Like Tree22Likes
Old 08-27-2014, 09:13 PM
  #16636
rcjunky1's Avatar
I'll try getting picks of mine with the v3 slipper and dual slipper, ujs front and rear
rcjunky1 is offline
  #16637
tobamiester's Avatar
Trader Rating: 359 (100%+)
Finished up my v4 today. Nice evolutionary upgrades from v2/v3. Hope to get it on the track friday..
tobamiester is offline
Old 08-27-2014, 09:39 PM
  #16638
13Maschine's Avatar
Why is it hard to understand that my shafts are 68mm and some are 70mm? There are two part numbers on the durango site for each length?
13Maschine is offline
Old 08-27-2014, 09:40 PM
  #16639
13Maschine's Avatar
looks good TobaMeister! How do you like your viper gear?
Old 08-27-2014, 09:48 PM
  #16640
13Maschine's Avatar
Originally Posted by Konich
Also what rear brace are you using? Plastic, Carbon Fiber or adjustable alloy? For some reason it sounds like you have more flex than it should. Any of the chassis screws stripped (ie: Front diff hoop, bulkheads, etc)? This is hard to notice but any flex in those area's will increase the driveshaft travel.
I'm using the Carbon fiber brace.
Old 08-27-2014, 10:15 PM
  #16641
the incubus's Avatar
Trader Rating: 17 (100%+)
I'm not saying you have one or the other. But I do find it peculiar that you'd have received shafts shorter than the norm that would lend themselves to pop out. Unless your out drives were somehow machined too short?
the incubus is offline
Old 08-27-2014, 10:23 PM
  #16642
Pittster's Avatar
just checked my mates DEX410v3 and he has 70mm CVd's so looks like maybe it was a running change in the V3 to stop the issue. I never had one pop when I ran my 68mm but.
13Maschine : Go the V4 UJ shafts there better overall.
Pittster is offline
Old 08-27-2014, 11:29 PM
  #16643
rcjunky1's Avatar
the v3 was 68mm with the longer outdrive, the previous versions had 70mm with a shorter outdrive, the new UJ's are 70mm
rcjunky1 is offline
Old 08-28-2014, 01:13 AM
  #16644
Smile
Nice car..can I suggest that it is better to run the motor wires over the front shaft
It just helps to keep the air moving around the motor. I had mine like yours and it kept over heating...my 2 cents...great car enjoy it
Aussie RC is offline
Old 08-28-2014, 04:14 AM
  #16645
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Looks great Toby, welcome back!! Hope to see you around this indoor season.....
Bman's 3XNT is offline
Old 08-28-2014, 05:27 AM
  #16646
Very much. The VTX10RBE is perfect for wheeler and runs cool. The Mod motors are pretty decent too. With the Progauge, makes trackside adjustments a breeze. 365 day warranty on the ESC can't be beat!
Old 08-28-2014, 05:33 AM
  #16647
Yeah thought about that. Ran my v2 and v3 like this so fairly confident it'll be fine. I have that option if it gets too hot...Motor always gets a little 'spicey' after a run.
I actually put full ceramics in my v2 to help bring the heat down as the bearings were terrible in that car.
Old 08-28-2014, 05:34 AM
  #16648
Thanks bud. Yeah, back to offroad this fall/winter
Old 08-28-2014, 08:15 AM
  #16649
rcjunky1's Avatar
motor wires like that is fine, running them over its hard to get clearance of the body and center drive shaft when removing the slipper. looks good.
rcjunky1 is offline
Old 08-28-2014, 08:38 AM
  #16650
I run mine over the top and it's just as easy as when I ran them below, but it looks nicer and is more comfortable to work on if you have to remove the motor or ESC for any reason. You just need to leave enough slack for clearance for center assembly removal. And it doesn't touch my lid at all.
