Like Tree22Likes
Old 12-25-2014, 10:49 PM
  #17371
frankf's Avatar
What fan mount is that and does it fit under the v4 body? And as for being loose in the rear with a shorty pack yes it is but you can add weight to get it closer to a saddle pack and setup the car to compensate, I chose shortys because I can fit and remove them without pulling the spur gear assembly out and the fact I already had them.
frankf is offline
Old 12-26-2014, 01:56 AM
  #17372
Pittster's Avatar
Its a yeah racing fan bracket that I ground most of it down to fit cant see why it wouldnt work with the v4 shell it works in my Proline bull dog shell
Pittster is offline
Old 12-26-2014, 01:58 PM
  #17373
frankf's Avatar
Yeah the v4 shell is pretty tight over the motor is why I ask, is the wtf fan thinner than 10mm?
frankf is offline
Old 12-26-2014, 05:25 PM
  #17374
platgof's Avatar
Oh man is my car ready for tomorrow. That 8.5 is really moving along, and it is so much quieter with the plastic gears, really nice. I went through my stock of spur gears to find one that was truly round, and it made a difference. Can't wait for those Electrons to slap on the front.
platgof is offline
Old 12-26-2014, 05:38 PM
  #17375
Pittster's Avatar
Yeah its just a 10mm thick fan.
more detailed picks on how it sits with the old YR 30mm fan.
Pittster is offline
Old 12-26-2014, 06:06 PM
  #17376
Originally Posted by Sodakota
I tried a similar setup and felt felt it was a little to front heavy for my track. The rear was stepping out all over the place and my front tires wore out very quickly. The fronts are bald and the rears look almost new. It might work on a loose track well though.
I find the shorty only works on a track where you have a lot of rear grip but the front wants to push straight on which there isnt very many for this car, anywhere else it just makes the front sooooo twitchy!!!
av4625 is offline
Old 12-26-2014, 07:33 PM
  #17377
platgof's Avatar
The square pack fits like the car was designed for one. Saddles have two much going on with two packs.
platgof is offline
Old 12-27-2014, 08:46 PM
  #17378
platgof's Avatar
I ran it on the track and it was dialed. Ever have one of those nights that stupid stuff keeps happening, a lot of it my own fault, mainly overlooking stuff before the race.
platgof is offline
Old 12-28-2014, 11:10 PM
  #17379
I'll change 14mm wheel hub to 12mm and buy proline 2.4" vtr front and rear wheel but they have 3 different wheel, for b44.2, zx6 and 22-4. What is different between them? What should I buy?
xtaiji is offline
Old 12-29-2014, 06:36 AM
  #17380
TeamJammin!'s Avatar
Hey Guys, Not sure if this is the appropriate forum to advertise my car for sale, so if not let me know. I have a 2 year old Durango Dex410. I have raced it indoors only. Maybe had it at the track 15 times. Really great condition. Also have a bag full of new parts, upper lower arms etc. Probably $75 worth of parts in the bag. Looking for best offer. I will be keeping the servo motor and esc.
I will post a few pics later today once i get home from work.
TeamJammin! is offline
Old 12-29-2014, 09:00 AM
  #17381
Laker67's Avatar
Trader Rating: 69 (100%+)
I believe that the offsets are what set them apart, and also the hex depth. I think that the B44 wheels have a narrower offset then the 22-4 wheels but they make up that offset on the car with a wider 10MM hex. Also the b44 uses a 10MM hex, and the 22-4 uses the 12mm hex. I can't really tell you the difference with the ZX6 though.
On a different note, can anyone lay down a parts list to update a V3 car to the V4? I appreciate the help.
Laker67 is offline
Old 12-29-2014, 09:10 AM
  #17382
tobamiester's Avatar
Trader Rating: 360 (100%+)
http://www.rctech.net/forum/12845901-post14877.html
tobamiester is offline
Old 12-29-2014, 04:15 PM
  #17383
KBRacing's Avatar
Hi All,
Is there anyone who can tell me what the difference between rear brace in Plastic, Carbon Fibre and the Flex Brace System ... ???
KBRacing is offline
Old 12-30-2014, 02:24 AM
  #17384
Has anyone had trouble with the rear gearbox insert braking which in turn helps the bulkhead break I am now contemplating whether to get the aluminium insert or the brass weight insert, I use shorty lipos so I can use more weight but is it any good to have the weight so far back as opposed to inside the wheelbase?
thefan is offline
Old 12-30-2014, 03:51 AM
  #17385
Cant say I've had problems with inserts or bulkhead, but I've always ran the alloy inserts and brass skidplate. As your thinking the brass weight inserts can only add some strength but the skidplate plus inserts would be better. It puts the weight below the chasis. Also the further back the weight is the greater effect it has on reducing some of the cars twitchy nature.
Piles is offline
