Like Tree22Likes
Old 01-23-2015, 07:17 AM
  #17536
13Maschine's Avatar
Originally Posted by Dino_D
Have you tried the associated rims? Cause the DEX210 has the imperial sized axle for the front to use AE rims. So i figured logic would dictate that they would use AE as standard for the rear. Anyone tried them?
Right now the AE front wheels I have are the 9.7mm size…I've been using the 22-4 fronts or regular Durango wheels with 14mm hexes. The 14mm hexes seem to be a few MMs narrower than the 12mm unless you use the K1 hexes for the shumacher. When I use the 22-4 wheels with the new exotek 12mm clamping hexes on the front, the wheel locknuts don't get full thread penetration. Especially if they aren't low profile.
I"ll try to post some measurements and such later as I think I have most of the hex combinations for this car now. I have two sets of avid 12mm hexes, Shumacher K1 12mm, and the Spec R 14mm clamping set. I'm doing the NAMM trade show right now so it's a little crazy…
13Maschine is offline
Old 01-24-2015, 10:18 AM
  #17537
platgof's Avatar
I am willing to get the uni fronts, but the mids are over my budget. I am thinking of using the D drive shafts for the mid's, as I would not have to purchase a dual slipper. Is the D better than the original? I need something that will last. I think the uni's in the front would be worth it as they would help the bearings last longer, and make turning easier on the servo.
platgof is offline
Old 01-24-2015, 03:38 PM
  #17538
Reflexia's Avatar
Why would you have to purchase a dual slipper? The mid-uni (of which the rear is a 'must have' in my book ) works with the same middle slipper as always.
Reflexia is offline
Old 01-24-2015, 04:32 PM
  #17539
KBRacing's Avatar
Must have a dual slipper NO, it does not work.
Because if you lose one end, you have ONLY half a slipper to transfer power with, it works perhaps when you drive straight out and aut of a corner but NOT over a jump when the front Wheels slip......
KBRacing is offline
Old 01-24-2015, 05:22 PM
  #17540
Trader Rating: 26 (100%+)
Is the v4 slipper any good? I am starting to have issues with the v3 slipper. I am on my 3rs spur gear. This last one, I melted the inside of the spur...the plastic melted in between the holes on the metal slipper plates and locked the spur thus stripping the spur LOL. I now have it as tight as I can get it and it still slips. Used new pads also and ruined those. Do the plates go bad? I am using a 5.5t and it's awesome. but am also having gearing issues.
tfrankito is offline
Old 01-24-2015, 06:43 PM
  #17541
platgof's Avatar
If this uses the same pads as a Desc210, then the Arrmma pads will work. I sand the face of mine before installing, gives it a better grip. I flexed the chassis enough for the front mid drive shaft to pop out. After that I bent the body to make it tighter and it worked. I was able to finish the main tonight without breaking my car. I also have a slipper issue with my Desc410R, it was too loose. I also sanded the discs as well.
platgof is offline
Old 01-25-2015, 04:12 AM
  #17542
Reflexia's Avatar
Your slipper is still too loose then ( slipping all the time and melting the poor spur gear). Looks cool when that happens tho huh? Oooses through the metal
Associated Pads are much thicker and seem to take a lot more more punishment before they smooth up, I've been running them for a while now. I hear you can now get Durango Garodiscs which are even more hardcore.
Reflexia is offline
Old 01-25-2015, 10:23 AM
  #17543
platgof's Avatar
I am thinking of putting my RS Pro and Tekin 5 turn in this. I will of course limit the power. I have a triple I need to clear. This thing really turns now since I replaced all the drive line pins. I will probably need to beef up the drive line with the 5 turn, ya thank!
platgof is offline
Old 01-25-2015, 10:42 AM
  #17544
rcjunky1's Avatar
The drivetrain is bomb proof, as long as the diffs are shimmed right, It'll handle the horsepower for sure. A local had a 5.5 running on turf with a locked slipper...
rcjunky1 is offline
Old 01-25-2015, 06:29 PM
  #17545
platgof's Avatar
Is there a fix for the chassis flex? My front center drive shaft popped out during the second heat. I can flex the chassis and see that it could easily pop out.
platgof is offline
Old 01-25-2015, 10:08 PM
  #17546
frankf's Avatar
Carbon brace or alloy sides, but have never seen a chassis flex enough to pop the middle shafts out
frankf is offline
Old 01-25-2015, 11:37 PM
  #17547
ekt
ekt's Avatar
If your front drive shaft does pops out, check that the steel posts are screwed in tight and that the top deck/front bulk heads are not damaged.
ekt is offline
Old 01-26-2015, 07:04 PM
  #17548
platgof's Avatar
Thanks, I will check it and see if that is where the play is coming from. I installed the RS Pro and Tekin 5 turn. Needless to say I turned it down quite a bit and added current limiter to it as well, maybe too much. I know this is a lot of motor, but should be fun as it is a high torque motor. I was running an 8.5 motor, but it was lacking some punch.
platgof is offline
Old 01-26-2015, 07:26 PM
  #17549
I'd really like to see some alternate shock towers... These fine adjust towers blow.
Barge is offline
Old 01-26-2015, 08:28 PM
  #17550
rcjunky1's Avatar
The non fine tune ones are stronger, but what happened to the guy making 5mm towers? That's the solution imo.
rcjunky1 is offline
