Like Tree22Likes
Old 07-01-2014, 11:01 PM
  #16186
the incubus's Avatar
Trader Rating: 17 (100%+)
I used blue Loctite on the front deck/bell crank posts and it's been fine. Red is much too strong for this application, but if need be you clan heat the post with either a heat gun or blow torch to liquify the red Loctite and turn the screws out.
the incubus is offline
Old 07-01-2014, 11:35 PM
  #16187
rcjunky1's Avatar
I just make sure they're tight with 2 2mm drivers :P
rcjunky1 is offline
Old 07-02-2014, 12:14 PM
  #16188
Dino_D's Avatar
Originally Posted by jpcopeland1
So I have the steering where I want it for the most part. problem is I have a problem with the tail end wanting to step out. Running 6X1.0 dual taper pistons rear, 5X1.0 fronts, 35 wt. oil in front, 27.5 wt. in rear, upper camber links in the rear tower, upper camber links in the front tower. All is good until I get to a very tight S turn, then the apex happens and I go whipping around. Tires are typos which offer a lot of grip, and steering at my practice track. Need help getting the tail end to stay down. Tried Ryan Lutz Reedy Race setup, was not good for this layout in very tight sections. Any help would be appreciated. This is a new V4 buggy, running saddles in the rear with the chassis weight set trying to keep it stuck on the track.
Sounds like your car has too much roll. You need to use heavier oil to control the roll. Pistons control the pack. The smaller holes are good for big jumps, but not so great on bumpy stuff. It makes the car nervous.
I run 42wt with 2x1.6 front (same almost the ratio as your 5x.10) amd 30wt rear 2x1.7 (similar to your 6x1.0). Difference is the bigger holes are more forgiving. Also I use 1.3 front sway on big tracks, 1.1 on smaller tigbt tracks. 1.5mm sway in the rear.
Dino_D is offline
Old 07-03-2014, 06:59 AM
  #16189
hi i just bought a used v3. what upgrades are recommended from the v4? so far i take it that the u joints are good upgrades and so are the molded diff gears anything else?
hockeyrules16 is offline
Old 07-03-2014, 07:27 AM
  #16190
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Does anyone know where I can get these in the states? Thanks!
http://www.redrc.net/2014/07/rdrp-de...-shock-towers/
Bman's 3XNT is offline
Old 07-03-2014, 07:38 AM
  #16191
MaximeRoy77's Avatar
Would this wing fit the DEX410 ?
Or any black alternatives ?
Tx
MaximeRoy77 is offline
Old 07-03-2014, 08:10 AM
  #16192
they were just released. I dunno if anyone has them yet. I've always bought my RDRP stuff from amain.
TLRrunner is offline
Old 07-03-2014, 08:16 AM
  #16193
rcjunky1's Avatar
just get the 2010 spec non fine tune towers, no? My 5mm tower is a tank, had a massive tumble down the strait last night, popped 2 or 3 tie rods, a shock eyelet and broke both front bulkheads. One cheap part from a massive wreak, I'll take it (100% my fault, I screwed up trying to pass a slow car on the strait, instead hit them hard at WOT)
rcjunky1 is offline
Old 07-03-2014, 08:48 AM
  #16194
Does anyone know the diameter of the inner rear hinge pins? Does anyone know of alternative inner rear hinge pins that can be used? I need a replacement but don't have one nor can I wait till my order comes in. I'm supposed to be racing tonight.
Old 07-03-2014, 09:41 AM
  #16195
A few months ago I was in a pinch and all I had was a busload of Associated hinge pins which were too thick so I found a small tube I had in my garage and used a pumice bit on my Dremel set to the highest setting and hit the Associated pin at any angle that would force it to spin and push inward to the cylinder until I took the hinge pin down just enough that it slid into the A-arm firmly. From there I hit it with my metal bristle bits to smooth it out and polish it slightly and then went over it with a stripping bit and some Colegate to to make it smoother. I got through that weekend just fine and the damn thing was actually way stronger than the stock Durango pins.
Old 07-03-2014, 09:50 AM
  #16196
rcjunky1's Avatar
they're 3mm in diameter, you might be able to find some 3mm drill rod locally
rcjunky1 is offline
Old 07-03-2014, 10:39 AM
  #16197
Thanks, I'll keep a look out!
Old 07-03-2014, 12:15 PM
  #16198
rcjunky1's Avatar
why not just get td330002? is it not the same?
rcjunky1 is offline
Old 07-03-2014, 12:43 PM
  #16199
Not sure. They made it sound like its better..... I had a new TD one break/shear off for no reason. Could of been bad weave/laminate. Just wanted to try something else.
Old 07-03-2014, 06:42 PM
  #16200
LOSI123's Avatar
Trader Rating: 63 (100%+)
Most hudy and EDs hex drivers are 3mm so if you have a worn out tip on one just dremel it to size, for front and rear length just look in the manual
LOSI123 is offline
