Like Tree22Likes
Old 09-08-2010, 09:44 PM
  #1576
R-E-A-P-E-R-'s Avatar
Originally Posted by dangerwr
You need to order a lot of spares son! Might as well get you a spare roller why you at it! Ha-ha! Cannot wait for winter racing (almost)! I think the class will be good size on the heels of eifff EP and this crazy Durango invention!
Are you going to park your 2.0 for the winter or bring it out to play every now and then
R-E-A-P-E-R- is offline
Old 09-08-2010, 09:47 PM
  #1577
dangerwr's Avatar
No. I will not be running 8th scale on that track!
dangerwr is offline
Old 09-08-2010, 09:48 PM
  #1578
SALLY
Its a good lesson in control
Old 09-08-2010, 09:54 PM
  #1579
dangerwr's Avatar
SALLY
Needed for some but not I. Current limiter, kiddo. See you in Burlymantown running Nitro . . .
dangerwr is offline
Old 09-09-2010, 04:40 AM
  #1580
Matt Howard's Avatar
Originally Posted by Dlewis4
Just checked the tracking on my package that I ordered from him at 1PM yesterday, it is sitting in KC right now... so i will have it tomorrow morning.
Cant beat that shipping time!
good to know. I placed an order through Amain on saturday and it's not schedueled to be delivered until monday Granted it was a holiday weekend but I'm not paying Amain's extra charge for "rush" packing. Next time I'll just go through RPP.
Matt Howard is offline
Old 09-09-2010, 07:20 AM
  #1581
Trader Rating: 54 (100%+)
What are common parts that should be ordered as spares with this kit? I have read about the front outer suspension holder, can someone give a part number for it, and what else is needed?
Also, what motor is best for a smallish track? Was leaning towards a 10.5.
Lastly, what is the limitation on height for a Lipo? I have Venom 6300mah saddle packs, but not sure if they will fit.
jsmax is offline
Old 09-09-2010, 07:46 AM
  #1582
i think its 23-25mm depending on what car you have
Old 09-09-2010, 08:10 AM
  #1583
ABBOTT's Avatar
23 or 25 is correct. The venoms will not fit. sorry
ABBOTT is offline
Old 09-09-2010, 11:31 AM
  #1584
tonyv2382's Avatar
Trader Rating: 67 (100%+)
As with every kit just get things that are prone to breakage. Hubs, steering knuckles, the odd suspension components etc... The car is tough so you wont break much if you drive well. the a-arms are indestructible. The only thing you really need is the front outer susp holder in aluminum. But in general doesnt hurt to have things for back up. I came off a triple with a zx5 and we both landed on eachother and I had to replace a steering knuckle and c-hub. so far thats all Ive broken. You mal also want to look into getting the rear bulk head supports in aluminum as well.
tonyv2382 is offline
Old 09-09-2010, 12:46 PM
  #1585
dangerwr's Avatar
Questions??
Quick question:
Has anyone measured the offsets of these wheels compared to AE or Losi? Grapejuice?? I want to know if I have options . . .
dangerwr is offline
Old 09-09-2010, 01:37 PM
  #1586
grapejuice's Avatar
Trader Rating: 151 (100%+)
Quick question:
Never measured but I use losi wheels with no fitment issues. I read somewhere that the AE front wheels don't fit well because of the offset.
grapejuice is offline
Old 09-09-2010, 02:47 PM
  #1587
tonyv2382's Avatar
If Im not mistaken, I think the rango front wheels have a deeper fitting for the front wheel adapters. I tried fitting some 501x front wheels, which are the same as the losi fronts and it didnt work out. The fit wasnt all that.
In the rear different story.
Old 09-09-2010, 02:51 PM
  #1588
Quick question:
I measured the width using losi wheels front and back compared to the Durango wheels and they were the same. If there was a difference it was 1mm or less each way
Old 09-09-2010, 02:57 PM
  #1589
kenshu's Avatar
You can run the AE wheels. For the rears just cut the pin shorter to fit in the wheel. For the fronts take the gold drive hex off. Then get 4 front wheel crush spacers for the 410R and put 2 on each side then use a Hot Bodies hex hub or AE B44. That's what I did and the spacing is correct.
kenshu is offline
Old 09-09-2010, 04:52 PM
  #1590
dangerwr's Avatar
Great! This is exactly what I want to hear. Losi wheels it is! Looking on Oople it appears to me that early DEX410 prototype has a lot of Losi parts on it . . .
dangerwr is offline
