Like Tree22Likes
Old 06-09-2014, 08:09 PM
  #16066
rc_dude's Avatar
Trader Rating: 131 (100%+)
Originally Posted by ekt
The v4 arms have captured outer hinge pins.
The drive train is more efficient with UJ center drive shafts and redesigned front and rear drive shafts. It also has composite spider gears and cross shafts for less rotational mass. The v4 also comes with a 2-way center slipper.
The v4 comes standard with 19 caster blocks instead of the 17 in the v3 kit and it comes with a new cab forward body.
Got it, thanks! looking to trade a dex408 for a dex410, if not, i'll sell then buy. lol
A couple guys at the track are hoping they'll get a 4WD 1/10 buggy class going again
rc_dude is offline
Old 06-10-2014, 08:16 PM
  #16067
Originally Posted by Bman's 3XNT
Yes +10mm
Does it take out the twitchyness out of the car? i like how aggressive the steering can be on a 410 and the rear still be planted!
av4625 is offline
Old 06-11-2014, 04:11 AM
  #16068
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
To some degree. It can be still aggressive according to setup. The length was needed to use stock TD components. You can still run the rear arms forward to achieve that aggressive feel.
Bman's 3XNT is offline
Old 06-11-2014, 07:10 PM
  #16069
13Maschine's Avatar
Hello All, Since my local shop has stopped carrying parts and I can't help but always want to modify everything I've created a new thread for the Durango kids:
http://www.rctech.net/forum/electric...e-parts-d.html
Please join us! Tell your friends too!
13Maschine is offline
Old 06-11-2014, 08:16 PM
  #16070
mine are 1mm from being full forward as is lol your car looks pretty cool though!
av4625 is offline
Old 06-11-2014, 10:04 PM
  #16071
13Maschine's Avatar
Guys who are using the new front arms, have you tried moving the castor blocks back or forward ? I think Ryan lutz was saying he likes to run it in the middle for a slightly less aggressive feel over the older arms which didn't have room for spacers.
Old 06-12-2014, 10:51 AM
  #16072
Dino_D's Avatar
I prefer caster blocks full forward. Its less aggressive. Moving it more to the rear will make the steering more aggressive (shorter wheelbase)
Dino_D is offline
Old 06-12-2014, 03:02 PM
  #16073
MaximeRoy77's Avatar
Guys,
based on your recommendations of not going with higher than 25mm LIPOs , I bought 2 pairs of Turnigy nano-tech 4850mah 2S3P 50~100C Hardcase Lipo Saddle Pack, specs:
Capacity: 4850mAh
Voltage: 2S3P / 2S Cell / 7.4V
Discharge: 50C Constant / 100C Burst
Weight: 132g EA (290g Total Inc Wires)
Dimensions: 69x47x25mm EA
Balance Plug: JST-XH
Discharge Plug: 4mm Bullet-connector to your own custom plug
Model no: NC4850.2S3P.50
And they do not fit in height, can't close the lid ????
Should they ? Or do I need to make some mod to the DEX410v3 ?
Thanks for the help in advance
Max
MaximeRoy77 is offline
Old 06-12-2014, 03:49 PM
  #16074
Carlos69's Avatar
Originally Posted by MaximeRoy77
Guys,
Capacity: 4850mAh
Max
Per chance you've put the battery hinge pin in the lower hole ?
Carlos69 is offline
Old 06-12-2014, 03:50 PM
  #16075
Trader Rating: 15 (100%+)
the battery strap is set to the highest hole on the loop? I had to move mine to the top hole to fit the 5100 MAH saddles in from turnigy.
RBraswell is offline
Old 06-12-2014, 05:25 PM
  #16076
Thanks - i'll have a look and keep you posted.
Old 06-12-2014, 06:15 PM
  #16077
sometimes the pin is just awkward to push through when the car is new
av4625 is offline
Old 06-12-2014, 07:26 PM
  #16078
No. I can't push the pin in. I need 1mm in height and 2mm in length.
Is the dex410v4 new lipo brace In any way better for theses max_size lipo??
Old 06-12-2014, 08:06 PM
  #16079
Pittster's Avatar
I have the same batteries, Its a really tight fit I actually use the Type B 410 Lipo battery brace due to having a carbon chassis and alloy side pods, as well as a hacked up version of the Plastic Spur mount it dosent have the battery clip hole in it so I can flex the pin into the hole a little easier.
http://www.team-durango.com/part-inf...artNo=TD320244
It does get easier over time from use.
Also is anyone using a shorty in there 410 ?? Im going to try it next race meet as i run in a 17.5 class weight came down 50g.
I have the rear skid weight so it should be OK hopefully not to loose in the rear.
Pittster is offline
Old 06-14-2014, 10:51 PM
  #16080
13Maschine's Avatar
I'm not sure why but I can't get my SMC shorty to fit down the middle like this. I can't fit my battery wires in and I can't put the strap down. It's also fairly tough to put the battery in in the first place, without squeezing the plastic portion of the motor mount out of the way.
