Like Tree22Likes
Old 09-19-2010, 06:47 PM
  #1771
dangerwr's Avatar
Here are some pics of my new shell for the Durango. Thank you Mel for this work of art. Now I will be motivated to build the rest of the car!
dangerwr is offline
Old 09-19-2010, 06:50 PM
  #1772
Konich's Avatar
Looks good! I gave REAPER my Azarshi body last week now get that thing built so we can have a 4wd class on Wednesday!
Konich is offline
Old 09-20-2010, 06:04 AM
  #1773
rfleck's Avatar
Trader Rating: 58 (100%+)
Originally Posted by captain stacker
does anyone have a setup that calms the rear end?
I find it alot tailly/nervous compared to other 4wd's I've driven/own.
have tried lengthening rear camber link, 50grams on top of lipos, softer rear oil and springs, doesn't seem to have changed much however. Running 20k/5k diff oils.
As others have suggested, you may want to go down in the front diff. I run 10k front and 5k rear with rear hubs all the way forward. I have tried many shock setups, but have yet to think any of them made the car nervous. Very planted but still turns on a dime.
rfleck is offline
Old 09-20-2010, 08:00 AM
  #1774
grapejuice's Avatar
Trader Rating: 153 (100%+)
im running IP5000 lipos and there is only room to put weights on top of the lipo.
Adding weights on top is just raising the center of gravity and will make the car drive worse...Try mounting them next to the lipo where the durango side weights go.
grapejuice is offline
Old 09-20-2010, 08:37 AM
  #1775
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
are weights even really needed this car is so heavy already..
bigBoyBigToy is offline
Old 09-20-2010, 08:45 AM
  #1776
grapejuice's Avatar
Just to balance the car out a bit, it was designed for NIMH....it helped the rear end a little when I added the side weights, look a little of the steering out too which helped as well. I don't feel it needs more then those.
  #1777
grapejuice's Avatar
Looks good bud!!!
Old 09-20-2010, 09:19 AM
  #1778
Originally Posted by evostyle
So what's the best replacement for the stock ball cups. I only want to change out the cups.
has anyone just changed out the ball cups??? if so please post guys
Old 09-20-2010, 09:22 AM
  #1779
dangerwr's Avatar
I have only read in this thread that some were using the grey Losi ball cups. I have also read the Durango stocks were questionable. I will try the stock and see what happens and then look to see what else fits. I used to run the RPM stuff on the AE's I had but was still a noob.
dangerwr is offline
Old 09-20-2010, 09:25 AM
  #1780
Matt Howard's Avatar
The losi one's won't work, they're a bit too small. I thought someone posted some RPM ballcups that were sized for the Durango studs?
Matt Howard is offline
Old 09-20-2010, 09:36 AM
  #1781
dangerwr's Avatar
Not sure since I will be using Lunsford 3mm "Punisher" Ti tie rods. The RPM will certainly fit those! I bought the 1 x 3/4" tie rods which are slightly longer than the stock 43mm but should work just fine.
dangerwr is offline
Old 09-20-2010, 09:41 AM
  #1782
I meant the losi ball cups are too small for the durango ball studs, sorry for the confusion. I think RPM does make some ball cups that will fit the stock durango ball studs.
Old 09-20-2010, 10:04 AM
  #1783
dangerwr's Avatar
Whoops! I get you now. I would honestly try the RPM cups first but do not know which ones to try.
dangerwr is offline
Old 09-20-2010, 10:43 AM
  #1784
Konich's Avatar
Weird, I have the stock ballcups and not a single problem. I think the first production ball cups were better than the ones with the 410R. Even Grapejuice raided my spare supplies
Looking to finish up my setup on Wed. so I'll post up the results!
Konich is offline
Old 09-20-2010, 11:09 AM
  #1785
R-E-A-P-E-R-'s Avatar
Horse Power has arrived. According to the gearing chart I used a 87-20 combo should be a pretty good place to start. Anyone disagree ? ? ?
X12 6.5
R-E-A-P-E-R- is offline
