Like Tree22Likes
Old 05-05-2014, 11:13 PM
  #15841
ekt
ekt's Avatar
Originally Posted by billdogg
I just picked up a used DEX410V3. It came RTR with a cheap AE radio and rx. I'd like to use my Airtronics MT4. The space for the rx is pretty tight. How are you guys mounting the RX? It has a smaller Tekin RS Pro ESC next to the spur gear.
A couple pics of my wiring
ekt is offline
Old 05-06-2014, 06:17 AM
  #15842
rcjunky1's Avatar
With the wires going over the center drive shaft, can you easily remove the spur assemble and will it clear the body? I've found you get one or both those issues unless you go under the shaft like I did.
rcjunky1 is offline
Old 05-06-2014, 07:16 AM
  #15843
garagebuilt's Avatar
Just want to make sure im getting the right springs. the dex410v3 with big bores would come with dark blue springs right?
garagebuilt is offline
Old 05-06-2014, 07:26 AM
  #15844
the incubus's Avatar
Trader Rating: 17 (100%+)
You just have to give just the right amount of slack and it's no issue to remove the slipper assembly. I run a fan under my front shaft so my wires have to go over the top.
This is with my old RS Pro and futaba Rx:
I have to look for pics with new equipment.
the incubus is offline
Old 05-06-2014, 02:37 PM
  #15845
billdogg's Avatar
Trader Rating: 15 (100%+)
Thanks for the pics guys. It will help a lot.
billdogg is offline
Old 05-06-2014, 04:37 PM
  #15846
Very clever functional wiring layout
Aussie RC is offline
Old 05-06-2014, 04:54 PM
  #15847
Smile my layout
my version the wires run under the center shaft...I believe running the wires over would keep things a bit cooler to allow better circulation around motor
Cheers
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-20140507_094847.jpg
Old 05-06-2014, 04:57 PM
  #15848
13Maschine's Avatar
@incubus: I should dig up my smoking car video from Hot Rod hobbies. And you are totally right….having the wires sandwiched together like this could cause a short. Probably a good reason to use a square pack as you can have your pos/neg wires with a little more separation. I should probably shrink the ends that attach to the ESC as well….
It's a bit time consuming to get everything to wire up properly, I had to extend my capacitor wires and I think next time I re-do it I might try to run them between the receiver and ESC to keep them away from the spur. The real trick is to create a setup that is super easy to get in and out. It makes the car super easy to work on if you take the time up front.
13Maschine is offline
Old 05-06-2014, 05:31 PM
  #15849
billdogg's Avatar
Now that I can get my radio setup. What is a good starting setup for medium sized indoor hard pack? Here's a video (not mine) of the newest layout.
http://youtu.be/9ZDMiOomMnY
billdogg is offline
Old 05-06-2014, 06:07 PM
  #15850
Well this is what I did with my Reventon Pro 1.1 which has the quad capacitor...
Old 05-06-2014, 06:08 PM
  #15851
Pittster's Avatar
I wired mine up for ease of use motor removal sensor cable replacement etc not the prettiest but its racing so im not worried as long as they look good body's on.
Pittster is offline
Old 05-06-2014, 07:06 PM
  #15852
Originally Posted by 13Maschine
NICE! I have 2x of their Top end shorty packs. both awesome. Have you run the packs yet? What charger are you using? I just picked up a Junsi 308Duo
No not yet. I have to try and make time to get it all together. The electronics I mean. I use a cheap thunder ac6 from hobby parts. Works great though.
04sti20 is offline
Old 05-06-2014, 09:09 PM
  #15853
ekt
ekt's Avatar
Dark blue fronts TD330137 and light blue rears TD330151
ekt is offline
Old 05-11-2014, 08:24 AM
  #15854
psl
Just purchased a v4. It is a great buggy. I am having a problem getting small pinions to fit on the motor and mesh with the spur gear. I have an 87 pinion and I cannot put anything smaller then a 23 pinion on. Any ideas or suggestions? Any help would be great.
psl is offline
Old 05-11-2014, 09:44 AM
  #15855
rcjunky1's Avatar
you should be able to go smaller, I think 18 is the smallest. What motor are you running?
rcjunky1 is offline
