Like Tree22Likes
Old 06-24-2014, 10:02 AM
  #16141
13Maschine's Avatar
Smile
Originally Posted by azenis
Yup a V4 picked it up second hand yesterday, only done two race meets and has a few mods like the weight kit.
How about some under the hood shots!
13Maschine is offline
Old 06-24-2014, 07:11 PM
  #16142
azenis's Avatar
Not much to see under the hood, it is all empty at this point. Yet to get a motor, ESC and RX for it.
azenis is offline
Old 06-28-2014, 11:10 PM
  #16143
LOSI123's Avatar
Trader Rating: 63 (100%+)
Was wondering if anyone knows if the machined diff ring gear make this car any quieter?
LOSI123 is offline
Old 06-28-2014, 11:15 PM
  #16144
INFERN0's Avatar
The machined gear is only slightly quieter. It's more about gear mesh in the diffs and your cv joints. If those are done right the car can be quiet. It won't be as quiet as a belt drive car tho so you can not compare.
INFERN0 is offline
Old 06-29-2014, 12:33 AM
  #16145
LOSI123's Avatar
Ok thanks, do you reckon its the mesh of the ring and drive gear being to tight or to loose that would make it very loud?
LOSI123 is offline
Old 06-29-2014, 07:54 AM
  #16146
INFERN0's Avatar
Too tight will be very loud and cause premature bearing failure. Too loose will be quiet till the teeth strip out. I shim mine to get the same mesh as my motor pinion to spur. Then I use red grease on the gears to keep em lubed and quiet.
INFERN0 is offline
Old 06-29-2014, 09:11 AM
  #16147
13Maschine's Avatar
I've found the secret to getting the 410 to be a little quieter is to make sure you shim the differentials properly. You have to make sure the diff is aligned properly. it takes some guesswork, install a shim, reassemble and spin to check. Should be easy to feel, usually you will have a tough spot when you roll it around and that means you need another shim. Keep adjusting until it's perfect.
Another tip is to set your gear mess with the whole center gear/slipper setup out of the car. It's only a few screws in the bottom and if you use the radio plate you can take the whole electronic setup out pretty easily. Definitely recommend doing this. Secondly it allows you to much more easily setup the Pinion and Spur mesh. Otherwise you will need a short driver to reach the motor screws while the motor is installed in the car.
Good luck!
Old 06-29-2014, 01:32 PM
  #16148
ridgeback's Avatar
Trader Rating: 15 (100%+)
Default DEX410
My DEX is only noisey when my cv joints are either worn out or are lacking maintanence. Switching over to the new U-joints takes care of the noise for me. Ive never had my diffs make noise. Poorly maintained or worn CV joints are the biggest culprit.
ridgeback is offline
Old 06-29-2014, 04:02 PM
  #16149
LOSI123's Avatar
Thanks guys
LOSI123 is offline
Old 06-29-2014, 05:01 PM
  #16150
Pittster's Avatar
So snapped the top right off my carbon front tower which I don't really blame it for doing (landed straight on it off a large jump) Now my V3 410 has a had a hard life done many seasons of racing so the v3 carbon Fineadjustment tower I think is really tuff so im going to grab another.
Question is do I need to CA glue the edges of these towers or they dont require it ?
Pittster is offline
Old 06-29-2014, 06:02 PM
  #16151
LOSI123's Avatar
The V4 has the same size shock standoff front and rear in the kit as standard, I was looking to get the quick change ones but there is a front and rear that look to be different sizes, does anyone know which of these 2 are the same size as the origianl black plastic ones that come with the V4 kit?
http://www.amain.com/product_info.ph...ck-Mount-Set-2
LOSI123 is offline
Old 06-29-2014, 06:47 PM
  #16152
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
You want the rears for both front and rear. They are close to the black plastic stand offs.
Bman's 3XNT is offline
Old 06-29-2014, 07:05 PM
  #16153
LOSI123's Avatar
Thanks bud
LOSI123 is offline
Old 06-29-2014, 08:19 PM
  #16154
rcjunky1's Avatar
CA will help for sure. The non fine tune tower is stronger but not nearly as adjustable, a tower in between would of been nice. The 'defective' 5mm tower is king though
rcjunky1 is offline
Old 06-29-2014, 10:41 PM
  #16155
Pittster's Avatar
Hmm defective 5mm tower you say.
Seems the fine tune tower is not really available right now
http://www3.towerhobbies.com/cgi-bin...?&I=LXCCZV&P=7
Has anyone used atomic carbon towers?
Are they just as tuff ?
Pittster is offline
