Like Tree22Likes
Old 05-22-2014, 10:35 AM
  #15916
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by knowitall156
Nice work. Fast lap and the win. Your center diff conversion is so fun to drive, it's ridiculous. I just came off winning both our Friday night and Tuesday night series with it.
Great job Mike! Glad somebody agrees!!
Bman's 3XNT is offline
Old 05-22-2014, 11:16 AM
  #15917
13Maschine's Avatar
Bman and Incubus, have you guys done anything to combat broken arm syndrome? Obviously don't crash….(I know I need more practice). I wanted to get your input.
I think the 2 way slipper design is great and a nice improvement over the standard slipper. I've seen a few situations with long rhythm sections where I think a center diff would be better. I just wish it was a little easier to convert between the two. I like the slipper design as it's very low rotating mass. There's a growing class of 13.5 4 wheeler at my local track and I think going with this and a shorty pack would be wicked. I wonder about the balance though…..I plan to get some scales soon so I can see how it all works out.
Thanks!
13Maschine is offline
Old 05-22-2014, 11:46 AM
  #15918
the incubus's Avatar
Trader Rating: 17 (100%+)
I found the culprit for snapping from arms to be the set screw that threads into the caster blocks. I started using the B Type arms that use a securing screw like Associated to keep the pin from falling out and have not snapped an arm since. Perhaps that set screw places too much pressure on the ends of the pin and arms and when you hit something it's just what it needed to push it over the edge.
the incubus is offline
Old 05-22-2014, 11:48 AM
  #15919
Thanks!
The v3 arms seem fine. The v4 I broke in practice first time out. I don't like the design. If you run the v3 style with HD pins you should be fine.
Old 05-22-2014, 11:52 AM
  #15920
Trader Rating: 25 (100%+)
Default For sale
TD DEX410V3 for sale: http://www.rctech.net/forum/r-c-item...ller-sale.html
IVAN RM is offline
Old 05-22-2014, 12:14 PM
  #15921
13Maschine's Avatar
I broke all of my V3 arms and didn't finish a single race or qualifier. I'm running the Tresrey TiNi hinge pins. They seem great as they didn't seem to get bent in any of these crashes. I expect Amain to deliver my B type arms today.
…..Granted we have a bit of a crazy design with a crossover that has no net, this same Xover leads to cartwheels onto the straightaway or landing on the cars below. Did I mention the double double after the straight? phew. Lots of broken cars on Sunday.
My local hobby shop stopped carrying Durango parts which is part of why I'm leaning towards the D413. They have said they will carry parts for it. I'd love to see Durango do something even more robust with their next design. Perhaps the D413 arms will fit my durango
Old 05-22-2014, 01:02 PM
  #15922
Realistically, the reason the 410 seems brittle is because of it's weight. If there was a proper CF Chassis option with accompanying CF side plates, the car would be lighter and therefore not as hard on components when crashing. Also, the precision fit of the components on Durango vehicles means there's no give as compared to some others which, when combined with the load = Snap!
Old 05-22-2014, 10:18 PM
  #15923
LOSI123's Avatar
Trader Rating: 63 (100%+)
Does anyone know if the ProLine "Stabilizer" Wing fits ok on the DEX410?
LOSI123 is offline
Old 05-22-2014, 11:15 PM
  #15924
should be fine, may need a little bit trimming.
nicholasxuu is offline
Old 05-23-2014, 12:30 AM
  #15925
13Maschine's Avatar
As I rebuild my car and realize I've broken another front shock tower (carbon fibre cuts hurt!) as well as all the arms (trying not to be frustrated, I know it's my fault for crashing but I'll post a video of the track and you'll see what's up…) I thought perhaps using delrin pivot balls for the suspension would help give the arms a little bit of give to prevent snapping them. I think I will try and find some to try this out. I'm also now using the Type B arms with the set screw. I've noticed the Tresrey Titanium Nitride pins are a little bit too long for the Type B setup so probably best to use the pins that come with the arms. Anyone using anything else?
I think I have most of the light options although I am running the rear weight under the gear box (30g). I'm running Titanium turnbuckles, Titanium Ball Studs, and the Tresrey Pins…Seems like this leaves the Servo or going to shorty packs. Did I miss any other ideas?
Old 05-23-2014, 04:00 AM
  #15926
LOSI123's Avatar
Apart from the Tekin RS and Speed Passion Reventon R does anyone else know of any 8.5T or lower capable small Sensored ESC's?
LOSI123 is offline
Old 05-23-2014, 04:24 AM
  #15927
ekt
ekt's Avatar
Viper ESCs are another option
ekt is offline
Old 05-23-2014, 04:31 AM
  #15928
When the front arm breaks, what location does it happen? Inside, outside? The Tresrey pins look to be stock TD pins but coated, if these are the ones your referring to. I would get the HD pins or McMaster drill blanks. Much stronger.
Old 05-23-2014, 05:13 AM
  #15929
RC10Nick's Avatar
I got my center diff conversion out on the track for the first time last night. HOLY COW! What a difference. The car was super aggressive. It accelerated harder, it braked harder, it jumped better, and the back end didn't want to step out at all. It was better in almost every way... The only problem? It pushed pretty hard. That was completely expected, though. Moving the batteries 90* takes weight from the front and puts it on the rear, and I didn't change my spring rates to match.
I am absolutely convinced now. Center diffs are the way to go!
RC10Nick is offline
Old 05-23-2014, 05:21 AM
  #15930
Exactly what I've been saying. You can't explain it unless you try it. Thank you!! And congrats on your build.... what weight oil in the center?
