Like Tree22Likes
Old 09-19-2010, 04:37 AM
  #1756
evostyle's Avatar
Trader Rating: 103 (98%+)
BBBT... nice report! Thanks for all your testing and information. I can't wait to get mine out and run with you. I just wired it up last night and have a really nice layout for anyone with a RS. I'll post pics later.... gotta go fly, be back this afternoon with some pics.
evostyle is offline
Old 09-19-2010, 06:01 AM
  #1757
TCarlson777's Avatar
Trader Rating: 18 (100%+)
Default Front aluminum suspension holder upgrade
Just a quick tip. If you decide to upgrade the 410r to the front aluminum braces, part 330004 and 330006 you will also need to order a set of suspension arm pivot balls, part 330037. The hinge pins float in the pivot balls. Take a look at the 410 manual, page 25 if you want to see what I mean.
TCarlson777 is offline
Old 09-19-2010, 09:36 AM
  #1758
Trader Rating: 10 (92%+)
Default setup
does anyone have a setup that calms the rear end?
I find it alot tailly/nervous compared to other 4wd's I've driven/own.
have tried lengthening rear camber link, 50grams on top of lipos, softer rear oil and springs, doesn't seem to have changed much however. Running 20k/5k diff oils.
captain stacker is offline
Old 09-19-2010, 09:54 AM
  #1759
Matt Howard's Avatar
Is it loose on power, off power, or just all the time? I ran 3k in the rear with the stock suspension geometry, 3 hole pistons drilled out to 1.3mm with 35 wt oil and light green springs and my rear end was pretty much locked in. I also ran the brass skid plate.
Matt Howard is offline
Old 09-19-2010, 10:23 AM
  #1760
So what pistons and springs, what surface/tyres, used all/side/rear weight, ride height, other setup ?
Poinas2 is offline
Old 09-19-2010, 11:20 AM
  #1761
bigBoyBigToy's Avatar
Trader Rating: 23 (100%+)
focus on your ride height!! U can also move your rear arms completely foward!! Go up in diff fluid! And most important adjust your slipper correctly maybe loosen it a tad and u must have the correct tire so it doesnt wash out jmo!!!
bigBoyBigToy is offline
Old 09-19-2010, 02:02 PM
  #1762
Konich's Avatar
20K in the front diff seems a little high, maybe go down to 15K and a tad up int he rear (5K).
Konich is offline
Old 09-19-2010, 02:08 PM
  #1763
savageboy69's Avatar
Trader Rating: 93 (100%+)
i agree, i think its not so much as ur rear end is loose, but your front is very aggressive, i run 10k front and 2k rear, and it will also depend on your tire selection
savageboy69 is offline
Old 09-19-2010, 03:22 PM
  #1764
evostyle's Avatar
I just got mine built. Really nice kit. I dumped the B44 for this one. I just wanted to share my electronic layout. The new SAVOX servo seems really fast and precise!
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_0694.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_0695.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_0698.jpg
evostyle is offline
Old 09-19-2010, 04:09 PM
  #1765
looks very nice larry!! Hope u didnt use the stock servo horn? JUNK! Abbot has went thru 2 of them lol u run hitec so the blue alum horn works perfect
Old 09-19-2010, 04:27 PM
  #1766
evostyle's Avatar
I did read your post about the stock arm. I have an aluminum one ready to go on.
evostyle is offline
Old 09-19-2010, 05:56 PM
  #1767
Dal
Dal's Avatar
I went with 50k front dif and 20k rear diff.
Makes it heaps better, in a not so nervous type of way.
Much calmer into and out of turns.
Also try toe out on front, which will make it a little more sensitive on initial steering, but through the corner it will be less steery.
Dal is offline
Old 09-19-2010, 06:03 PM
  #1768
thanks guys, the surface I run on is hard packed clay, grippy when clean, and slippery when there is a fine dusk on surface. Car is loose off power. Tires of choice at my track is holeshots and x2000. My setup was standard the last time I used the car except rear pistons drilled out to 1.3mm and the softest kyosho black springs and 20k/5k diff oils with only 50gm on lipos. Removed rear bar. Usually run 35/30 shock oils.
I will try the changes suggested, one at a time, starting with moving the rear hubs forward, then 10k front oil, and maybe stiffer front roll bar. And as a last resort, spend the ridiculous amount for the lead weight kit.
Old 09-19-2010, 06:08 PM
  #1769
Konich's Avatar
Are you running the lipo weights? Where are you stacking the weight you are adding?
Konich is offline
Old 09-19-2010, 06:22 PM
  #1770
im running IP5000 lipos and there is only room to put weights on top of the lipo.
