Like Tree22Likes
Old 06-14-2014, 10:20 PM
  #16081
onekiwi's Avatar
Put a shim under the rear drive shaft / diff holder loop
onekiwi is offline
Old 06-15-2014, 12:04 AM
  #16082
Pittster's Avatar
Originally Posted by 13Maschine
I'm not sure why but I can't get my SMC shorty to fit down the middle like this. I can't fit my battery wires in and I can't put the strap down. It's also fairly tough to put the battery in in the first place, without squeezing the plastic portion of the motor mount out of the way.
I had to modify my spur mount to fit my Turnigy batteries and battery strap to do the shorty.
Pittster is offline
Old 06-15-2014, 06:13 AM
  #16083
J Stark's Avatar
Is Jorn Nueman's Cactus set up posted anywhere or any of his other set up's?
J Stark is offline
Old 06-15-2014, 07:19 AM
  #16084
rc_dude's Avatar
Trader Rating: 131 (100%+)
Originally Posted by MaximeRoy77
Guys,
based on your recommendations of not going with higher than 25mm LIPOs , I bought 2 pairs of Turnigy nano-tech 4850mah 2S3P 50~100C Hardcase Lipo Saddle Pack, specs:
Capacity: 4850mAh
Voltage: 2S3P / 2S Cell / 7.4V
Discharge: 50C Constant / 100C Burst
Weight: 132g EA (290g Total Inc Wires)
Dimensions: 69x47x25mm EA
Balance Plug: JST-XH
Discharge Plug: 4mm Bullet-connector to your own custom plug
Model no: NC4850.2S3P.50
And they do not fit in height, can't close the lid ????
Should they ? Or do I need to make some mod to the DEX410v3 ?
Thanks for the help in advance
Max
I'm running the 5100 and 4850mah turnigy pack no problem. But I took a grinder and made a small point on the end of the pins going through the diff and the battery holder so they align and fit easier. After a few runs the plastic will loosen up a little bit so it gets easier to install them. I do recommend grinding the tip just a little bit though, it allows the pin to align the parts without much effort
rc_dude is offline
Old 06-16-2014, 04:19 AM
  #16085
MaximeRoy77's Avatar
^ Thanks , will do and report back ;-)
MaximeRoy77 is offline
Old 06-16-2014, 04:22 AM
  #16086
onekiwi's Avatar
Anyone running this buggy as a 2wd?
onekiwi is offline
Old 06-16-2014, 08:03 AM
  #16087
13Maschine's Avatar
I think Bman has tried to run his 410 as a 2wheeler. He called it a 310. We have some pictures and discussion here:
http://www.rctech.net/forum/electric...e-parts-d.html
13Maschine is offline
Old 06-16-2014, 08:04 AM
  #16088
13Maschine's Avatar
@Pittster! That's a great idea Thanks! I'd love to see them make it easy to use either style pack on the next car!
Old 06-16-2014, 02:36 PM
  #16089
it is really really tight with a shorty, it is a little harder to put the spur in as it squeezes the plastic, and the battery pin is so hard to get in, i have the wires at the back and they fit either side of the strap, it is so tight that it doesnt move and the wires are close to the strap and hold it, i dont run foam either side.
it works on a track were, you have enough rear grip and not enough steering, as it gives a little less rear grip and more steering, quite a lot more steering!
av4625 is offline
Old 06-16-2014, 02:48 PM
  #16090
13Maschine's Avatar
yeah....I don't need more steering as it is! . That being said For me I'd really only want to do this for a 13.5 or 17.5 class given the weight balance issue. I'm sure if I end up doing a lightweight version of my 410v3 with shorty after I upgrade to a V4 then I will go crazy modifying it. I just like to be able to fix the car with off the shelf parts if possible so I can quick get back on the track. I do love modifying and fabricating though!
Old 06-16-2014, 05:29 PM
  #16091
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Not all shorty packs are a direct fit. I run the Venom 3800 in my 410 without modification. I've got two SMC 4600 shorties but they will not go in without modifying the battery brace. Also, the SMC battery terminals are slightly more towards centre, which is also not ideal. Maybe Leo (ekt) can put up a list of shorties that are a direct fit on his website, as this question comes up fairly often.
ajj is offline
Old 06-16-2014, 09:20 PM
  #16092
ekt
ekt's Avatar
Sounds like a good idea, I'll work on adding it to the site. If anyone else knows of shorties that are a direct fit, let me know. I'll also add links to the various mods I know of to get them to fit.
ekt is offline
Old 06-17-2014, 08:37 AM
  #16093
rc_dude's Avatar
So what motor would you guys recommend in this buggy? I have 550 motors and a Orion 6.5T but I feel the 550's would be too much and the Orion doesn't seem like a very good idea for 2s on an off road track.
rc_dude is offline
Old 06-17-2014, 08:47 AM
  #16094
13Maschine's Avatar
I actually ran the Orion VST Pro 6.5 Motor for quite a while in mine, I think it's almost perfect. Unless your on a really small track. Then maybe an 8.5T might be better...The small indoor track north of here often, the 13.5 class of wheelers is just as fast as the open class....
Old 06-17-2014, 08:57 AM
  #16095
rc_dude's Avatar
hummm....i'll give it a try. I was mainly concerned about the dirt since it's got those openings in the can. But it's a medium sized track I guess, bigger than the indoor ones I've seen but too small for 1/8 scales and there got to redo it soonish to be more technical and a lot more track in the same space
rc_dude is offline
