Like Tree22Likes
Old 09-04-2014, 06:31 PM
  #16681
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by likea45
Tried the soldering iron trick and not even a budge. I bought it used so who knows what kind they used :/. Thinking I might just pick up the new v4 2-way slipper.
You could always try using a drill close the same size as the threads, or slightly bigger. This way when you start drilling the head it will pop off. Then disassemble the unit, heat the remaining screw and grab it with pliers. Should work fine....
Bman's 3XNT is offline
Old 09-04-2014, 06:47 PM
  #16682
the incubus's Avatar
Trader Rating: 17 (100%+)
Forget the soldering iron. A butane torch will liquefy the loctite to allow you to remove the screw. Also be sure your tool has crisp edges. If not, Dremel off a section or grind down a bit to expose a fresh edge to improve the chances of getting the screw to turn out.
the incubus is offline
Old 09-05-2014, 05:12 PM
  #16683
vito's Avatar
vito is offline
Old 09-06-2014, 05:42 AM
  #16684
jreeves's Avatar
Looking good Vito, but way too clean! Need to finish and get that buggy in the dirt!
BTW, I notice your servo lead coming out on the saver side, I've always routed mine out the opposite side. Is there a concensus on what works best?
jreeves is offline
Old 09-06-2014, 09:44 AM
  #16685
13Maschine's Avatar
Looks good Vito! What kind of ESC and motor are you planning to run?
13Maschine is offline
Old 09-06-2014, 09:47 AM
  #16686
vito's Avatar
fantom 6.5 ion 4 with tekin rsx esc
vito is offline
Old 09-06-2014, 10:05 AM
  #16687
vito's Avatar
the bolts that hold the servo down are a tad to long they stick out of the back side of the mount? the servo is a savox 12 57
vito is offline
Old 09-06-2014, 10:58 AM
  #16688
Konich's Avatar
You need to put a spacer on your servo linkage to line it up. I'd also put a plastic spacer in the middle as well (where the thread is showing)
Konich is offline
Old 09-06-2014, 11:01 AM
  #16689
vito's Avatar
put spacer under the ball stud on the horn?
vito is offline
Old 09-06-2014, 11:14 AM
  #16690
Konich's Avatar
Put a spacer behind the ball stud on the servo horn to make the linkage straight instead of an angle. On the linkage itself put a black spacer in between the two ends.
Konich is offline
Old 09-06-2014, 11:36 AM
  #16691
vito's Avatar
vito is offline
Old 09-06-2014, 11:49 AM
  #16692
Konich's Avatar
^^There you go, now add the plastic spacer to the linkage and its money!
Konich is offline
Old 09-06-2014, 12:32 PM
  #16693
vito's Avatar
do the make a metal servo horn I dint see one on the drango site
vito is offline
Old 09-06-2014, 03:22 PM
  #16694
Pittster's Avatar
I run this servo horn from durango, if you get another brand make sure it has zero offset and isn't to long as it will hit the front center shaft.
TD340064
http://www.team-durango.com/part-inf...artNo=TD340064
Pittster is offline
Old 09-06-2014, 08:21 PM
  #16695
looks good vito but get yourself a alum servo horn plastic will strip first day
turtle189 is offline
