Like Tree22Likes
Old 06-09-2016, 09:23 PM
  #18316
M3Man03's Avatar
I have a v4 and I can't seem to figure out how to change the rear toe. The hanger that came with the kit was a "-2" and the inserts at the rear just seem to adjust kickup and not toe. There's also no inserts at the hubs. I can't seem to find any other hangers for it either. Ideas?
M3Man03 is offline
Old 06-09-2016, 09:29 PM
  #18317
MikeR's Avatar
Trader Rating: 15 (100%+)
http://www.exotekracing.com/search.p...dex410&x=0&y=0
MikeR is offline
Old 06-09-2016, 10:41 PM
  #18318
M3Man03's Avatar
Yes, I've seen those... but what about if I wanted to DECREASE the rear toe? Right now it's like -3 or something and I want it like -2 or -1.5.
M3Man03 is offline
Old 06-09-2016, 10:43 PM
  #18319
ekt
ekt's Avatar
Outside of using the different RR blocks Mike linked, you can use different hubs for +/-1 toe, part no. TD330007
ekt is offline
Old 06-29-2016, 12:33 PM
  #18320
the incubus's Avatar
Trader Rating: 17 (100%+)
OK gents getting ready to place an order for spares, wheels and tires but I'm finally converting to 12mm Hexes on my son's 410 and my SB401.
My question is… What 12mm hexes do I need and what wheels are the correct offset for the 410?
Thanks in advance to my Rango family!
the incubus is offline
Old 06-29-2016, 04:41 PM
  #18321
I am really torn between what i want to get next. I am looking at the xb4 2016, dex410v5 or a 2wd buggy. For now, my question below
Has anyone driven both the xb4 2016 and the dex410v5? if you have, which would you consider to be nicer kit and better value? They are basically the same price, and i dont have a local hobby shop or a local track so parts availability is not a concern and i dont have the ability to drive other cars other than what i own myself.
rekim is offline
Old 06-30-2016, 12:00 AM
  #18322
I've not driven the XB4 2016, but it's just an evolution to the 2015, utilizing all the optional parts from he get. The 410v5 is a vastly more radical evolution from he previous model and it has a center gear diff WITH a slipper, which I am extremely curious to try. Since I detest the 100% On/Off of a center Gear Diff, and have tones of experience and great results int he way of drivability running a center slipper, having them both in combination is very enticing to me.
Old 07-01-2016, 08:47 AM
  #18323
Sorry if this is been asked, I searched and searched but for some reason couldn't find an answer. The original dex410, is it a lost cause or will the parts off the new ones work. I have a chance to buy one and worried about parts support
racin707 is offline
Old 09-18-2016, 02:25 PM
  #18324
platgof's Avatar
I bought a bunch of used ones, and when the local track shut down, I bought there stock. So I am good to go for awhile. I need to know what aluminum servo horn works best for this, 25 tooth Savox?
platgof is offline
Old 09-18-2016, 02:56 PM
  #18325
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
if its similar to the desc410 I got here, looks like guys cut the servo horns too for better fit as well.
Cain is offline
Old 09-19-2016, 05:43 PM
  #18326
Pittster's Avatar
I use the TD servo horn on a Savox 1258TG work well just rubs front shaft but no binding had it there for 3 years no issues.
http://www.team-durango.com/part-inf...artNo=TD340064
Pittster is offline
Old 09-19-2016, 06:33 PM
  #18327
JRSlash's Avatar
i am using the TLR 22-4 aluminum servo horn and is the right size without clearance issues.
https://www.amainhobbies.com/team-losi-racing-224-aluminum-servo-horn-25tfutaba-orion-savox-protek-tlr334012/p268680
JRSlash is offline
Old 09-28-2016, 04:11 PM
  #18328
platgof's Avatar
I bought some cheap servo horns, that I had to trim to fit, but they work now. I really don't know when I will run again? This car is jinxed, because every time I try to race it something beaks. Hopefully it will hold together the next time I race.
platgof is offline
Old 10-25-2016, 06:44 AM
  #18329
Trader Rating: 16 (100%+)
When you order factory durango wheels for the dex410 v5 are they 60mm or 2.2? everywhere states they are 14mm hex but nowhere tells the diameter.
thanks
Perrydog is offline
Old 10-25-2016, 07:03 AM
  #18330
Tech Legend
Cain's Avatar
thanks
The wheels I received were the regular type 2.2 not the newer style that seems to be getting phased out.
Cain is offline
