Like Tree22Likes
Old 06-30-2014, 03:38 AM
  #16156
dex410 i built to race in stock class with short (5g weight on each side, 10g under the diff, and brass skid plate. Might put the 10g side weights back on.
Pretty much a v3 with smallbore shocks (might put big bores back on), titanium turn buckles, machined diff, plastic gears, d-joint drive shafts, tresrey steering/servo saver, 21" front caster, aluminium spur holder and all the needed option parts such as diff hoops etc
LiL_JaSoN is offline
Old 06-30-2014, 07:04 AM
  #16157
rcjunky1's Avatar
Originally Posted by Pittster
Hmm defective 5mm tower you say.
Seems the fine tune tower is not really available right now
http://www3.towerhobbies.com/cgi-bin...?&I=LXCCZV&P=7
Has anyone used atomic carbon towers?
Are they just as tuff ?
http://www.greathobbies.com/producti...d_id=TDR330375
There was one run of v3 kits that shipped with the 5mm front tower, needed some work to fit but you'll never break it, its the same thickness as the 1/8 towers.
rcjunky1 is offline
Old 06-30-2014, 10:23 AM
  #16158
jreeves's Avatar
Has anyone here tried to fit the Turnigy nano-tech ultimate square pack in a v3?
http://www.hobbyking.com/hobbyking/s...uare_Pack.html
Not roar approved so I'm sure that stops alot of you, but if it fits nicely it would offset the weight kit since it's 50 grams heavier than the saddles.
jreeves is offline
Old 06-30-2014, 10:56 AM
  #16159
rc_dude's Avatar
Trader Rating: 131 (100%+)
I wondered when they would come out with something higher than 65C lol
Price wise they are good but my 5100's are around 3.85v/c after most runs already
rc_dude is offline
Old 06-30-2014, 11:07 AM
  #16160
jreeves's Avatar
Well I ordered a couple anyway so I'll be the guinea pig
Assuming they'll fit, I'll have to see how run time is once they're broken in.
jreeves is offline
Old 06-30-2014, 11:10 AM
  #16161
rc_dude's Avatar
haha sounds good. I'm disopointed in the 2C charge rate though
rc_dude is offline
Old 06-30-2014, 11:34 AM
  #16162
Trader Rating: 71 (100%+)
Reedy square packs fit fine, so I'd guess these would. Square packs clean up the wiring nicely on this already cluttered car.
negatv1 is offline
Old 06-30-2014, 12:16 PM
  #16163
13Maschine's Avatar
Would like to hear more about the HobbyKing square pack when it's all broken in What charger do you use? I've had pretty good luck with my Turnigy's so far. I have a Junsi 308Duo and I also have some SMC short packs as well.
13Maschine is offline
Old 06-30-2014, 12:26 PM
  #16164
jreeves's Avatar
I'm using an older Venom Pro charger, so I've only got 5 amps to work with for charging. It would be nice to charge at higher C, but for now I'll settle with 4 packs charged when we go to the track and have one on the charger at sub 1C. Trying to do all this on the cheap for club level racing. I imagine the serious racers among you have no use for the extra weight of these packs anyway.
I suspect the 2C rating on these may have to do with the number of cells in the 2s square pack vs the 2s3p saddle packs, but I'm just guessing.
jreeves is offline
Old 06-30-2014, 01:56 PM
  #16165
rc_dude's Avatar
the 3p just increases the capacity, witch in turn increases the charge amps but not C rating since it's a function of capacity anyway. All the ultimate packs are 2C it seems, so I bet they just focused of highest discharge and largest capacity and disregarded the charge rates to an extent
I use an icharger 20A charger and a parallel charge plate, of course the 5100 saddles have a dang 10C charge rate...lol
And my good friend has a HobbyKing HKC6 and just this past weekend I found that, according to both of my chargers and my balencer, it was charging his cells to 4.19 and 4.24 volts...this has been going on for the past year with no problem, but that's sketchy...
rc_dude is offline
Old 06-30-2014, 02:15 PM
  #16166
13Maschine's Avatar
@rc_dude: I noticed with my old bantam charger that I would sometimes get an unbalanced charge like this. I think this actually came from my balance cable being damaged, shorting out just a bit and providing a false reading. When you start getting into mV readings it's 100 times more sensitive so any change in wire or resistance can give a weird reading. I was able to verify this with my voltmeter, so perhaps double check your balance cable?
Old 06-30-2014, 02:45 PM
  #16167
rc_dude's Avatar
Both my ichargers and my HiTec cell checker said the same thing for all 3 of the batteries he charged on his charger, so i'm pretty sure it's the charger. I told him to look up online how to calibrate it. and the resistance in the wire will only effect it with current flowing (yes to take a reading there must be a small amount of current flowing) but the balancer/cell checker can't drain much at all and the charger sitting a monitor or a .05A charger wouldn't be enough to make a difference unless only one or two strains were still holding together.
rc_dude is offline
Old 06-30-2014, 05:14 PM
  #16168
Carlos69's Avatar
Since I like to keep my leads in 24/7 .... I'd like to see a square lipo with offset balance lead or with terminals positioned on the longer side so the balance lead doesn't clash with the drive line ...
Carlos69 is offline
Old 06-30-2014, 05:28 PM
  #16169
13Maschine's Avatar
@Carlos: you charge your battery in the car? and you lave the balance cables plugged in?
Old 06-30-2014, 06:40 PM
  #16170
Pittster's Avatar
I drilled a small hole in the middle of my battery strap in my 410 so when I run my shorty to charge it in the car I just remove the spur.
Getting the battery pin in over and over is a pain with a shorty nanotech battery
Pittster is offline
