Like Tree22Likes
Old 07-24-2014, 09:57 PM
  #16351
13Maschine's Avatar
@vito: I've seen hard copy manuals on ebay. V3 and V4 manuals.
13Maschine is offline
Old 07-25-2014, 05:41 AM
  #16352
@ Vito, I think I have the hard copy manual for my v3. If I find it I can send it your way. I downloaded the digital copy to my phone and use that if I ever have a question. let me know.
TLRrunner is offline
Old 07-25-2014, 07:39 AM
  #16353
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jpcopeland1
Where I am, no. But I finally have it to where it is smooth. Shimmed the 2way slipper so that it is not super tight, but does not move nearly as much. Also when I had originally built the car, I forgot to thread lock the screws that hold the spindles to the caster blocks and one came unscrewed and threw the little knuckle spacer and washers out. Got a set of new ones, they were silver, and are .5mm too long causing way too much play on the front end. Took the set of black ones out of my ST, and holy crap, it's not trying to kill its self anymore. Problem is those knuckle bushings are nowhere to be found and now my trucks front end is screwed. When I get the D413 built I will take them both and see what drives better with minimal tweaking, the winner stays, the loser ends up in the for sale thread.
Well at least you've figured out the cause. As for the knuckle spacers, can you say Dremel? LOL
You can mark them with a Sharpie and then take an old screw and slide it into the knuckle as a means to hold the knuckle level pretty securely so you can take it down enough to where it needs to be.
FYI, all the 410's I've seen the steering knuckles sit about .5mm outside the spindles top and bottom, as does mine and they are fine.
the incubus is offline
Old 07-25-2014, 09:07 AM
  #16354
jreeves's Avatar
Does anyone have spares of the anti-roll bar holders, the plastic pieces that come on the front bulkhead tree TD330003?
My roller came without them and I have all the roll bar parts except these.
PM me with a price if you can spare some.
jreeves is offline
Old 07-25-2014, 04:14 PM
  #16355
13Maschine's Avatar
Smile
Incubus: I really think it's the driveshaft length. The extra 2mm of length on the center rear driveshaft would keep it in the socket AND allow the car to flex a little bit. Right now it's just too close to the edge. I"ll take a pic later…when I get new driveshafts I'll post comparison pics
Originally Posted by Bman's 3XNT
@13Machine. Glad to hear you got your car straightened out!! What advice did you use, so I can use it again in the future.... as for the driveshaft. Stock v3 is 68mm long. They do have a cvd in 70 or the new UJ is 70 too if I remember correctly. Now to go beat up some 413's and 44's......
Old 07-25-2014, 04:19 PM
  #16356
vito's Avatar
what rims fit this car its a v 3 mod to 10 14 12mm hexs the owner told me losi rimes fit with the mod hexs
vito is offline
Old 07-26-2014, 01:00 AM
  #16357
13Maschine's Avatar
I haven't had a chance to go through all kinds of piston configs and oil combo's but I think that running 3 hole up front is not enough pack. This seems to slam the front of the chassis a bit on drop test (LOW drop test too) and I suspect this was part of the reason the car was so hard to drive last time out before my most recent changes. I'll post a full setup soon as I think it's pretty close to being dialed. By the end of my practice session last time out at OCRC I was getting close to breaking in to the 19 second lap times posting 20.1, 20.2, 20.3 etc. Just a few things to work out and I think I could be there. This was with a lot of traffic too….Only two other drivers on the track that day were getting into 19 second lap times. Mike Truhe and Frank Root as far as I could tell.
Perhaps faster with Dirt webs. I only had Ions and barcodes to test….
Old 07-26-2014, 06:29 AM
  #16358
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Great work and keep us posted. In my V5 I run 1.4x2 with 30 and 1.5x3 with 32.5. In my V5.2 (testing) 1.0x4 40 and 1.0x4 40. The first combo seems a bit better right now.....
Bman's 3XNT is offline
Old 07-26-2014, 08:41 AM
  #16359
13Maschine's Avatar
@Bman: I've done some small piston testing too with my own drilled sets. 2x1.2, 2x1.3 with 20 and 25 wt. Did you make a piston area chart? I think I remember you quoting total area for different piston configs….wanna share?
I assume you usually end up heavier in the front oil wise? so 1.5x3 with 32.5 in the front?
Old 07-26-2014, 09:58 AM
  #16360
vito's Avatar
is the new two way slipper a good upgrade to get
vito is offline
Old 07-26-2014, 05:00 PM
  #16361
ekt
ekt's Avatar
@Bman: I've done some small piston testing too with my own drilled sets. 2x1x2, 2x1.3 with 20 and 25 wt. Did you make a piston area chart? I think I remember you quoting total area for different piston configs….wanna share?
Was this what you were after? http://www.rctech.net/forum/12810859-post4932.html
ekt is offline
Old 07-26-2014, 06:01 PM
  #16362
1.4x2 32.5 front and 1.5x3 32.5 rear on my v5. The stock car I ran 1.5x2 35 front and 1.6x2 32.5 rear.
Old 07-26-2014, 06:27 PM
  #16363
Trader Rating: 166 (100%+)
Not really. It doesn't really work as advertised. Took mine to LRH. Was much better, but for my driving style the HB D413 is a much better car, so I will begin parting the DEX out. Let me know what you guys need for spare parts. Car has a 3 run track day on it. Zero signs of wear on any of it.
jpcopeland1 is offline
Old 07-26-2014, 10:33 PM
  #16364
vito's Avatar
I passed on the use one ill get a new v 4 kit pay day
vito is offline
Old 07-27-2014, 07:58 AM
  #16365
That post was meant for anybody needing new parts. I have a pant load of unopened parts for the buggy, a lot of it is back ordered stuff.
