Like Tree22Likes
Old 10-01-2014, 06:22 PM
  #16906
ekt
ekt's Avatar
Originally Posted by MrHistory
Thanks for the build ideas!
Few more questions:
1. Motor turn conversation leaves me unclear. I have a super fast friend running a 7.5T Reedy Sonic in his XB4. He's a better driver than me and suggested I get an 8.5T. We race at a smallish indoor track (Island Raceway-Long Island NY)
2. Looking at the Savox 1251MG and 1252MG Low Pro Servos. Opinions? I have full size servos but read a lot here about front heaviness of the DEX410. (I bought the 30gr rear skid weight).
3. Want to get Lunsford Turnbuckle Set. Should I get the 3mm or the 3.5mm Superduty? Should I run Lunsford or DEX410V4 Ball Cups?
4. Are the DEX410V4 kit shock springs a good starting point or should I get other springs?
Thanks, Jason
1. For a smaller track, those motor sizes sound right.
2. I've seen too many broken gears in low profile servos to recommend them for 4wd offroad. I would recommend a Savox 1257tg or 1258tg.
3. I've run the 3mm turnbuckles on my v3 without issues. The v4 cups are fine, if you do change ball cups you will need to change ball studs too.
4. The kit springs are a good starting point.
ekt is offline
Old 10-01-2014, 06:41 PM
  #16907
MrHistory's Avatar
Thanks guys!
MrHistory is offline
Old 10-01-2014, 08:04 PM
  #16908
re-do73's Avatar
Originally Posted by rcjunky1
Or find someone to make 5mm front towers, mine is a tank, totally cleared off the bulkheads earlier in the year and the tower didn't even flinch. I run the Dino set up with 5k front oil, a little tamer on power. I found this car sensitive to ride height, especially in the rear, so if it's a little loose lowering the back a bit makes it planted
if there is enough interest, I can order up some 5mm carbon and make up some towers. I have the 410 going on the design bench next week. It will take about 2 weeks.
re-do73 is offline
Old 10-01-2014, 08:30 PM
  #16909
vito's Avatar
what a better battery fantom or rev tec brick?
vito is offline
Old 10-01-2014, 09:21 PM
  #16910
rcjunky1's Avatar
Durango had a 'defective' run included in a batch of kits like mine and it's the bees knees, just a slight bit of trimming with an xacto and it's perfect. I'd recommend them for sure
rcjunky1 is offline
Old 10-02-2014, 07:11 AM
  #16911
13Maschine's Avatar
@re-do73: I'm interested, let me know details when you can please
13Maschine is offline
Old 10-02-2014, 07:34 AM
  #16912
13Maschine's Avatar
Have you also considered a making a graphite chassis for the 410? Now that I'm asking I wonder if we talked about it on open source durango already….
Old 10-02-2014, 08:02 AM
  #16913
rcjunky1's Avatar
like the atomic carbon ultra 410 with a carbon tub chassis? I don't think there's any benefit for one like the 8racing one, you don't save any weight with the alloy side pods.
rcjunky1 is offline
Old 10-02-2014, 09:12 AM
  #16914
13Maschine's Avatar
this is my sad face
Old 10-02-2014, 10:00 AM
  #16915
re-do73's Avatar
I have been researching the tub chassis, along with some other options.
re-do73 is offline
Old 10-02-2014, 05:28 PM
  #16916
ekt
ekt's Avatar
Not sure about the difference in weight between the aluminium and carbon chassis, but the aluminium side pods are 5g heavier per pod.
Originally Posted by Pittster
So Having never known how much the alloy side pods weigh I grabbed a mates Dex410 plastic side pods and compared to my own.
The difference was 5g and the alloy side pod has velcro and chassis protector on it so it would be nearly the same.
ekt is offline
Old 10-02-2014, 06:42 PM
  #16917
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
The carbon chassis with alloy side pods saves around 50-60g, can't remember exactly.
ajj is offline
Old 10-02-2014, 06:50 PM
  #16918
Pittster's Avatar
Whats a Dex410 normally weigh with Alloy chassis?
With mine I have a 8 racing carbon chassis, alloy sidepods SP Reveton Pro esc a full servo, titanium cambers links,30g rear weight, proline bulldog shell, sway bars front rear, holeshot tyres with open cells, nanotech saddles and race weight is 1750g.
I can't remeber what it was with the alloy chassis so unsure on the weight saving.
Pittster is offline
Old 10-02-2014, 08:03 PM
  #16919
ekt
ekt's Avatar
Just weighed my v4 mine in at 1826g. Pretty much stock, orca saddles, pin points with closed cell foams, tekin rsx combo and a full sized servo
ekt is offline
Old 10-02-2014, 09:42 PM
  #16920
Pittster's Avatar
Thanks EKT good to know I never wanted to pull the car down to its chassis to check weight but that sense so the carbon chassis is lighter.
Pittster is offline
