Like Tree22Likes
Old 04-25-2015, 10:10 AM
  #17881
So I ran the 410R at the opening weekend at 204Raceway and had a blast. What a missile! The track is primarily a 1/8 track so it has crazy MX jumps. Needless to say, the combination of crazy speed, nutty jumps and very rusty driving resulted in a broken, plastic rear shock tower. I have put a CF tower on the front but Amain is always out of stock on the rear CF tower. What other sellers have a good stock of 410 parts?
Also, I have been reading about various ways to run 12mm hexes - can someone please summarise for me? I want to run 12mm on all my buggies so I can swap around wheels.
Thanks!
CeeGee is offline
Old 04-25-2015, 10:13 AM
  #17882
rcjunky1's Avatar
Exotek makes 12mm hexes, that's the easiest way to do it.
rcjunky1 is offline
Old 04-26-2015, 04:12 AM
  #17883
Default For sale
VERY CLEAN roller for sale:
http://www.rctech.net/forum/r-c-item...-like-new.html
triple7s is offline
Old 04-26-2015, 10:42 AM
  #17884
Trader Rating: 26 (100%+)
Installed the universals on both front and rear. Already had them in the center. Like a whole different car! No heat, no binding. Acts differently. I do have to back and tweak it again as it now pushes on power. Off power steering is good. Doesn't over rotate squares up nicely On power.
tfrankito is offline
Old 04-26-2015, 02:41 PM
  #17885
tommytom's Avatar
Gents / Ladies,
What do you think is a fair price to put up my durango lot for? I have a dex410v4(2/3 of winter used), dex410v3 (used for about 8 months indoor only), 95% of a new v3 unbuilt(used as a parts resource) and a handful of clay tires)
Hop ups include
rear aluminum gear inserts
Rear weight set (3pc)
Aluminum Servo Saver arm
Aluminum servo mount
Aluminum spacers
Exotek Aluminum rear hubs (stuck bearing case in one) Im sure with some patience it can be removed.
tommytom is offline
Old 04-27-2015, 07:14 PM
  #17886
platgof's Avatar
Did you also install the 21* hubs as well? I did but haven't had a chance to use them.
platgof is offline
Old 04-28-2015, 08:28 AM
  #17887
Just fit the rear center universal to my 410R and the universal is hitting the battery strap. Being such an old model I am assuming the battery strap has undergone a running change to clear the uni.
Rutters is offline
Old 04-28-2015, 05:45 PM
  #17888
ekt
ekt's Avatar
You'll want the type B battery strap, TD320244.
ekt is offline
Old 04-28-2015, 07:10 PM
  #17889
rcjunky1's Avatar
Or just dremel it out, just compare pics to see what you need to trim, it's pretty easy
rcjunky1 is offline
Old 04-28-2015, 09:36 PM
  #17890
I had to trim mine as well. Basically just the center that is right under the uni joint. I have the v3. I cut mine out no issues.
Plangoff.....yes I did put the 21's on. It's better nm but so far I am really liking the universals all the way around.
Old 05-02-2015, 09:42 PM
  #17891
platgof's Avatar
Finally got a chance to run the car with the 21* hubs. I really like them a lot, and it handles great, a lot of confidence. After a few laps I was in a groove with it. I never expected the 21* hubs to make that much of a difference, but they did.
platgof is offline
Old 05-03-2015, 10:16 AM
  #17892
the incubus's Avatar
Trader Rating: 17 (100%+)
Tis what I've been preaching for 2 years now!! Lol
the incubus is offline
Old 05-04-2015, 05:52 PM
  #17893
Pekr.da.skurl's Avatar
Default Little help
Let me start by saying I'm new. Please correct me, and fill in the blanks of you will. Ok I pickup up a Dex410 roller. This is the first car I've bought that has the saddle style battery packs. I looks like it takes 2 2 cell lipos. I think the local track has you race in 2 cell lipo. Is that how it's done? Also could, should I run 550 can in a 4x4 buggy. Thanks in advance.
Pekr.da.skurl is offline
Old 05-04-2015, 06:06 PM
  #17894
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Welcome, saddles are 2x1s=2s so your good, and no on the 550. To big, fast and heavy. Plus I do not think it will fit...Good luck with the new ride!
Bman's 3XNT is offline
Old 05-04-2015, 07:35 PM
  #17895
you run a regular 540 can. Most run a 8.5 - 6.5 turn. There are the superstock classes that rn 13.5 so check with your local track and see what motors they are running.
The saddle packs are sold in pairs. They come as matched 1s cells. They are 1 cell each and when ran in series = 2s together.
