Like Tree22Likes
Old 09-22-2010, 07:50 AM
  #1801
dangerwr's Avatar
Originally Posted by mccoy
i just wanna know if the lipo pack a few threads above by dangerwr ( the team orion) will be fitting without any mods in the 410r thx guy! or by the way what lipo r u running in yours?! looking to get the best for the buck! thx
I bought 2 of them so they had better fit! I believe the larger Orion (5800 or 6000mAh?) might be a tight fit. I know Racer's Edge advertises their 5200mAh packs are a perfect fit for the Durango. I personally have had very good luck with Orion packs. They typically use Kokam cells which are arguably the best on the market. I know from personal testing, in an entirely different application, that Kokam cells are quite robust. Cheers!
dangerwr is offline
Old 09-22-2010, 08:24 AM
  #1802
Trader Rating: 21 (100%+)
thx dangerwr for your comments!
mccoy is offline
Old 09-22-2010, 08:26 AM
  #1803
rraden's Avatar
Trader Rating: 259 (100%+)
Be careful! Any pack taller than 25mm will NOT fit! I have a 6000mah IP Intellect pack that is 31mm tall and no way would it go in.
rraden is offline
Old 09-22-2010, 08:27 AM
  #1804
dangerwr's Avatar
Glad I can help! And please, call me Danger! If you are looking for a good deal I saw that A-main is selling their Pro/Tek saddle packs for $99.99. They are 45 or 50C and around 5000mAh. I do not know anyone who runs these but might be worth a look . . .
dangerwr is offline
Old 09-22-2010, 08:44 AM
  #1805
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
5200mah and 45C, and I run one, along with 2 40C 5000mah stick packs.
I'm happy with them. Great punch and no issues after 5-6months with the stick packs. If anything happens to them, ANYTHING, Amain will sell you a new one at 1/2 the price.
t0p_sh0tta is offline
Old 09-22-2010, 08:45 AM
  #1806
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
Default Stallion!
i will be running this stallion in my very Dialed Durango!! next weekend..
http://www.amainhobbies.com/product_...s-Motor-5200kV
bigBoyBigToy is offline
Old 09-22-2010, 08:56 AM
  #1807
Company Representative
JoeNolasco's Avatar
Hey guys, I've been getting a few messages asking if we'd carry Durango Apparel. Here it is!
http://www.rpphobby.com/category_s/138.htm
JoeNolasco is offline
Old 09-22-2010, 10:03 AM
  #1808
dangerwr's Avatar
Yeahzz! The Team Orion 4500mAh saddle packs are 24.5mm tall whereas their 6000mAh packs are 31.5mm tall. Nice call on the height limitation. Cheers!
dangerwr is offline
Old 09-23-2010, 02:43 AM
  #1809
Dlewis4's Avatar
Trader Rating: 148 (100%+)
For anyone running on a tight indoor hard packed high bite track, the setup Matt Howard posted is absolutely dialed. The rear end needs to be a hair softer, but other than that the car is glued
Dlewis4 is offline
Old 09-23-2010, 03:44 AM
  #1810
Matt Howard's Avatar
SWeet, glad it works for you as well.
Matt Howard is offline
Old 09-23-2010, 05:25 AM
  #1811
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Is this for the R or spec car? Also what is the ride HT.? Thanks......
Bman's 3XNT is offline
Old 09-23-2010, 06:57 AM
  #1812
grapejuice's Avatar
Trader Rating: 153 (100%+)
Do you have your set-up posted any where?
grapejuice is offline
Old 09-23-2010, 07:06 AM
  #1813
rfleck's Avatar
Trader Rating: 58 (100%+)
Default Which battery, Matt?
Unless it changed, here was Matt's setup.
Front
7000 diff oil
2 hole pistons drilled out to 1.4mm, 40wt oil
Dark green springs
shocks mounted inside middle on tower, outside on arm
1mm spacer under outside camber link, inside middle on tower
Rear
3000wt diff oil
3 hole pistons drilled to 1.3mm, 35 wt oil
Light green springs
Shocks mounted middle on tower, middle on arm
Rear hubs spaced forward
Camber link middle on hub, inside second from bottom on tower
Brass skid plate used
rfleck is offline
Old 09-23-2010, 07:58 AM
  #1814
410R
ride height was bones level front and rear
Old 09-23-2010, 08:25 AM
  #1815
JoeNolasco's Avatar
Front
7000 diff oil
Dark green springs
Rear
3000wt diff oil
Light green springs
What brand of oils in the diffs and shocks?
