where the CVD and driveshaft meet and theres a pin in there, does that make sense I don't think its a big deal... but I still broke it. How did you guys get those on there, it was freakin hard for the first one which luckily didnt break
mike881 is offline
