Like Tree22Likes
Old 09-13-2014, 08:55 PM
  #16726
vito's Avatar
I got the 22 back on it now its fine now I did order a 20 tooth I got a 21 22 20 17
vito is offline
Old 09-14-2014, 06:56 AM
  #16727
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by the incubus
The most absolutely necessary thing you MUST replace is the skid plat. Replace it with the brass skid plate and that's prettying it. It's NOW said the 19* front blocks are ideal but the masses found the 21* blocks to calm the car down and make it flow better through corners. With my 410, the 19's would force me to have to throttle steer to whip the rear end around on med/slow tight corners and it made it tough to keep a rhythm going because I'd already be on too much power exiting corners and to compensate I'd have to let off and feather the throttle more gently. Once I put the 21* blocks the car was smooth through those types section and I shaved almost 4 seconds off my times consistently.
Good info on the 21's. Gonna try a set. Thanks
tobamiester is offline
Old 09-14-2014, 07:03 AM
  #16728
thephunnel's Avatar
A word of caution, this car is already a bit heavy so depending on your particular track you may need weights in the middle BUT you don't want both the side weights and the rear skid plate. Just one or the other. Generally the rear skid plate achieves a very good balance for the car and all you need to do is tune your suspension depending on track and conditions.
Also, for a replacement wing, don't dick around with anything g other than the Vortex. Been there, done that, and this is the only wing I'll ever buy. The only other wing as durable has been the sweep but the wicker element is too steep for 2wd Buggy but it should be good for 4WD.
Stick with the 22 pinion initially and see how it works for you. If it's too much simply switch to the 20.
Do you think the 21's would be a good bet for high grip carpet as well? Lots of tight turns. I don't even know what I have now. It's the 410RV3
thephunnel is offline
Old 09-14-2014, 09:58 AM
  #16729
i was running a tight carpet track yesterday and ran a 21 so 20, 21 be fine temps were low, running with a 6.5 motor just turned throttle down to 85%
turtle189mt is offline
Old 09-14-2014, 10:00 AM
  #16730
anyone upgrade to rpm ball caps if so what do you need for ball ends to make it work?
Old 09-14-2014, 12:56 PM
  #16731
13Maschine's Avatar
I think the RPM cups are very similar if not the same as what you get with the Lunsford titanium balls stud and turnbuckle kit:
http://www.amain.com/Lunsford-Super-...Cups-6/p244667
I'm not sure what other ball studs work with these cups. I'd like to know other options as well! Although I have had great luck with the lunsford studs so far. I've yet to break one with quite a few cartwheels and the cups last for quite a while. Holes drilled so you don't have to pop them to change settings. Also nice for install as you can use a wrench to help hold the cup while threading the turnbuckle in. Just be gentle and use some lube!
13Maschine is offline
Old 09-14-2014, 01:04 PM
  #16732
vito's Avatar
pay day ill get my tekin rsx esc.
battery I don't know saddle or brick pack
vito is offline
Old 09-14-2014, 02:17 PM
  #16733
Used to run RPM Long Shank Ball Cups RPM73392 on v3 with these ballcups
Metric TC5 Ball studs from Associated ASC31282 10mm, ASC31281 8mm
New plastic/material and balls in v4 seem like a massive improvement so sticking to stockers until/if I have issues.
Old 09-14-2014, 02:38 PM
  #16734
when im coming to the straits on my track and give full throttle, the car often like to kinda jump from side to side before straitening out if you know what i mean?
maybe because of the track? its a bit bumpy and soft. astro
anyone else having this?
running hw 3.1 - with 6.5 motor. 23t pinion and swaybars front and back mounted (stock ones) car is v3.
these_savages is offline
Old 09-14-2014, 02:50 PM
  #16735
I guy's need a new servo for my dex410 ... what should i looking for ... speed or torque !!!
any brand better then the other !!!
thank's
stdu007 is offline
Old 09-14-2014, 03:03 PM
  #16736
i just installed this servo : http://www.hobbyking.com/hobbyking/s...13sec_47g.html
its cheap , fast , strong and so far so good. recommended.
Old 09-14-2014, 03:16 PM
  #16737
thank's
Only run Hitecs personally. A HS-7985MG or HS-8335SH (I love the HS-8335SH as they're Hi-voltage so you can crank up the BEC volts if you want. Or run them in your Nitro Buggy during the warmer months and run them direct from a 2s receiver pack. Reasonable price too) . Can't fault Hitec Warranty Service.
Old 09-14-2014, 03:49 PM
  #16738
is it a loose side to side? whats your diff fluids? where is your slipper set? i turned the 3 insert for anti squat upside down to make it 1.5 which helped calm down the car,
Old 09-14-2014, 03:51 PM
  #16739
thank's
i like a fast servo
Old 09-14-2014, 04:15 PM
  #16740
hmm well its handling very well overall, its just when im giving full throttle it kinda bounces side to side before straitening up and going straight. if i give throttle slowly and more controlled it doesnt happen.
I think im running associated 10 000 sct front and back. im noob lol, i just found a carpet setup somewhere and ran that setup. dont remember which one right now.. feel free to recommend a different setup here. seems a bit weird to have same weight front and back? or is that ok?
can it be that the rear shock oil is a bit to light? cus i think the shocks seemed a bit soft so i put some heavier oil in there but havent tried it out yet.
slipper dont have a clue. havent touched it to be honest, bought the car built and as new. anything i should be checking ?
great car, very quick and responsive. im very happy with it, and its my first and only 4wd.
thanks
