Like Tree22Likes
Old 05-11-2014, 10:46 AM
  #15856
psl
LRP Vector, K4, I pulled it out my SCT.
psl is offline
Old 05-11-2014, 11:36 AM
  #15857
13Maschine's Avatar
Smile
I haven't gone as low as 18 yet, but I will try it today to see if it fits. I usually run between 20-22(87 Spur) with my 5-6.5T motors. Have you tried attaching the motor and setting the mesh while the whole center transmission is out? It's only 4 screws on the bottom and it's much easier to get perfect mesh this way I've found. Although I end up doing it in the car sometimes when I wanna change gearing quickly….I've found having a short wrench like this helps tons. Pic attached...
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_0201.jpg
13Maschine is offline
Old 05-11-2014, 09:15 PM
  #15858
rcjunky1's Avatar
What turn? you want to be careful on gearing with that motor, they can melt if you get them too hot, not forgiving at all to over heating, and with the plastic can I'd start 1 tooth smaller then usual.
rcjunky1 is offline
Old 05-12-2014, 03:15 PM
  #15859
LOSI123's Avatar
Trader Rating: 63 (100%+)
On the black ALum seteering rack plate that come with my V4 there is 2 holes for steering linkage to change ackerman, On setup sheets im seeing 3 holes, im geussing this is the machined alum plate, Can anyone tell me which 2 holes the black plates comapres to of the 3 hole plate?
LOSI123 is offline
Old 05-12-2014, 03:23 PM
  #15860
front two holes.
nicholasxuu is offline
Old 05-12-2014, 03:40 PM
  #15861
lowbudget1's Avatar
I also have a steering question has anybody had trouble with the steering rack rubbing on the servo? Also I had to use shorter screws than the kit recommends because mine went through the back of the mount and rubbed the steering assembly causing binding. I did use a radiopost servo which has metal replaceable mounting ears that are thinner than plastic ears just a heads up for the v4 builders.
lowbudget1 is offline
Old 05-12-2014, 04:07 PM
  #15862
yes, a little bit. Overall not a big deal.
In short course, I use some of those cheap solar servos, so I just trimmed my servo a bit to make it rub less.
and buggy I just use low profile servo, not touching at all.
Old 05-13-2014, 02:43 AM
  #15863
LOSI123's Avatar
I had a few screws on the kit be too long also, a newbie may have not noticed and just kept screwing tho lol
My servo mounting screws were way to long also, which if i kept going in would have busted through plastic and jammed up the steering
LOSI123 is offline
Old 05-13-2014, 08:03 AM
  #15864
billdogg's Avatar
Trader Rating: 15 (100%+)
What setup should I start with? I'm on a medium sized indoor track. Medium grip hard pack.
billdogg is offline
Old 05-13-2014, 10:14 AM
  #15865
Hey guys, how is everyone doing with their v5s? I haven't been running mine because I haven't been able to get out to the track.
TLRrunner is offline
Old 05-13-2014, 11:42 AM
  #15866
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I've been running mine outdoors the last month. All I can say is it's been awesome. The only thing I changed was tires and more droop... kinda of figured this is were the platform would have its advantages over the v4.
Dude run that sh!t…
Bman's 3XNT is offline
Old 05-14-2014, 07:38 AM
  #15867
13Maschine's Avatar
Smile
V5 = CENTER DIFF? aka the 410Bman edition
Old 05-14-2014, 08:16 AM
  #15868
the incubus's Avatar
Trader Rating: 17 (100%+)
What shock cap is that??!??
the incubus is offline
Old 05-14-2014, 08:58 AM
  #15869
13Maschine's Avatar
@incubus: Are you healing up nicely? I'm running these STRC shock caps:
http://www.amain.com/product_info.ph...ps-4-Gun-Metal
Old 05-14-2014, 10:10 AM
  #15870
13Maschine's Avatar
has anyone considered taking a set of Durango wheels and shaving the outside rib off to make them more like an EVO or VTR style wheel? Does anyone shave the inner rib to tune the wheel a bit?
