Like Tree22Likes
Old 12-18-2015, 03:37 PM
  #18196
platgof's Avatar
Tower Hobbies sells the kits. Make sure to hit the area with a very hot soldering iron, to soften the Loctite so you can remove them. I stripped out a few and had to drill them out before I learned this trick.
platgof is offline
Old 12-19-2015, 10:37 AM
  #18197
SamuraiJack's Avatar
Trader Rating: 41 (100%+)
Do u mean the cvd rebuild kit? That is not what I mean. I mean pressing out and replacing dogbone and universal pins. So easy on my 8IGHT.
SamuraiJack is offline
Old 12-23-2015, 10:03 AM
  #18198
frankf's Avatar
So after trying to make my v4 work well with a shorty lipo I've ended up with a very heavy front shock/spring package compared to the rear and tuned out as much steering as possible added both brass weights to gain more rear grip but honestly it just feels unbalanced and not fun to drive, so I have decided to convert it to a v5 similar to d413 b44.3 xb4 and pretty much all other wheelers that have the motor at the rear and shorty beside it. I know a few have done this before but the ones I have seen made new wider chassis and then used an ae or xray body but I will be keeping the original chassis and body because that's what attracted me to the durango in the first place, pics to follow.....
frankf is offline
Old 12-23-2015, 12:02 PM
  #18199
Pittster's Avatar
Funny you metion that i never felt as good with a shorty. I went through the same process with mine ran shorty for over a year and it just never felt as good as it having saddles. I run a square pack now and even though its a heavy 1840g now it feels really good to drive.
Pittster is offline
Old 12-23-2015, 09:32 PM
  #18200
the incubus's Avatar
Trader Rating: 17 (100%+)
Just out of curiosity, what front blocks are your running. I've found that when a 410 is on the twitchy side it's usually down to the front blocks. The kit I believe still includes the 19 blocks. If that's what you're running I suggest you change to the 21 blocks as they REALLY make a world of difference in smoothing the car out.
As well, what are you using for weight on it. Initially I listened to the masses that you had to have both the rear skid plate and the side weights but I found that the car was too heavy. I Removed the side weights and was able to run shorties just fine. Car was as they like to say… Dialed!
I ran 32f/27R and 7K/3.5K diff oils.
One other thing I would suggest highly is a Vortex wing. It has a very large main plane and the wicker panel is just right in every regard. Excellent downforce without all the resistance you get from other wings. Balances the 410 perfectly.
the incubus is offline
Old 12-24-2015, 01:05 PM
  #18201
frankf's Avatar
Still using standard castor blocks and I was using the brass rear and brass diff cradle weights but the latter was mainly for strength, I managed to dial the twitchiness out but it just never felt planted in the rear and I didn't feel confident on the throttle. Anyway im past the point of no return and one bonus is all the space ill have up front for the electronics now.
frankf is offline
Old 12-24-2015, 05:15 PM
  #18202
frankf's Avatar
Finally done there is definitely more space for electrics, the left to right balance is very good, the battery brace doubles as a chassis brace, and best of all the standard v4 body still fits, overall very pleased with the end result. Now to remove the brass weight and reverse everything I did trying to decrease the steering in hope it would give me more rear bite (it didn't)
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-p1010377.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-p1010379.jpg
frankf is offline
Old 12-25-2015, 10:22 AM
  #18203
platgof's Avatar
Wow, that is different!! I am not sure I want to do all the work you went through. I guess it is much lighter with the shorty though. Please let us know how it handles in a race.
platgof is offline
Old 12-25-2015, 10:21 PM
  #18204
Trader Rating: 83 (100%+)
Couple of questions. Can the v4 be ran with a brick pack instead of saddles? When is the v5 coming out. Can't seem to find any mention of it
dpcardoza is offline
Old 12-26-2015, 01:47 AM
  #18205
ekt
ekt's Avatar
Square packs fit.
Haven't seen news of an official release date for the v5, but from all the info that has been released it shouldn't be too far away.
ekt is offline
Old 12-29-2015, 07:55 PM
  #18206
8ight-e's Avatar
Trader Rating: 58 (100%+)
Just a note.. looks like there are B-Type or in-line changes to the diff cases and the hoops. New kits are different... they won't even fit into the old hoops (alum) with out sanding them down.. the new hoops are also have a little more material.. may not ever need the aluminum again... A few of the other plastics are also slightly different material now.. more firm.
8ight-e is offline
Old 01-01-2016, 07:15 AM
  #18207
Default Wheels!
Guys, i tried the search but couldn't find what i wanted...
Will the B5/B44.3 rear wheels and tlr 22-4 front wheels with Exotek 12mm hex adapters make the same width as the original Durango wheels?
I think yes but has someone got some confirmation for me??
Thanks!
Egress is offline
Old 01-01-2016, 08:34 AM
  #18208
This can answer a fiew of your and our questions!
http://www.rcnews.net/2015/12/30/hob...ango-dex410v5/
micholix is offline
Old 01-01-2016, 07:06 PM
  #18209
Laker67's Avatar
Trader Rating: 69 (100%+)
Thanks!
Any of those wheels can work with the exotek hexes, if you run the tlr wheels on the front it will make the front wider. I'm not sure in mm how far the difference is, but it's noticeable. The rears I didnt really notice a difference.
Laker67 is offline
Old 01-02-2016, 08:34 AM
  #18210
Thanks mate. So if i would want the same width as per stock in the front i should buy Asso b44.3 front wheels? Is this correct?
Egress is offline
