Like Tree22Likes
Old 09-18-2014, 03:30 PM
  #16801
jreeves's Avatar
Originally Posted by 13Maschine
I see a lot of you guys are running the plastic steering brace. I assume because it's lighter than the alum? Has anyone weighted the two and know the difference in weight? Thanks!
Steering brace? Which part is that?
jreeves is offline
Old 09-18-2014, 04:46 PM
  #16802
ekt
ekt's Avatar
I think he's talking about the servo mount TD340002
ekt is offline
Old 09-19-2014, 06:02 AM
  #16803
tobamiester's Avatar
Trader Rating: 360 (100%+)
Mmmm. Just installed Big Bore Alum caps. Very sexy.
As they don't come with instructions, good to note there is a quick instruction sheet for installation here: http://www.team-durango.com/part-inf...artNo=TD230034
tobamiester is offline
Old 09-19-2014, 07:17 AM
  #16804
Option parts you'll use will be the rear weight to replace the skid plate, the aluminum servo saver arm and a aluminum servo horn, and the aluminum rear differential hoop. McMaster-Carr drill blanks to make your own 3mm inboard hinge pins are a good idea too.
If your V2 doesn't have aluminum hinge pin mounts you'll want them too as the plastic ones break.
The servo I use is a Savox 1257 (SC-1257TG) and it's more than up to the job.
I use turnigy saddles in my buggy since they're lighter than the square packs, but use their squares in the DESC410. Both work great for me.
+1
It's a beast on the track, easy to work on (getting the electronics in takes some planning), and very consistent.
Spend some time building / going over the CVDs.... it'll throw pins if they aren't just right.
wicker9 is offline
Old 09-19-2014, 07:32 AM
  #16805
Anyone had any issues with the Servo arm/link popping off the ball on the v4 ? Never really had that issue with the v2/v4. Maybe my servo-saver is too tight ?
Old 09-19-2014, 08:37 AM
  #16806
thanks for the advice on the equipment. I will have my radio and extra receiver and servo on tuesday. i will be able to at least run my dex210 until I get my other speed control/motor/batteries. I ordered a hitec 7966 servo to try it out, if it doesnt work well i will switch it out (from what i read the speed passions only put out 5.75volts at 3A so i didn't want to go with a HV servo but if i have to i will get one).
jswinkos is offline
Old 09-19-2014, 08:40 AM
  #16807
vito's Avatar
I put in a metal horn on the streeing servo and it hitting the center drive shaft it the drango one 25 t
vito is offline
Old 09-19-2014, 09:32 AM
  #16808
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Not sure if Durango has more than one style but mine did the same thing. I ended up buying a Losi one. You would think TD would make something to fit all their cars since that is a relatively common part.
Bman's 3XNT is offline
Old 09-19-2014, 09:35 AM
  #16809
vito's Avatar
it just rubs a tad it a savox 12 57
vito is offline
Old 09-19-2014, 09:48 AM
  #16810
vito's Avatar
vito is offline
Old 09-19-2014, 11:16 AM
  #16811
the incubus's Avatar
Trader Rating: 17 (100%+)
Yeah that's a little bit of an issue with the 410 but most of us just grind it down to gain the proper clearance for the horn.
the incubus is offline
Old 09-19-2014, 09:15 PM
  #16812
13Maschine's Avatar
Thumbs up
Sorry guys, I meant the servo mount: TD340019. The alum. version is TD TD340002. I've been running the alum for a while but as I think about try to lose weight I wonder how heavy the alum servo mount is versus the plastic...
13Maschine is offline
Old 09-20-2014, 05:00 AM
  #16813
jreeves's Avatar
I don't imagine that the servo mounts differ by more than a gram or two. This particular part doesn't seem to be receiving much stress in use, so I personally don't see the need to hop it up to aluminum.
If you really feel the need to reduce weight up front maybe a low profile servo would help?
jreeves is offline
Old 09-20-2014, 05:59 AM
  #16814
13Maschine's Avatar
I upgraded to the Alum version after I broke the plastic part. I've looked into low profile servos as well but most seem to be fairly low torque comparatively. Have you had any experience with a low profile servo in this car?
Old 09-20-2014, 06:04 AM
  #16815
13Maschine's Avatar
Maybe someone can weigh the plastic part for me and I'll weight my alum part?
