Like Tree22Likes
Old 10-21-2015, 11:23 AM
  #18181
Originally Posted by MikeR
Hi All!
I plan to make a few new front end parts for the DEX410 and wanted to possibly survey your opinions on the steering rack-
If we make an all aluminum steering rack set, should it be with the servo saver or without? 'Without' the servo saver will help reduce the cost, complexity and weight and is what I'm more leaning towards since most wheelers do not have servo savers currently (if needed a plastic servo horn acts as a servo saver)... but I better check with you guys before proceeding!
Servo saver- yeah or nay?
Hello MikeR,
Did you allready decide, witch version you want to produce for the steering rack, and/or witch other parts could we see in the future from exotek?
micholix is offline
Old 10-21-2015, 12:09 PM
  #18182
the incubus's Avatar
Trader Rating: 17 (100%+)
Make it so that it uses the original servo saver so it won't cost more.
Additionally something this buggy could use are new front arms that make it so the bottoms of the front shocks are captured and therefore protected. Outside of that the 410 is pretty well refined.
the incubus is offline
Old 10-21-2015, 02:12 PM
  #18183
Originally Posted by TAMAK
Old photo of my DEX410 W/GTB2 (same size as a Havoc Pro I believe)...
Attachment 1027993
Attachment 1027996
Hey man was it a pain in the ass to solder new wires on the gtb2?
Bentlr22 is offline
Old 10-21-2015, 03:42 PM
  #18184
Soldering is soldering.
If you take the time to plan it out and KNOW how to solder properly, it should be easy peazy.
I've soldered several types of ESC's over the years and they always look like factory. You just need to know how to pre-tin your exposed leads (you want just the minimum amount of wire exposed - usually just over 1/16") and use a sparing amount flux on the contact point so it build heat quickly and efficiently to provide the perfect solder joint.
Old 10-25-2015, 03:54 PM
  #18185
platgof's Avatar
The Dex410 is ready to go again. I am running a Tekin 7.5 and RS Pro in it. I just need to get the tires for it, thanks Dino D.
platgof is offline
Old 10-28-2015, 04:07 AM
  #18186
I just had a look at the TD web site and i saw, that also the DEX410v4 will be no longer manufactured!
So the release of the V5 is close... ;o)
micholix is offline
Old 11-03-2015, 03:14 PM
  #18187
platgof's Avatar
I finally finished my Dex410 for the race sat. I had a lot of issues to fix, space being one of them, this thing is tight.
platgof is offline
Old 11-07-2015, 06:58 PM
  #18188
platgof's Avatar
The car handled great, but electrical issues kicked my butt all night. I was doing great, and then a motor wire came loose, ughh! Then in the main, second lap, another motor wire comes loose, it happens.
platgof is offline
Old 11-18-2015, 11:54 AM
  #18189
Laker67's Avatar
Trader Rating: 69 (100%+)
That's a bumber man, nothing worse then small issues becoming big ones!
Laker67 is offline
Old 11-18-2015, 11:57 AM
  #18190
Laker67's Avatar
If anyone is interested I'll be doing a set up sheet for the V4 for high bite clay tonight. I'll post it on Team Durango - RC Cars page on facebook. I've tried to post them on here but the files are to big. I had some great results with my car last weekend at our state champs race. I have to say, the V5 is going to have to be an amazing car for me to completely retire the V4.
Laker67 is offline
Old 12-10-2015, 08:43 PM
  #18191
Volition's Avatar
Hi Guys,
Need a favour - I race 4wd stock 17.5t in Australia its a reasonably popular class here. So weight is important. To compare the 4wd's on the market;
Could someone weigh there car - ideally as close to stock as possible with electronics and a shorty and body on.
Would be much appreciated? There is no prize for anyone who can post a reply the fastest. Thanks.
Volition is offline
Old 12-10-2015, 08:47 PM
  #18192
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Volition
Hi Guys,
Stock weight is around 1840 RTR using a typical pair of saddles, nothing done to reduce weight.. in fact weight added on the rear So maybe 1800 w/o weights
8ight-e is offline
Old 12-10-2015, 08:51 PM
  #18193
Volition's Avatar
Thanks Mate - When I hear back from other cars - I'll post the results
So far - Stock - Race Ready w/ Shorty Batteries
Durango DEX410 - 1800-1840g
Schumacher Cat K2 - 1760-1790g
Volition is offline
Old 12-10-2015, 11:01 PM
  #18194
ASH93A's Avatar
Hi Guys,
Hi Mate, I have the V4 and in full race trim with regular shorty it weighs in at 1710 grams. The only thing that I have done to shave a bit of weight off (about 10 grams) is using the skinny shocks (not big bore). I reckon the Dex410 is very under rated when it comes to 17.5! I am planning to purchase the V5 and also a few low profile shorties for even more weight saving!
ASH93A is offline
Old 12-17-2015, 12:34 PM
  #18195
SamuraiJack's Avatar
Trader Rating: 41 (100%+)
Replacing driveline pins (bones, cvds, universals?). I found some mention of it but can't fine details. Can anyone provide part #'s or brands for pins that work well?
SamuraiJack is offline
