Like Tree22Likes
Old 12-24-2014, 12:39 PM
  #17356
Trader Rating: 26 (100%+)
Originally Posted by platgof
You will also have the extra weight and no slip feature. I find the least complicated don't break as often, and in 4wd buggy, this means a lot. I need to know what tires are working best, has anyone tried Electrons on the front? I am using Scrubs up front, but they pack easily.
My track I have tried dirt webs front and rear in SS and electrons rear SS and clay electrons front. I have the 17 degree castor block still (it's so expensive LOL) We run a medium bite clay and traction is getting better every week. Dirtwebs were really loose compared to the electrons on the rear. Fronts...the dirtwebs hooked decent but the clay electrons take the twitch out. I am going to try a sway bar on the front. I kind of like the 17's but haven't driven anything else. Rear is planted.
Dino, going up in spring on the rear prevent bottoming out? She sure slaps the ground a lot. Is that a buggy tendency or should I go up a bit in oil? Running your shock, oil, spring package. get's around 45 degrees in the building. The front seems pretty good.
tfrankito is offline
Old 12-24-2014, 01:52 PM
  #17357
platgof's Avatar
Glad to hear about the Electrons on the front, as I just ordered a set, and some pinion gears for it. I ordered 21 and 22 as I use an 8.5.
platgof is offline
Old 12-24-2014, 02:31 PM
  #17358
frankf's Avatar
Originally Posted by Millsy97
Has anyone tried a centre diff in there 410 before?
All tknowhe new cars that are out have centre diff and they seem to be doing well so I have been looking for a option that would let me run a centre diff. I've seen the b44.3 diff as that's extremely thin so I'm hoping that it might.
Alex
There's a few forum members who have managed to go the centre diff in dex410. I know the fast local assoc sponsored driver runs 100k in the c/diff and have seen a setup sheet where he used a slipper and ball diffs in his b44.3 so i dont think its a must have item, the v4 2way slipper should be as good as running really thick c/diff fluids that all the pros seem to run in there d413, b44.3 etc...
frankf is offline
Old 12-24-2014, 10:40 PM
  #17359
Laker67's Avatar
Trader Rating: 69 (100%+)
Hey guys, I've been a TLR guy for a while now but wanna try a the durango stuff for a minute. What are the things I need for this car along with tuning stuff. I have tlr low frequency springs I can use but what else besides springs does this car need? It's a V3 that I just picked up. Thanks for the help!
Laker67 is offline
Old 12-24-2014, 11:24 PM
  #17360
really all that is needed is the 19 or 21 castor blocks (19 blocks and up one compound in tire). sway bars and the type b pistons. Really good set up on petit rc. Dino Delemos. I have been running his setup on this car plus all my other cars. Dialed!
Old 12-25-2014, 02:57 AM
  #17361
Thanks, do you have any ideas how they did it?
I race on astro so setups might be a little bit different.
Millsy97 is offline
Old 12-25-2014, 03:08 AM
  #17362
ekt
ekt's Avatar
Bman's 3XNT made a chassis that allows for a center diff http://www.rctech.net/forum/13643943-post17153.html
ekt is offline
Old 12-25-2014, 06:37 AM
  #17363
platgof's Avatar
So what is required to install the two way slipper, and is it really that much better than the old one? I wonder if one will be available for the Desc410? Desc210?
platgof is offline
Old 12-25-2014, 08:55 AM
  #17364
tobamiester's Avatar
Trader Rating: 360 (100%+)
If I recall, the 2-way is a drop-in for the v3 buggy (as they changed the lengths of the center cvd's in the v3).
desc410 already has a center diff to tune front/rear power transfer.
Not sure why you'd want it in the desc210 2wd car.
tobamiester is offline
Old 12-25-2014, 11:14 AM
  #17365
Laker67's Avatar
Awesome thanks pal! Ill get some pistons ordered. I know the car is moving with sway bars on it but is there a specific pack that I need to get?
Laker67 is offline
Old 12-25-2014, 02:31 PM
  #17366
I recommend a brick pack, less wires (internal resistance). Trinity Brick or Half Brick both are great. Vant make a nice pack. Also Reedy and some run the Nanotech also (from Hobbyking). Depends on your preference and budget . Just make sure its less that 25mm high...
Old 12-25-2014, 03:17 PM
  #17367
Laker67's Avatar
Have you guys tried running a shorty in them yet?
Laker67 is offline
Old 12-25-2014, 03:52 PM
  #17368
Pittster's Avatar
Pittster is offline
Old 12-25-2014, 05:09 PM
  #17369
Originally Posted by Pittster
I tried a similar setup and felt felt it was a little to front heavy for my track. The rear was stepping out all over the place and my front tires wore out very quickly. The fronts are bald and the rears look almost new. It might work on a loose track well though.
Sodakota is offline
Old 12-25-2014, 09:47 PM
  #17370
tc5 man's Avatar
With the plastic Spider diff gears on the gear diff do i need to go up to 5k from 4k with the Metal Spider diff gears i been using or i can stick with the 4k ?
Sorry wrong tread lol.
tc5 man is offline
