Like Tree22Likes
Old 09-23-2010, 09:59 AM
  #1816
Matt Howard's Avatar
Originally Posted by JoeNolasco
What brand of oils in the diffs and shocks?
Losi in both
Matt Howard is offline
Old 09-23-2010, 10:07 AM
  #1817
grapejuice's Avatar
Trader Rating: 152 (100%+)
Pretty close to my set-up, shocks are a little different. Finally got to race mine last night, car was awesome!! TQ'd and won
grapejuice is offline
Old 09-23-2010, 10:26 AM
  #1818
dangerwr's Avatar
What? There was enuff wheelers to race?!? I had better get on the ball. I am moving this weekend but will see you guys the following . . .
dangerwr is offline
Old 09-23-2010, 10:37 AM
  #1819
R-E-A-P-E-R-'s Avatar
Danger how do you not have that DEX together yet. hahaha
SLACKER
R-E-A-P-E-R- is offline
Old 09-23-2010, 10:39 AM
  #1820
dangerwr's Avatar
SLACKER
Hey! Did u race? No?!? And yours is built!!! Anyway. how are things looking? I almost getting close with the build. I will need to figure out the ESC a little bit but have read it is cake.
Anyone having trouble with the stock servo horn?
dangerwr is offline
Old 09-23-2010, 11:02 AM
  #1821
I used a racer edge aluminum servo horn from the start, I never trust plastic ones unless I have to.
Old 09-23-2010, 11:14 AM
  #1822
dangerwr's Avatar
Thanks for the heads up--I have placed one in my wish list! I know people have asked about spares so let me ask once again . . .
What spares do I need? I have the aluminum FR & FF hinge braces already. Thanks everyone!
dangerwr is offline
Old 09-23-2010, 11:19 AM
  #1823
for spares I would recommend probably just some extra castor and steering blocks for the front end. Apart from the plastic suspension blocks included with the R version, every else is pretty robust.
Old 09-23-2010, 11:48 AM
  #1824
grapejuice's Avatar
We got parts on the wall at MHOR bud I've made sure to get the most necessary parts in stock and have been getting more in too!!
Old 09-23-2010, 12:12 PM
  #1825
dangerwr's Avatar
Awesome! Thanks so much for making this happen. People I told were amazed that you guys stocked the Durango and parts. I gave Jess all the credit and explained that he is just ahead of the times!
dangerwr is offline
Old 09-23-2010, 02:05 PM
  #1826
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
As of yesterday A Main had the alloy front blocks in stock. It said low stock last I checked. Of course I got my order placed, so I'll be back in action shortly!
t0p_sh0tta is offline
Old 09-23-2010, 02:08 PM
  #1827
mdowney's Avatar
Trader Rating: 21 (100%+)
Originally Posted by bigBoyBigToy
i will be running this stallion in my very Dialed Durango!! next weekend..
http://www.amainhobbies.com/product_...s-Motor-5200kV
How does that compare with an LRP X-12? I've never been clear on the differences between Orion, LRP, Tekin, SP, Novak, Castle, etc. I just stick with LRP motors because it's what I started with and they've always worked well for me. Plus I'm a big fan of German engineering (drive a 2006 M5 - man's most perfect creation, other than Adriana Lima).
I always use Kyosho diff oils. Anyone know if their weighting system is the same as Losi?
mdowney is offline
Old 09-23-2010, 03:10 PM
  #1828
X-12's run hotter than all the motors you listed, the LRP motors also cog under a heavy load and eat bearings like they are candy, but they are also a very fast motor when working right...
Shirk is offline
Old 09-23-2010, 03:36 PM
  #1829
Company Representative
JoeNolasco's Avatar
Kyosho and Losi oils--Not even on the same planet, unfortunately.
Someone actually tested all the different oils with a rheometor. It's because of this study that I asked about the oil brands. The biggest issue is that anyone can put fluid in a bottle and call it "30wt". The only true rating is CST.
Example: Losi 27.5 is the same as AE 25 but in CST both of those are 300!
http://www.twf8.ws/php/tip/shock.html
JoeNolasco is offline
Old 09-23-2010, 04:30 PM
  #1830
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Does anyone know the length of the LRP motor in mm?
Jmuck69 is offline
