Like Tree22Likes
Old 09-29-2014, 01:30 PM
  #16876
Dino_D's Avatar
Originally Posted by tony montana
In the market for a new 4 wheeler. Asking honest opinions please. Anything this car needs as far as options out the box? Doesn't it still use odd ball 14mm hex, or can you use other hexes for more popular wheels? Biggest concern is durability, any parts I would need to keep on hand that are issues. I'm leaning toward this or the xb4. I had a 44.2 last year and it was ok didn't break many parts but hate the fact it's still uses standard screws and bearings. Gonna be running on a indoor clay track. Also will there be enough room for a orion r10? Any suggestions is appreciated
If you are considering v4, I would suggest the rear brass weight kit, aluminum servo saver arm, front 1.3mm and 1.1 sway bars if you are running on a clay indoor track.
As for durability, I think the v4 is definitely stronger than the Losi 22-4. I have seen the TLR break front arms, front clickers and belts. I havent broke the whole season, nor have my teammates. But others drives in the lower mains have clipped or crashed at speed into pipe and broke arms. But then again most cars don't survive a full speed hit. Any of the cars would break except the HPI.
As for spares: front arms, front shock tower unless you get the HPI Vorza shock protectors then you wont snap a tower, and front bulkhead set. Thats about it. The XB4 is very similar to the durnago, maybe slightly stronger, but the replacement parts and options are more $$.
Dino_D is offline
Old 09-29-2014, 08:57 PM
  #16877
13Maschine's Avatar
@Dino_D: Can you post pics of your vorza shock protectors installed on the 410?
13Maschine is offline
Old 09-29-2014, 08:58 PM
  #16878
13Maschine's Avatar
+1 for this "If you are considering v4, I would suggest the rear brass weight kit, aluminum servo saver arm, front 1.3mm and 1.1 sway bars if you are running on a clay indoor track."
Old 09-30-2014, 01:26 PM
  #16879
FastPete's Avatar
Trader Rating: 44 (100%+)
Anyone have a indoor med to high bite clay setup to start with?
FastPete is offline
Old 09-30-2014, 01:38 PM
  #16880
rcjunky1's Avatar
I finally broke my car last weekend, hit the face of a jump pretty hard with a single front wheel. When The front arm breaks, the inner hinge pin does as well. I think front arms and inner hinge pins is all you need, it takes a ton to break a tower or bulkhead.
rcjunky1 is offline
Old 09-30-2014, 02:33 PM
  #16881
Dino has a good one i was running. I can't find it tho.
turtle189mt is offline
Old 09-30-2014, 05:55 PM
  #16882
MrHistory's Avatar
Just ordered the DEX410V4. Excited to join you guys.
I will be running 2 classes: 2wd blinky and 4wd with the DEX410 which will have an 8.5T motor. Currently I have two speedos: an Orion R10 and a Tekin RS (not Pro). The Orion is two years old (the grey one, and the Tekin is at least 4 years old). Maybe these speedos have newer models but mine are a bit old (but in good condition).
Not an off road guy so please let me know which of these speedos I should use in the DEX410 or if I should buy something different. Was thinking about getting an LRP Flow, also looking at the Orca. Currently I have the Orion in the 2wd buggy.
Thanks! Jason
MrHistory is offline
Old 09-30-2014, 06:20 PM
  #16883
MrHistory's Avatar
Also does that Tresrey servo arm fit the DEX410v4? Where do I get that damn thing?
Old 09-30-2014, 06:33 PM
  #16884
FastPete's Avatar
Hope someone finds a setup for me. I looked on the site nothing stuck out at me. Leisure Hours in Joliet IL is where I run. Indoor clay med to high bite.
Also I took apart this V3 buggy I picked up. Is there any V4 parts that I should get? Driveshafts, etc? Or just freshen it up the way it is? Shock pistons? Anything.
Also any clue where I should start for gearing 13.5 blinky.
FastPete is offline
Old 09-30-2014, 06:51 PM
  #16885
rcjunky1's Avatar
It does but hard to find. Just get the Durango one. As for esc's, put the r10 in the 410, rs in the 2wd if you run a 7.5 or slower
rcjunky1 is offline
Old 09-30-2014, 06:55 PM
  #16886
MrHistory's Avatar
Yes the 2wd buggy class is 17.5T Blinky...
Thanks!
Old 09-30-2014, 07:05 PM
  #16887
I pulled the trigger on the 410v4 im sick of 2wd bye bye 210, anyway are the alloy diff hoops needed and what about the alloy mid drive plate?
thefan is offline
Old 09-30-2014, 07:12 PM
  #16888
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Give this one a look, I used it our indoor clay track, and it was pretty good..The key was the rear droop for our track, it helped lock down the rear end.
http://www.petitrc.com/setup/durango...AllSeason2012/
flame56mx is offline
Old 09-30-2014, 07:23 PM
  #16889
FastPete's Avatar
Thank you
FastPete is offline
Old 09-30-2014, 09:47 PM
  #16890
the incubus's Avatar
Trader Rating: 17 (100%+)
Thanks! Jason
You're going to want to run a 6.5 or 5.5 on a 410 depending on the size of the track. I'd go with the Orion over the Tekin.
As for the diff hoops, I don't have them and have never broken the plastic ones. Your money is better spent on the rear skid plate weight and the 21* front blocks if you find the car a tad too twitchy.
The Tresrey servo arm is made for the 410 but they had stopped production in anticipation of the new 410 being different, but Konich said in the Tresrey forum they are going to do new runs of their 410 stuff because they fit the v4. I'd imagine he meant the front and rear blocks and all the other little tidbits as well.
Welcome to the family and enjoy
the incubus is offline
