Like Tree22Likes
Old 08-07-2014, 08:18 PM
  #16441
ekt
ekt's Avatar
Originally Posted by vito
whats the stock rr anti squat setting ?
The '3' insert to give 3° antisquat.
ekt is offline
Old 08-07-2014, 08:19 PM
  #16442
vito's Avatar
up down ?
vito is offline
Old 08-07-2014, 08:23 PM
  #16443
vito's Avatar
looks like the 3 is down?
vito is offline
Old 08-07-2014, 09:14 PM
  #16444
ekt
ekt's Avatar
Yeah, 3 down. Check out TDs guide on the inserts for more info http://www.team-durango.com/blog/201...quat-settings/
ekt is offline
Old 08-07-2014, 09:24 PM
  #16445
vito's Avatar
got a link to a starting set up the book has little in fo in it
vito is offline
Old 08-07-2014, 09:39 PM
  #16446
rcjunky1's Avatar
http://www.petitrc.com/setup/durango...Raceway201406/
That's the set up to use IMO. I use the 1.1mm front bar and just changed the front inner camber link to 3 instead of 2 and it was really good last night. Seems to work well on a variety of surfaces.
rcjunky1 is offline
Old 08-08-2014, 10:18 AM
  #16447
vito's Avatar
whats the deal with the little spacer on the rear hing pin shaft theres a paper with some new one to use its not in the book?
vito is offline
Old 08-08-2014, 05:25 PM
  #16448
ekt
ekt's Avatar
There was an error in the manual, it requires a thicker spacer than what was listed, fixed on the additional page.
ekt is offline
Old 08-10-2014, 10:32 AM
  #16449
rcboy1's Avatar
Is there a way to convert this car over to 12mm hexes? Maybe use b4 hexes?
rcboy1 is offline
Old 08-10-2014, 08:14 PM
  #16450
Smokem Racing's Avatar
Hey guys. Shameless plug time...
For those who wants to put their Euros winning DEX410v4's on a diet. We're currently doing some "Deals of the Week" in our online shop. One of these deals is on the Hiro Seiko 69816 Titanium Screw Set for the DEX410v4 buggy - with no less than 109 screws - at a massive 25% off.
You can find this and our Smokem shock towers by following this link - http://bit.ly/smokem-dex410.
Many thanks to those who have tried our shock towers and recommended them to friends. Happy racing!
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-hs-69816.jpg
Smokem Racing is offline
Old 08-11-2014, 02:02 PM
  #16451
13Maschine's Avatar
Smile
Definitely. I like to use the Avid 12mm hex set:
http://www.avidrc.com/product/5/acce...cessories.html
...but you will probably need a selection of spacers to make it all work properly.
That being said I've found the 14mm hexes from Spec R to be some of the best. The offsets for aftermarket 12mm wheels don't have quite the same offset as the Durango wheels so certain suspension link settings will rub. It's very close though and I do sometimes run the 12mm setup. I use the Shumacher K1 hexes up front. http://www.amain.com/Schumacher-Raci...-Set-2/p273732
This way you should be able to use the EVO wheels from AKA. Up front the 22-4 wheels will work. Offset seems very close if not same.
there are many posts and pics about different 12mm setups in this thread. Perhaps try to search if you need more info. Let us know and we will try to help though!
13Maschine is offline
Old 08-11-2014, 04:52 PM
  #16452
how much is everyone's Durango weighing in at?
LiL_JaSoN is offline
Old 08-11-2014, 05:10 PM
  #16453
Pittster's Avatar
1740g with a shorty pack, carbon chassis, 30g rear skid plate weight, front and rear sway bars, 30mm fan with custom bracket on motor, composite diff gears.
Its to heavy for 17.5 but I change a few things and get it down to 1700g, but they affect the way I like it handling. (skid weight and sway bars)
Pittster is offline
Old 08-11-2014, 05:17 PM
  #16454
nice to see another 17.5. I thought I was the only guy running 17.5t in this heavy thing. What gearing are you running?
I have mine running at 1670-80 atm.
that's with shorty, 30g brass skid weight, and tresrey 30g diff weight, and 5g on each side of shorty - so 70g added weight all up
Old 08-11-2014, 05:33 PM
  #16455
rcboy1's Avatar
Thank you for the help I would definitely like to use 12mm wheels as those are far more common. I assume you mean the rear wheel standard offset isnt right for this car. I will certainly go through the thread for solutions I was just wondering what people are using now; what the lastest setup is.
For the avid hexes are you using both the front and rear that come in the set?
rcboy1 is offline
