Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
[QUOTE=ekt;13204161]I noticed you are using the aluminium servo mount, there can be an issue of the top deck moving because it doesn't have the locators that fit into the top deck hole like the plastic mount. There was a mod for it, but I'll have to try find it.
*Edit
Found it here rctech.net/forum/11408457-post11388 [QUOTE]
So I tried this mod and it did not stiffen the front of the chassis at all in the area that is flexing.
Like I said before, you really have to land right at the top point of a landing with the middle of your chassis to cause the front drive shaft pop out.
*Edit
Are you running the alum diff hoops? I wonder if these would stiffen the front end enough to keep the drive shaft intact when you land on the face of a jump. I haven't had this problem yet although I haven't taken too many landings in the same way you mentioned….
Isn't this EXACTLY what I said I wanted to do, only to have a bunch of people tell me they've tried it and it's terrible>
Winning a 2WD kinda says otherwise. Being as I LOVE the look of the 410 over any other buggy I would LOVE to have a 2WD version so I can stockpile a bunch of spares of just a single model. Having once lost my front drive shaft in a race I know how well a 2WD version of this buggy can perform.
Has anyone tried the front wing similar to what Jorn ran at EOS round 4? If so how is it mounted?
Front wings are usually mounted on the shock tower somehow. However, there are ways to set up a car to work well without the front wing.
I've had an idea to cut Lexan pieces that would mount to the front arm hardware that has a measured pitch in order to provide a significant amount of downforce without looking so clumsy and cumbersome the way traditional front wings do.
I was there this weekend and i've not exactly seen, how Jorn was mounting the front wing, but i saw how Lee Martin was testing with the front wing on his yokomo!
They just stick them on the bodyshell with double side tap, thats all!
Man, that was such a great weekend and i saw many prototyp parts and stuff, thats not on the market jet, or even not will go on the market at all!?
Thanks micholix!
So I picked up a v3 roller. Didn't come with sway bars. What do I need? I have the rod ends already but don't know what else. So far I think I need
Td230012 front 1.5mm roll bar kit
Tdr230013 rear 1.5 kit. I'm starting with 1.5 to be sort of in the middle
V3 likes a light front sway bar (1.1 or 1.3) or None - Depending on layout for clay or dirt
The most cost effective way for me to get the sway bars going on my V3 was with the TD230031 kit.
http://www.team-durango.com/part-inf...artNo=TD230031
The only other part you may need depending what came with your roller.
TD330003
http://www.team-durango.com/part-inf...artNo=TD330003
TD330003
TD330003
Has anyone had trouble with the diff outdrive sleeves causing a little bit of binding with my drive shafts? It seems the drive shaft pin rides on the internal ridges of the sleeve causing the suspension to stick a little bit. I had expected these to bed in a bit after running a few practice days and a race day. Still a little sticky though, has anyone else experienced this? Did you shave down the pin just enough to keep it from sticking? Dremel the inside of the sleeve a little?
Thanks in advance!
Thanks in advance!
